Potential Difference Confusion
In summary, there are three different forms of potential difference: definition, differential, and point charge. However, the use of different reference potentials (Vi,Vf=0) can be confusing. It is important to note that potential is arbitrary and can be set like the origin of a coordinate system. The third equation is not potential difference, but rather a value of electric potential at a distance r from a point charge.
brentd49
74
There seems to be two different uses of potential difference that either contradict each other, or at the very least make it very confusing. Let me write the three different forms:
Definition: Vf-Vi= -E*d
Differential: dV=-E*dr (Vi=0)
Point Charge: V=E*r (Vf=0)
What is with the different reference potentials (Vi,Vf=0)? Can someone please make sense out of this.
Edit: I avoided writing integrals above because I don't how to use latex, and the book I'm studying is Halliday, Resnik.
Here is a nice discussion of potential energy. It is really the change in potential energy that matters.
http://hyperphysics.phy-astr.gsu.edu/hbase/pegrav.html#pe
Gravitational potential energy - http://hyperphysics.phy-astr.gsu.edu/hbase/gpot.html#mgh
Electric potential energy - http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elepe.html#c1
Reference potential - potentials are relative!
The nature of potential is that the zero point is arbitrary; it can be set like the origin of a coordinate system. That is not to say that it is insignificant; once the zero of potential is set, then every value of potential is measured with respect to that zero.
ref Hyperphysics
Read also the third plate in the link on electric potential - Potential Reference at Infinity.
Ok, so you Vf & Vi are values of potential. So if you substract them, you get the difference in potential between them.
Your second is just substituting 0 into your first equation.
Your third equation is not potential difference. It is a value of electric potential at a distance r from a point charge (It is the energy required to bring a unit charge of identical polarity from infinity to the distance r from the point source; that's the way I think about it).
Does this help you?
Regards,
Sam
Related to Potential Difference Confusion
1. What is potential difference confusion?
Potential difference confusion refers to a common misconception about potential difference, also known as voltage, in electrical circuits. It is the incorrect belief that potential difference is the cause of electric current, when in reality it is the result of electric current flowing through a circuit.
2. How does potential difference relate to electric current?
Potential difference is the difference in electrical potential energy between two points in a circuit. When a potential difference is present, it causes electric charges to move through the circuit, creating an electric current. However, it is not the cause of electric current, but rather the result of it.
3. Why is it important to understand potential difference correctly?
Understanding potential difference correctly is crucial for accurately analyzing and designing electrical circuits. It allows for proper measurement and control of electric current, which is essential for the safe and efficient operation of electrical devices.
4. What are some common misconceptions about potential difference?
Aside from potential difference confusion, other common misconceptions about potential difference include the belief that it is the same as electric potential, that it is the same at all points in a circuit, and that it is directly proportional to electric current.
5. How can potential difference confusion be avoided?
To avoid potential difference confusion, it is important to have a clear understanding of basic electrical principles and to use proper terminology when discussing potential difference. It can also be helpful to visualize potential difference as the driving force for electric current, rather than the cause of it.
