Solving Baseball Throw: Initial Speed, Altitude & Time
  • Thread starter Thread starter Pius
    Baseball
The discussion centers on solving a physics problem involving a baseball thrown upward, passing a window 23m high with a speed of 14m/s. To find the initial speed, altitude, and timing of the throw, participants suggest using kinematic equations that relate velocity, displacement, and acceleration. The ball's maximum altitude can be calculated by determining how much higher it ascends beyond the window before descending. The symmetry of the ball's trajectory indicates that the speed upon hitting the ground equals the initial speed, allowing for straightforward calculations of the time of throw and return. The conversation emphasizes the importance of understanding freefall mechanics and the parabolic nature of projectile motion.
Pius
A baseball is seen to pass upward by a window 23m above the street with a vertical speed of 14m/s. If the ball was thrown from the street, (a) what was the initial speed, (b) what altitude does it reach, (c) when was it thrown, and (d) when does it reach the street again?
v=v0+at
x=x0+v0t+1/2at^2
v^2=v02+2a(x-x0)
So I guess I use x=x0+v0t+1/2at^2 for the initial speed...altitude and time?
It's a lot clearer if you re-write your equations in a slightly different form:
<br /> v = v_0 + a t<br />
<br /> s = v_0 t + \frac{1}{2} a t^2<br />
<br /> v^2 = v_0^2 + 2 a s<br />
Where s is the displacement x-x_o[/tex](hint hint).
You know that at a height of 23m, the ball is moving at 14m/s. From this, you can calculate how much higher the ball will ascend before it begins its descent. The altitude it reaches will be this value plus 23m.
At this moment in time where the ball is still, you can apply freefall mechanics to it in order to find the speed at which it hits the ground. Since the flight of the ball is a parabola, its velocity is symmetric about the turning point, and the speed at which it hits the ground is the speed at which it was thrown (ignoring air resistance).
Once you have this velocity information, you can easily calculate (c) and (d).
hint: the horizontal speed doesn't change
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
