Polarity and Electronegativity
In summary, when determining the polarity of a molecule, it is important to consider both the shape and bond polarities.
Veronica_Oles
142
When to use electronegativity value? and when to look at both bonds and shape?
This isn't really a question more so need some clarification.
First question is about electronegativity and bond polarity. When placing the delta positive and delta negative on your molecule, you place the delta negative on the molecule with the higher electronegativity number, correct?
You only use the electronegativity values when determining the polarity of a single bone, right??
And your dipole is directed towards the more electronegative atom??
For the second question, you should look at both bond and shape when determining the polarity of a molecule. The shape of the molecule can affect the overall polarity of the molecule. For example, a linear molecule will have no dipole moment, but a bent molecule may have a dipole moment. Additionally, the bond polarities in the molecule can also affect the overall polarity of the molecule. If all the bonds are non-polar, then the molecule will be non-polar. But if there are polar bonds in the molecule, then the molecule will be polar.
1. What is the difference between polarity and electronegativity?
Polarity refers to the unequal distribution of electrons in a molecule, resulting in a separation of charge. Electronegativity, on the other hand, is a measure of an atom's ability to attract electrons towards itself in a covalent bond.
2. How is polarity determined in a molecule?
Polarity is determined by the difference in electronegativity between atoms in a molecule. If the difference is large, the molecule will have a polar covalent bond. If the difference is small or zero, the molecule will have a nonpolar covalent bond.
3. What is the relationship between electronegativity and bond polarity?
The higher the electronegativity of an atom, the greater its ability to pull electrons towards itself in a covalent bond. This results in a polar covalent bond, with one atom having a partial negative charge and the other having a partial positive charge.
4. How does polarity affect the physical properties of a molecule?
Polarity can affect a molecule's boiling point, melting point, and solubility in different substances. Polar molecules tend to have higher boiling and melting points, and are more likely to dissolve in polar solvents.
5. What are some real-life examples of polar and nonpolar molecules?
Water is a commonly known polar molecule, with the oxygen atom having a higher electronegativity than the hydrogen atoms. Oil, on the other hand, is a nonpolar molecule, as it consists of mostly carbon and hydrogen atoms with similar electronegativities.
  • Chemistry
