How Do You Calculate Total Alpha-Decays in Radium-226 Experiment?
In summary, the problem involves finding the total number of decays per gram of radium-226 per second, given a sample of 6.3 x 10^-5 g placed in a vacuum and exposed to a screen 1.5 m away for 10 minutes. The provided solution calculates this by determining the number of alpha particles emitted by 1 g in 1 min and hitting the screen, and then multiplying it by the surface area at the sampling distance. This accounts for the assumption that the radium emits particles equally in all directions.
sparkle123
175
It is found that when a 6.3 x 10–5 g sample of radium-226 is placed in a vacuum and exposed
to a screen of area 1.0 mm2 placed 1.5 m away from the sample, an average of 46 α-particles
hit the screen in 10.0 minutes. Calculate the total number of decays per gram of radium-226 per
second.
2. Solution provided
α−particles emitted by 63 μg in 10 min & hitting screen = 46
thus α−particles emitted by 1 g in 1 min & hitting screen = 46/(10×60) × 1/(6.3×10−5) =1.2 ×10^3
total α−particles emitted by 1 g in 1 min = 46/(10×60) × 1/(6.3×10−5) × 4 π (1.5 ×10^3)^2
= 3.4 ×10^10 g-1 s-1
I don't understand where "4 π (1.5 ×10^3)^2" comes from. Please explain?
Thanks!
Assume that the radium emits particles equally in all directions. The screen only sampled a 1 millimeter square area. What's the total potential surface area at the sampling distance?
Related to How Do You Calculate Total Alpha-Decays in Radium-226 Experiment?
1. What is radioactive decay?
Radioactive decay is the process by which an unstable atomic nucleus loses energy by emitting ionizing particles or radiation. This process transforms the nucleus into a more stable state and can continue until the nucleus reaches a stable configuration.
2. What is the purpose of a radioactive decay experiment?
The purpose of a radioactive decay experiment is to study the rate of decay of a radioactive substance and to determine the half-life, which is the amount of time it takes for half of the substance to decay. This information can be used to understand the properties of radioactive materials and to make predictions about their behavior.
3. How is a radioactive decay experiment conducted?
A radioactive decay experiment typically involves taking a sample of a radioactive substance and measuring its activity over a period of time. This can be done using a Geiger counter or other radiation detection equipment. The data collected is then used to calculate the half-life of the substance.
4. What are some common applications of radioactive decay experiments?
Radioactive decay experiments have a wide range of applications, including in medical imaging, carbon dating, and nuclear power. They are also used in research to study the behavior of different elements and to develop new materials.
5. Are there any safety precautions that need to be taken when conducting a radioactive decay experiment?
Yes, there are several safety precautions that should be taken when conducting a radioactive decay experiment. These include using proper protective gear, handling the radioactive material carefully, and following proper disposal procedures. It is also important to conduct the experiment in a well-ventilated area and to limit exposure to the radioactive material as much as possible.
  • Atomic and Condensed Matter
