Relative Velocity of a Grenade
In summary, the hero in an action-adventure film needs to throw a grenade from his car to the enemy's car, which is traveling at a higher speed and is initially 15.9 m ahead. The grenade must have a launch angle of 45 degrees above the horizontal and an initial velocity greater than the enemy's car in order to catch up with it. The horizontal and vertical components of the grenade's velocity can be assumed to be equal in magnitude, simplifying the calculations. A spreadsheet can be used to solve for the launch velocity.
jasonchiang97
72
In an action-adventure film, the hero is supposed to throw a grenade from his car, which is going 79.0 km/h , to his enemy's car, which is going 125 km/h . The enemy's car is 15.9 m in front of the hero's when he let's go of the grenade.
If the hero throws the grenade so its initial velocity relative to him is at an angle of 45 ∘ above the horizontal, what should the magnitude of the initial velocity be? The cars are both traveling in the same direction on a level road. You can ignore air resistance.
Vx=Vcos45°*
Vy=Vsin45°
x=-b√(b2-4ac)/2a
d-vyt+gt2/2
Rx=Vcos45*t
villain velocity in m/s=34.72
hero velocity in m/s=21.94
34.72-21.94=8.77m/s
Vx/cos45=V
Vy=(Vx/cos45)sin45
d=(Vx/tan45)t+gt2/2Not sure what to do now.
Vx=Vcos45°*
Vy=Vsin45°
x=-b√(b2-4ac)/2a
d-vyt+gt2/2
Rx=Vcos45*t
34.72-21.94=8.77m/s
Vx/cos45=V
Vy=(Vx/cos45)sin45
Since the enemy's car is going faster than the hero's, the horizontal velocity of the grenade, relative to the ground, must be greater than the enemy's car in order to catch up with it. Since there is a difference in speed between the two vehicles, the initial separation of 15.9 m between the two cars is going to increase during the time of flight of the grenade.
That I understand but I'm not quite sure how that information will help me solve it.
You've figured out the relative velocity between the two cars.
You know what the launch angle of the grenade is.
You know how far apart the cars are initially.
The only thing you are missing is the launch velocity of the grenade.
If nothing else, you can assume a launch velocity and see if the grenade can reach the other car. It may not be an elegant solution, but you should be able to at least bracket an answer in a couple of attempts.
A problem like this is suitable for setting up using a spreadsheet to do the actual calculations.
One thing you can do to unclutter the math is take advantage of the launch angle being 45 degrees. That makes the horizontal and vertical components of the grenade velocity (with respect to the hero) equal in magnitude. So just call them both "v". That gets rid of all the trig functions, and you can later combine the components to obtain the magnitude of the velocity vector: ##~~~v_o = \sqrt{2 v^2}##.
1. What is relative velocity and how does it apply to grenades?
Relative velocity refers to the speed and direction of an object in relation to another object. In the case of grenades, it is the speed and direction of the grenade in relation to its initial position or the position of the thrower.
2. How is the relative velocity of a grenade calculated?
The relative velocity of a grenade can be calculated by determining the difference in velocities between the grenade and the thrower. This can be done by measuring the initial velocity of the thrower and the final velocity of the grenade at impact.
3. Does the shape or weight of a grenade affect its relative velocity?
Yes, the shape and weight of a grenade can affect its relative velocity. A heavier or more aerodynamic grenade will have a higher relative velocity compared to a lighter or less aerodynamic one.
4. How does air resistance affect the relative velocity of a grenade?
Air resistance can slow down the relative velocity of a grenade. As the grenade moves through the air, it experiences drag force which opposes its motion, causing it to slow down.
5. Can the relative velocity of a grenade be changed after it has been thrown?
No, the relative velocity of a grenade cannot be changed after it has been thrown. The only factors that can affect its velocity are external forces such as air resistance and gravity.
10K
