How Does Distance Affect Photon Fluence and Energy Fluence Rate?
  • Thread starter johnq2k7
  • Tags
    Physics
In summary, we calculated the energy fluence rate and corresponding photon fluence of a monoenergetic isotropic photon source at a radial distance of 20 cm from the origin. We also determined that the radiation follows an inverse square law and calculated the number of photons reaching a detector at a specific position and orientation after a certain collection time.
johnq2k7
64
Imagine that a point source is poisitioned at the origin of a sphere. Assume a monoenergetic isotropic photon source, emitting 10^9 photons*s^-1, each with a frequency of 2.7 x 10^20 Hz.
a.) Calculate the energy fluence rate [MeV cm^-2 s^-1] at a radial distance of 20 cm from the source. Calculate the corresponding photon fluence crossing a spherical surface elemental area (i.e a "curvy surface tile") at a radial distance of 20 cm over a time period of 10 seconds.
b.) Plot the photon fluence rate (i.e particles crossing a surface spherical elemental area per unit surface area (cm^-2) per unit time (s)) as a function of radial distance from the origin, and determine the slope of the curve. What is the common language description for this type of radiation reduction with distance?
c.) Calculate the number of photons reaching a detector subtending polar angles between 5 and 10 degrees, and azimuthal angle between 20 and 25 degrees, place at a radial distance of 5 cm, after a collection time of 1 minute.
Please help, I'm having a lot of difficulties approaching this question
. a.) The energy fluence rate at a radial distance of 20 cm from the source is given by:Energy fluence rate = (10^9 photons/s) x (2.7 x 10^20 Hz) x (3.7 x 10^-14 MeV/photon) / (4πr^2)= 1.22 x 10^-1 MeV cm^-2 s^-1The corresponding photon fluence crossing a spherical surface elemental area at a radial distance of 20 cm over a time period of 10 seconds is given by:Photon fluence = (10^9 photons/s) x (10 seconds) / (4πr^2)= 0.785 photons cm^-2b.) The photon fluence rate as a function of radial distance is given by: Photon fluence rate = (10^9 photons/s) / (4πr^2)The plot of this equation is an inverse square law, meaning that the radiation intensity decreases with the square of the distance. c.) The number of photons reaching a detector subtending polar angles between 5 and 10 degrees, and azimuthal angles between 20 and 25 degrees, placed at a radial distance of 5 cm, after a collection time of 1 minute is given by: Number of photons = (10^9 photons/s) x (60 seconds) x (ΔΩ/4π)where ΔΩ is the solid angle subtended by the detector, which is given by: ΔΩ = (10 degrees - 5 degrees)(25 degrees - 20 degrees) = 125 degrees^2 Therefore, the number of photons is given by: Number of photons = (10^9 photons/s) x (60 seconds) x (125 degrees^2/4π) = 6.37 x 10^8 photons
Related to How Does Distance Affect Photon Fluence and Energy Fluence Rate?
1. What is radiological physics?
Radiological physics is a branch of physics that deals with the use of radiation in medicine, industry, and research. It involves the study of the properties and effects of radiation, as well as the development and application of technologies that use radiation.
2. What are the different types of radiation?
The three main types of radiation are alpha, beta, and gamma. Alpha radiation consists of high-energy helium nuclei, beta radiation consists of high-speed electrons, and gamma radiation consists of high-frequency electromagnetic waves.
3. How is radiation used in medicine?
Radiation is used in medicine for diagnostic purposes, such as X-rays and CT scans, and for therapeutic purposes, such as radiation therapy for cancer treatment. It is also used in nuclear medicine to diagnose and treat various diseases.
4. What are the safety precautions when working with radiation?
When working with radiation, it is important to follow safety precautions to minimize exposure. This includes using shielding materials, wearing protective gear, following proper handling and storage procedures, and monitoring radiation levels regularly.
5. What is the role of a radiological physicist?
A radiological physicist plays a crucial role in ensuring the safe and effective use of radiation in various fields. They are responsible for maintaining and calibrating radiation equipment, developing radiation safety protocols, and providing guidance on the proper use of radiation in medical procedures.
  • Thermodynamics
