Is z_0 a Removable Singularity in Complex Analysis?
  • MHB
  • Thread starter alexmahone
In summary, by estimating the coefficients of the Laurent Series, we can prove that if $z_0$ is an isolated singularity of $f$, and if $(z-z_0)f(z)\rightarrow 0$ as $z\rightarrow z_0$, then $z_0$ is a removable singularity.
alexmahone
304
By estimating the coefficients of the Laurent Series, prove that if $z_0$ is an isolated
singularity of $f$, and if $(z−z_0)f(z)\rightarrow 0$ as $z\rightarrow z_0$, then $z_0$ is removable.
My attempt
$\displaystyle f(z)=\sum\limits_{n=0}^\infty a_n(z-z_0)^n+\frac{b_1}{z-z_0}+\frac{b_2}{(z-z_0)^2}+\ldots+\frac{b_n}{(z-z_0)^n}+\ldots$
in a punctured disk $0<|z-z_0|<R_2$.
So, $\displaystyle(z-z_0)f(z)=\sum\limits_{n=0}^\infty a_n(z-z_0)^{n+1}+b_1+\frac{b_2}{z-z_0}+\ldots+\frac{b_n}{(z-z_0)^{n-1}}+\ldots$
in $0<|z-z_0|<R_2$.
How do I proceed?
To prove that $z_0$ is a removable singularity, we need to show that the Laurent series of $f(z)$ around $z_0$ has no negative powers of $(z-z_0)$. This means that all the coefficients $b_n$ must be equal to 0.
Since $(z-z_0)f(z)\rightarrow 0$ as $z\rightarrow z_0$, we know that the Laurent series of $f(z)$ must converge to 0 at $z=z_0$. This implies that $\lim_{n\rightarrow\infty}a_n(z-z_0)^n=0$ as $z\rightarrow z_0$.
Using the fact that $a_n$ is the coefficient of the $(z-z_0)^n$ term in the Laurent series of $f(z)$, we can write this as $\lim_{n\rightarrow\infty}a_n=0$. This means that all the coefficients of the positive powers of $(z-z_0)$ in the Laurent series of $f(z)$ must be equal to 0.
Since all the positive powers of $(z-z_0)$ are eliminated, the Laurent series of $f(z)$ reduces to a polynomial in $(z-z_0)$, which is analytic at $z=z_0$. This means that $z_0$ is a removable singularity of $f(z)$.
Related to Is z_0 a Removable Singularity in Complex Analysis?
1. What does it mean for z_0 to be removable?
When we say that z_0 is removable, it means that the function f(z) has a singularity at z_0, but it can be "removed" by assigning a value to f(z_0) that makes the function continuous at that point.
2. How can you prove that z_0 is removable?
To prove that z_0 is removable, we must show that the limit of f(z) as z approaches z_0 exists and is equal to the value of f(z_0) that makes the function continuous at that point.
3. Why is it important to prove that z_0 is removable?
Proving that z_0 is removable is important because it allows us to extend the domain of the function f(z) to include z_0, making the function continuous at that point. This can help us better understand the behavior of the function and make calculations easier.
4. Can z_0 be removable in all cases?
No, z_0 cannot be removable in all cases. There are certain types of singularities, such as essential singularities, that cannot be removed. Only isolated singularities can be removed by assigning a value to make the function continuous at that point.
5. How does proving that z_0 is removable relate to complex analysis?
Proving that z_0 is removable is a fundamental concept in complex analysis. It allows us to extend the domain of a function to include singularities, which is crucial in understanding the behavior of complex functions. It also helps us classify different types of singularities and analyze the properties of functions in the complex plane.
  • Topology and Analysis
