Why Does the Electric Field Sum Instead of Cancel with Opposite Charges?
In summary, a parallel plate capacitor is inside the region where both the positive and negative are in the same direction, but the electric field from the capacitor is the sum of the electric fields from the positive and negative charges. If there are two charges positive and negative and their electric field points in the same direction, then the total electric field from the charges would be their sum of magnitudes.
hello721
If there are two charges positive and negative and their electric field point in the same direction then the total electric field would be their sum of magnitudes. Why don't we consider the sign of the charges? For example, a parallel plate capacitor is inside the region where both the positive and negative are in the same direction but the Enet is the sum of both of them rather than canceling it out. I was assuming since one charge is negative and one is positive we can just cancel them out since they are equal in magnitude.
N/A
We find the strength and direction of an electric field by measuring the force on a positive test charge. If it is placed between the plates of a capacitor, the negative plate attracts it and the positive plate repels it, so they act in unison. By contrast, if we place the charge outside the capacitor, and some some distance away, the positive and negative plates now push and pull, so acting against each other. For this reason the field is weak outside the capacitor.
Likes topsquark
hello721 said:
Homework Statement:: If there are two charges positive and negative and their electric field point in the same direction then the total electric field would be their sum of magnitudes. Why don't we consider the sign of the charges? For example, a parallel plate capacitor is inside the region where both the positive and negative are in the same direction but the Enet is the sum of both of them rather than canceling it out. I was assuming since one charge is negative and one is positive we can just cancel them out since they are equal in magnitude.
Relevant Equations:: N/A
I we add two vectors that act in the same direction we simply add the magnitudes. The signs of the charges are already taken into account here: If the charges had the same sign then the vectors would point in the opposite direction and we'd have to subtract. That's all this problem is doing.
-Dan
You've gotten some good replies already. I'll just add: Don't just assign "+" or "-" signs to the electric field value based on the charge(s) producing it. Instead, think about the direction that the field vector (arrow) is pointing -- either away from or toward the charge that is responsible for it, based on the charge's sign.
Likes Tom.G, kuruman and topsquark
To write the electric field in a way that its direction will be sorted out automatically for an arbitrary charge, you have to use the formal expression for the electric field. Let's start with a charge on the x-axis at the origin. The formal expression for the electric field on the axis is $$E=\frac{k~q~x}{|x|^3}.$$Now this may seem a silly thing to write, but bear with me and let's see how it works.
Case I: Positive charge ##q=|q|##
$$E=\frac{k~|q|~x}{|x|^3}.$$When the point of interest is to the right of the charge (##x>0##), this yields ##E=\dfrac{k~|q|~(x)}{|x|^3}=\dfrac{k~|q|}{x^2}.##
When the point of interest is to the left of the charge (##x<0##), this yields ##E=\dfrac{k~|q|~(-x)}{|x|^3}=-\dfrac{k~|q|}{x^2}.##
So the field points away from the positive charge as it should.
Case II: negative charge ##q=-|q|##
$$E=\frac{k~(-|q|)~x}{|x|^3}.$$When the point of interest is to the right of the charge (##x>0##), this yields ##E=\dfrac{k~(-|q|)~(x)}{|x|^3}=-\dfrac{k~|q|}{x^2}.##
When the point of interest is to the left of the charge (##x<0##), this yields ##E=\dfrac{k~(-|q|)~(-x)}{|x|^3}=+\dfrac{k~|q|}{x^2}.##
So the field points towards the negative charge as it should.
Of course what is true along the x-axis, is also true along the y and z axes. Superposition then allows us to write the electric field vector at position vector ##\mathbf{r}## due to a charge at the origin as $$\mathbf{E}=\frac{k~q~\mathbf{r}}{|\mathbf{r}|^3}$$ where ##q## can be positive or negative.
To complete the picture, when the source charge is not at the origin but at position vector ##\mathbf{r}'## relative to the origin, we have the most general expression for the electric field from a point charge, $$\mathbf{E}=\frac{k~q~(\mathbf{r-r'})}{|\mathbf{r-r'}|^3}.$$
Likes ChiralSuperfields and topsquark
When the point of interest is to the left of the charge (##x<0##), this yields ##E=\dfrac{k~|q|~(-x)}{x^3}=-\dfrac{k~|q|}{x^2}.##
Should there be absolute-value bars around the "x" for the "x^3" term in the denominator? (And similarly for Case II, to the left of a negative charge.)
Likes kuruman
Good catch! I edited the post. Thanks.
1. What is the sign of electric field?
The sign of electric field refers to the direction of the force that a positive test charge would experience when placed in the electric field. If the force is directed towards the positive charge, the electric field is considered positive. If the force is directed away from the positive charge, the electric field is considered negative.
2. How is the sign of electric field determined?
The sign of electric field is determined by the relative positions of the source charge and the test charge. If the source charge and test charge have opposite charges (one positive and one negative), the electric field will be directed towards the positive charge. If the source charge and test charge have the same charge (both positive or both negative), the electric field will be directed away from the positive charge.
3. Can the sign of electric field change?
Yes, the sign of electric field can change depending on the relative positions of the source charge and the test charge. As the test charge moves closer or farther away from the source charge, the direction of the electric field may change from positive to negative or vice versa.
4. How does the sign of electric field affect the motion of charged particles?
The sign of electric field determines the direction of the force that a charged particle will experience. If the electric field is positive, the force will be directed towards the positive charge, causing the charged particle to accelerate towards it. If the electric field is negative, the force will be directed away from the positive charge, causing the charged particle to accelerate away from it.
5. What is the significance of the sign of electric field in electric circuits?
The sign of electric field is important in electric circuits because it determines the direction of the flow of electric current. In a circuit, the electric field is usually directed from the positive terminal of the battery towards the negative terminal. This causes the flow of electrons, which are negatively charged, in the opposite direction, creating an electric current.
