Prove Holomorphic on C: Continuity and Differentiability
  • Thread starter fauboca
In summary, the key idea is to find a holomorphic function g \colon \mathbb C \to \mathbb C that agrees with f everywhere except possibly on [2,5], and then use the Integral Transform Theorem to show that f and g agree on all points outside of C. However, we run into problems when trying to apply this to points inside C but not on [2,5], as the corollary to the theorem requires f to be holomorphic inside the circle. Therefore, alternative approaches such as Morera's theorem may need to be used to show that f is holomorphic at all points of C.
  • #36
Let ##\gamma## be a closed curve in ##\mathbb{C}##. If ##\gamma## doesn't contain any point from [2,5] in its interior, then ##\int_{\gamma}f=0## since f is holomorphic away from [2,5]. Suppose that ##\gamma## contains [2,5] in its interior. Let R be a rectangle oriented with the coordinate axes in ##\gamma## such that [2,5] is in R such that ##[2,5]\notin\partial R##. Divide the rectangle into two sub rectangles of length ##1-\epsilon## and ##\epsilon## such that [2,5] is contained in one the sub rectangles. WLOG suppose [2,5] is the rectangle of length ##\epsilon##. Then the over f of the rectangle of length ##1-\epsilon## is zero.
I am not sure how you mean to use the limit argument.
<h2>1. What does it mean for a function to be holomorphic on C?</h2><p>A function is considered holomorphic on C if it is complex differentiable at every point in the complex plane. This means that the function has a well-defined derivative at every point in the complex plane, which is a stronger condition than just being differentiable on the real line.</p><h2>2. How can I prove that a function is holomorphic on C?</h2><p>To prove that a function is holomorphic on C, you must show that it satisfies the Cauchy-Riemann equations. These equations relate the partial derivatives of the function's real and imaginary parts, and if they are satisfied, the function is complex differentiable and therefore holomorphic on C.</p><h2>3. Is a holomorphic function on C always continuous?</h2><p>Yes, a holomorphic function on C is always continuous. This is a consequence of the Cauchy-Riemann equations, which imply that the function's real and imaginary parts are continuously differentiable. Therefore, the function is continuous on the complex plane.</p><h2>4. Can a function be holomorphic on C but not differentiable at a specific point?</h2><p>No, a function cannot be holomorphic on C if it is not differentiable at a specific point. Holomorphicity requires complex differentiability at every point in the complex plane, so if a function is not differentiable at a specific point, it cannot be holomorphic on C.</p><h2>5. Are all analytic functions on C holomorphic?</h2><p>Yes, all analytic functions on C are holomorphic. This is because an analytic function is one that can be expressed as a convergent power series, and any function that can be represented as a power series is complex differentiable and therefore holomorphic on C.</p>
