What Are the Nuances of Mathematical Symbols and Their Applications?
In summary: A hyperbola, however, is created by slicing a cone with a plane that is not parallel to the side. It meets both halves of the cone and so is represented by two separate pieces.
jaysquestions
None of these questions are homework problems, they're just confusing things that homework has caused
1. In math, what is the difference between a bracket and a parenthesis? Also what about the right symbols for ordered pairs , is that strictly these [ ] or these { }
2. If you have lots of brackets (just to be clear, I mean these ( ) )... does the number of left hand brackets always equal the right hand brackets? For example,
## f(x) = (3(x^2 - 3) / x(x^3+6)) ## I realize it could be written a lot different, but I am just focused on the brackets.
..so when you are checking over a long problem, you can count the left brackets and make sure they = right brackets. Is that valid? (in English one right bracket can close multiple left brackets, which has never made sense to me. So math is different?)
3. What is he difference between "broadened" and "steepened" wrt graphs?
4. Are corners of a function defined and how do I know they are defined? (or does it all depend on the function?
5. What does the textbook mean when he says "use analytical method to determine..." Is he just saying make a graph and look at it?
6. Conic sections: Why are hyperbolas represented with two lines , taken from two cones, when circles and ellipses are represented using just one cone?
thank you for any answers
Mathematics news on Phys.org
Yes. If a closing parenthesis is missing, there is no reason to assume it belonged at the end. It's a mistake.
I've never heard of this. Brackets and parentheses must always be used in pairs. The only exceptions are smilies and leetspeak.
LISP programming used to use the convention of a square bracket closing the program statement. It would basically close all remaining open parentheses.
Also there's a general convention in math to call "( )" parentheses and "[ ]" square brackets and "{ }" curly braces with some folks dropping the square and curly adjectives.
Using an analytical method means to use algebra rules, trigonometric, boolean, ... identities and Calculus rules to reduce an expression into a simpler form or to use numerical methods to get an answer. This is in opposition to graphing the function and determining things visually by inspection.
In general there is no difference. There may be special cases. For example, you ask about "ordered pairs" being either [ ] or { }. I have never seen either of those. I have always seen (a, b) for ordered pairs.
Yes, "brackets" ("braces", "parentheses") always separate a given section of a formula from the rest. You should never have a left bracket without a corresponding right and vice versa.
I have never heard of such an "English rule". Where did you learn that? Is it, for example, in Strunk's "The Elements of Style"?
Pretty much just what it says. If you have a function, y= f(x), such that f(1)= 3, f(2)= 4, and f(4)= 7, so that the graph contains the points (1, 3), (2, 4), and (4, 7), then the graph of y=f(2x) satisfies f(2)= 3 and f(4)= 4 so contains the points (2, 3) and (4, 4). This new graph takes twice as long (2 to 4) to go from height 3 to height 4 a before (1 to 2) so has "broadened. On the other hand, the graph of the function y= 2f(x) contains the points (1, 6) and (2, 8). In going from x= 1 to x= 2 horizontally, it has gone, vertically, from 6 to 8 so is steeper.
I have no idea what you mean here. A "function" is not a geometric object and so does NOT have "corners". Where did you see "corners of a function"? How were they defined where you saw the reference?
No, an "analytical method" (just "analytical method" without an article would be bad English!) is one that involves limits and calculations, not just looking at a graph. It might mean considering continuity and/or using limits to determine what asymptotes there are.
Because that is the way they are created. circles, ellipses (and parabolas) have only one connected component because they are created by slicing a cone (grammatical point: strictly speaking a "cone" always has two parts, not just one. It is incorrect to say "two cones" or "just one cone". You are rather, referring to one or two components of a cone.) with a plane. In the case of a circle so that the plane is perpendicular to the axis of the cone, and only intersects one component, in the case of an ellipse so that it is between perpendicular to the axis and parallel to one side, so that it still slices through one component of the cone, in the case of a parabola parallel to the side of the cone so goes through one side of one component and is parallel to the other, and, finally, a hyperbola that crosses through both components.
What do the words "broad" and "steep" mean to you?
Corners of what function? You'll have to be more specific here.
If that were the case, then the textbook would say, "graph [whatever] to determine ..."
Analytical methods usually involve doing calculations of some sort.
Look up how conic sections are defined by a plane which intersects the cone.
Some of these questions you could have answered yourself by doing a little research.
The web is a wonderful tool, but you've got to put forth a little effort to get it to yield its information.
Try using a search engine to answer some of these questions.
Hyperbolas come from double cones:
In this image, that would be #3. This is what https://www.physicsforums.com/members/hallsofivy.331/ meant when he said:
What is the purpose of random math questions?
The purpose of random math questions is to test a person's understanding and problem-solving skills in various mathematical concepts. These questions are often used in educational settings to assess a student's knowledge and progress.
How are random math questions generated?
Random math questions are typically generated using a computer program or algorithm that selects numbers and operations at random to create a question. These questions can be tailored to specific topics or difficulty levels.
Can random math questions be used for practice?
Yes, random math questions can be a great way to practice and improve your math skills. There are many online resources that offer random math question generators for this purpose.
Are there any benefits to solving random math questions?
Yes, solving random math questions can improve critical thinking and problem-solving abilities. It can also help strengthen your understanding of mathematical concepts and improve overall math performance.
How can I improve my performance on random math questions?
One way to improve your performance on random math questions is to practice regularly. You can also review and study different mathematical concepts and techniques to better understand how to approach and solve problems.
  • General Math
  • General Math
  • Differential Equations
  • General Math
  • General Math
