How Does the Quotient Rule Apply to Derivatives of Cotangent Functions?
In summary, the quotient rule was used to find the derivative of cot(x), which is equal to cos(x)/sin(x). However, in the attempt to simplify the expression, parentheses were dropped resulting in incorrect answers. The correct derivative is -csc^2(x).
Torshi
118
Use quotient rule
d/dx (cot(x)
d/dx (cot(x))
= cos(x)/sin(x)
= (sin(x))(-sin(x)) - (cos(x))(cos(x)) / (sin(x))^2
= -(sin(x))^2 - (cos(x))^2 / (sin(x))^2
= -1 - (cos(x))^2
Does the last step equal 1 + (cos(x))^2 and how come that turns into negative -(csc(x))^2
Torshi said:
Use quotient rule
d/dx (cot(x)
d/dx (cot(x))
= cos(x)/sin(x)
= -1 - (cos(x))^2
I think you dropped some parentheses and this led you to a wrong answer. That first step should be:
$$ \frac{d}{dx} \cot(x) = \frac{\sin(x)(-\sin(x)) - \cos(x)\cos(x)}{\sin^2(x)}$$
Now simplify the numerator and see what you end up with.
= (-1)-(cos(x))^2
Torshi said:
= (-1)-(cos(x))^2
Shouldn't the second term be divided by ##\sin^2(x)##?
Hold on
-1 - (cos(x))^2 / (sin(x))^2 = -1/(sin(x))^2 = -(csc(x))^2
but...
-(sin(x))^2 - (cos(x))^2 / (sin(x))^2 = 1/(sin(x))^2 = -(csc(x))^2
Torshi said:
Hold on
How did you get that?
but...
I think there are some parentheses missing again. The expression on the left should be
$$\frac{-\sin^2(x) - \cos^2(x)}{\sin^2(x)}$$
Now you can use the identity ##\sin^2(x) + \cos^2(x) = 1## in the numerator.
My main question is do both of the following equations equal -(csc(x))^2
1/(sin(x))^2 and -1/(sin(x))^2
or which one of those two define -(csc(x))^2 ?
Since, by definition, csc(x)= 1/sin(x), it follows that sin(x)= 1/csc(x) and then that [itex]sin^2(x)= 1/csc^2(x)[/itex].
If you want "-" on the right, you will have have a "-" on the right.
Torshi said:
Use quotient rule
d/dx (cot(x)
d/dx (cot(x))
= cos(x)/sin(x)
You haven't actually taken the derivative yet, so the above should be:
=d/dx(cos(x)/sin(x))
Others have already commented about the missing parentheses and the incorrect parts.
= -1 - (cos(x))^2
Related to How Does the Quotient Rule Apply to Derivatives of Cotangent Functions?
What is the Quotient Rule for Derivative?
The Quotient Rule for Derivative is a formula used in calculus to find the derivative of a quotient of two functions. It states that the derivative of a quotient is equal to the denominator multiplied by the derivative of the numerator, minus the numerator multiplied by the derivative of the denominator, all divided by the square of the denominator.
When is the Quotient Rule used?
The Quotient Rule is used when finding the derivative of a quotient of two functions, where the numerator and denominator are both functions of the independent variable.
How is the Quotient Rule applied?
To apply the Quotient Rule, you must first identify the numerator and denominator functions. Then, use the formula: (f'(x)g(x) - f(x)g'(x)) / (g(x))^2, where f'(x) is the derivative of the numerator function and g'(x) is the derivative of the denominator function.
Can the Quotient Rule be simplified?
Yes, the Quotient Rule can be simplified by factoring out a common term from the numerator or denominator, or by using algebraic manipulations to simplify the expression before taking the derivative.
What are some common mistakes made when using the Quotient Rule?
One common mistake is forgetting to square the denominator in the final step of the formula. Another mistake is misapplying the chain rule when taking the derivative of the numerator or denominator functions. It is also important to pay attention to signs and make sure they are properly included in the final answer.
