PIC16F877 Microcontroller
In summary, the conversation discusses using a port on the PIC16F877 microcontroller to output an oscillator signal of a fixed frequency for an LED indicator light on a remote-controlled boat project. The frequency of the signal can be controlled through programming and the LED has a limit beyond which it cannot blink on and off, but this limit is beyond the perception rate of human eyes.
cyeokpeng
69
Hi,
One of my projects requires my team to build a remote-controlled boat. One of the features of the boat is an indicator light feature which will blink on and off to indicate that there is this ship nearby and signal to other ships to clear away during dim light conditions (for example visibility is poor due to fog or at night). OK, now is a simple simple question.
Can I use one of the ports (for example port RC0 of the PIC16F877) to output an oscillator output signal of a fixed frequency (the frequency, how to determine or control this frequency in the microcontroller? Is it dependent on the external crystal oscillator clock frequency?) since this port is designated as a Timer1 oscillator output?
How does the oscillator signal output of this port look like if I program the microcontroller to output the desired frequency I want? Is it a square wave signal with logic one at 5V say, and logic 0 at 0 V? If the signal is exactly as above, then I think the LED will blink on/off which satisfy our design specifications.
Another question on the LED, does LEDs have a frequency sensitivity that at a certain threshold frequency, it cannot change fast enough to blink on/off? Or is this limitation of the frequency dependent on how our eyes perceive it, not on the LED itself?
Usually the microcontroller executes instructions slower then the input oscillator frequency. You can look in the documentation for this or just set a port to alternate between +5 and ground and use an oscilloscope to measure the frequency at which it switches.
The led can turn off and on faster then our eyes can perceive. The LED does have a limit but that limit is far beyond the perception rate of human eyes.
Hello,
Yes, you can use port RC0 of the PIC16F877 microcontroller to output an oscillator signal of a fixed frequency. The frequency of the output signal can be controlled by the microcontroller through the Timer1 module. The frequency is dependent on the external crystal oscillator clock frequency, which can be determined by the user during the design process. The output signal of this port will be a square wave with a logic high of 5V and a logic low of 0V, which can be used to drive an LED for blinking on and off.
In terms of frequency sensitivity, LEDs have a specific range of frequencies that they can handle, and if the frequency is too high, the LED may not be able to turn on and off fast enough to produce a visible blinking effect. However, this limitation is usually dependent on the specific LED being used and can vary. Our eyes also have a threshold for perceiving blinking lights, so the frequency should be within a certain range to be noticeable to humans. It is best to test the frequency with the specific LED being used to ensure it meets the design specifications.
Related to PIC16F877 Microcontroller
1. What is a PIC16F877 Microcontroller?
A PIC16F877 Microcontroller is a type of microcontroller, which is a small computer on a single integrated circuit. It is commonly used in electronic devices to control and communicate with other components.
2. What are the main features of the PIC16F877 Microcontroller?
The main features of the PIC16F877 Microcontroller include a 8-bit microprocessor, 14kB of flash memory, 368 bytes of RAM, 33 input/output pins, and a variety of communication interfaces such as UART, SPI, and I2C.
3. What applications can the PIC16F877 Microcontroller be used for?
The PIC16F877 Microcontroller can be used in a wide range of applications, including industrial control systems, consumer electronics, medical devices, and automotive systems. It is often used in devices that require precise timing and control.
4. How do I program a PIC16F877 Microcontroller?
The PIC16F877 Microcontroller can be programmed using a variety of programming languages, including assembly language and C. To program it, you will need a programmer device and specific software, such as MPLAB IDE, which is provided by the manufacturer Microchip.
5. Are there any limitations to the PIC16F877 Microcontroller?
Like any microcontroller, the PIC16F877 has limitations, such as its 8-bit processing capability and limited memory. However, for many applications, these limitations are not significant and the PIC16F877 is a reliable and versatile choice for controlling electronic devices.
  • Electrical Engineering
