Power required to rotate a load of specific weight
The discussion revolves around calculating the power required to rotate a 200kg cylindrical load at 5 RPM with a diameter of 6m. The moment of inertia is calculated as 183 kg.m², leading to a torque of 96 Nm when assuming a 1-second time frame for acceleration. However, the torque required to maintain constant rotation is debated, with the consensus that if friction is negligible, no torque is needed to sustain the rotation. The torque needed to initiate movement depends on overcoming static friction and achieving the desired angular acceleration. The setup confirms that the axis of rotation is parallel to the Earth's surface, indicating that the torque from weight is effectively zero.
escape_velocity
  • Weight - 200kg
  • RPM - 5
  • Diameter - 6m
Moment of Inertia I = (weight/9.8).r^2
Torque t = I * (angular velocity / t)
Power = Torque * speed
First I calculate
Moment of Inertia Using
I=(weight/9.8) * r^2 = 183 kg. m^2
Then I calculate Torque using
t=I∗(angularvelocity / t) = 96 Nm
where angular velocity is in rad/s.
Here is where I'm stuck if I take t as 1sec I get a Torque of 96 Nm.
If take t as 5 sec the I get a Torque of 19 Nm But my load is rotating at constant rpm of 5 so what would be the correct torque.
Once I get the torque I will find Power by P=Torque∗speed.
Likes Delta2
Unless there is friction, or some other opposing torque, no torque is required to maintain a steady rotation rate.
Apparently the torque of the weight is the opposing torque. Thus we must provide a torque ##T_N## equal and opposite to the torque of weight ##T_B## so that the total torque ##T_N+T_B=0## is zero, so that the rotation rate is constant.
What is the torque of weight? Use the definition of Torque of a force, not from ##T=I\alpha## (to use the latter we will have to know the "partial" angular acceleration due to the torque of weight, which is unknown, though we know the total angular acceleration which is zero).
The Torque of weight ##T_B## will not be constant through time. It will depend on time t but not in the way you write in the OP.
Once you find ##T_B## use the relation for power ##P_B=T_B\omega## , where ##\omega## is the constant angular velocity , to find the power ##P_B## that the weight gives to its mass. The power of the torque ##T_N## will be equal and opposite that is ##-P_B##.
Thanks for the esteemed answers. So to find the torque of weight Tb will i need to know the friction in the ball bearings on which the load rotates?
No , the Torque from the friction in the ball bearings is another torque, I assumed it to be zero for this exercise.
BUT tell me how exactly the weight rotates? Is the axis of rotation perpendicular to gravity or parallel to gravity?
I suspect you are reading too much into the use of the word "weight".
As I read it, escape_velocity has a mass of 200kg rotating on axis, and probably the axis passes through the mass centre.
@escape_velocity , please clarify the exact set-up.
Ok @Delta² @haruspex
So the actual setup is a cylinder (not a complete rod but a shell with thickness 5mm) with diameter 6 meter and weight 200kg and axis of rotation is passing through its centre. The axis of rotation is parallel to the Earth's surface and perpendicular to gravity.
So without friction, why would any torque be required to maintain a constant rate of rotation?
If that's the setup then the torque of weight is zero (assuming that the cylindrical shell has constant density and the axis of rotation passes through the c.o.m). There must be some friction force, either in the ball bearings or somewhere else (maybe in the point of contact between the cylindrical shell and the ground) in order for a torque to be needed to maintain a constant rate.
Does that mean that once the cylinder is set into motion the only force that retards its rotation is the bearing friction. No it draws negligible power when its rotating at 5rpm its as though the motor is running unloaded. Is this the right deduction? Somehow it sounds strange.That a 200kg load is moving with negligible power!
But what would be the torque required to set this load into motion?
The relevant equation (if we ignore friction for the moment) is...
Torque = moment of inertia * angular acceleration
There is a similarly with the equation for linear motion..
Force = mass * acceleration
In both cases if the acceleration is zero (eg constant velocity or constant angular velocity) then the net force or torque is also zero.
To calculate the total torque needed to start it turning you need to know if there is any static friction as that can be higher than the running or kinetic friction. You also need to know how fast you want it to accelerate up to speed.
Likes Delta2
If there is anything in the cylinder (eg its really a trommel used for gold mining) then that will have an effect.
Yes this is because the torque of weight is zero , or almost zero since the axis of rotation passes through the center.
if we ignore the static friction that @CWatters mentions then it depends on how fast you want it to catch the final angular velocity. If the final angular velocity is ##\omega## and you want it to catch this velocity in time ##t## then calculate the average angular acceleration as ##\alpha=\frac{\omega}{t}## and then the Torque will be ##T=I\alpha=mr^2\frac{\omega}{t}##​
