Safely and cost effective chemical to raise specfic gravity of water
In summary, the conversation is about finding a chemical to raise the specific gravity of water in order to float PVC in a separation process. Some suggestions were made, including using soluble tungsten salts or cheap calcium chloride. The latter was recommended due to its high solubility and resistance to wetting plastics. Additional information and resources were also shared for further research.
werecycle
We are currently working on a project with flexible PVC wire chop from a metals recycler. with a density of 1.1 -1.35 we are in search of a chemical to raise the specific gravity of 1,200 gallons of water to float the pvc in a separation process. any ideas? thank you
why not use salt?
i tried salt on a smaller scale and was able to make some of the pvc float. the water became so saturted it would not dissolve anymore salt.
try soluble tungsten salts
i don't recall which has the highest solubility, but sodium/ammonium tungstate/metatungstate/paratungstate are cheap
i will check into that. spoke with morton salt company this morning and they were not very informative. the first load will be here this week. we need a solution quick. thank you
I would use cheap calcium chloride (CaCl2) since you can make a solution up to 40-60% easily without crystallization. It is commonly sold as a deicer as prills, or as a concentrated solution.
It will need makeup if your separation is not a yes or no type of differentiation; the solution will continue to dilute itself when exposed to moisture in the air.
An advantage could be that it doesn't like to wet parts like plastics, so will bead up and easily come off the parts.
I found that Occidental Chemical (OXY) has some good PDF links to properties of solutions and handling info at oxycalciumchloride.com. Their LIQUIDOW is a technical grade water solution of 10-12 #/US gal calcium chloride.
Related to Safely and cost effective chemical to raise specfic gravity of water
1. How does specific gravity affect water?
Specific gravity is a measure of the density of a liquid compared to the density of water. A higher specific gravity means the liquid is more dense and will sink in water, while a lower specific gravity means the liquid is less dense and will float on top of water.
2. Why would someone want to raise the specific gravity of water?
Raising the specific gravity of water is often necessary in industrial processes where a certain level of density is required for the desired outcome. For example, in some manufacturing processes, a higher density of water is needed to properly mix chemicals or to aid in the separation of materials.
3. What are some common chemicals used to raise the specific gravity of water?
Some common chemicals used to raise the specific gravity of water include sodium chloride (salt), calcium chloride, and magnesium sulfate. These chemicals are readily available and cost-effective options for increasing the density of water.
4. Is it safe to add chemicals to water to raise its specific gravity?
As with any chemical, it is important to follow proper safety precautions when handling and adding chemicals to water. It is also important to carefully measure and monitor the amount of chemical being added to avoid over-densification of the water. Additionally, it is important to note that some chemicals may not be safe for certain applications or environments.
5. Can the specific gravity of water be raised without using chemicals?
Yes, there are natural methods to increase the specific gravity of water, such as heating the water or adding certain types of solids or gases. However, these methods may not be as effective or cost-efficient as using chemicals, and they may also have limitations in terms of the desired level of density that can be achieved.
  • Earth Sciences
  • General Discussion
