Speeding bullet, average force by post on bullet
In summary, the conversation discusses the calculation of average force using the change in momentum over time and the kinematics equation. However, the answers on the MCQ sheet do not match the calculated answer and there is a discrepancy in the method used to calculate average force. The conversation also mentions the importance of considering units in calculations and the application of Newton's third law.
serendipityfox
bullet initial speed 600m/s, mass 15g, penetrates 10cm, average force exerted by post on bullet
f= delta p/t, d=vi+vf/2 *t
used a) change in momentum / time, time from from kinematics equation d = vi+vf/2 *t ... 0.1 = 300*t
=3.33*10^-4
then 600/0.00333 = 1.8*10 ^5
how to proceed?
What you calculated as 1.8x10^5 is the average acceleration (or to be more accurate deceleration) of the bullet. How can you find the average force if you know the average acceleration? Newton's 2nd law of course! :D
thankyou delta2
i bungled the second equation... should be 9 / 0.00033 of course
answer i get is 2.7*10^4
but the mcq answers are...
a) 9.0*10^3
b) 5.3*10^4
c) 2.4*10^5
d) 1.6*10^6
I get the same answer as you, don't know what's going on, maybe recheck the data given.
serendipityfox said:
thankyou delta2
a) 9.0*10^3
b) 5.3*10^4
c) 2.4*10^5
d) 1.6*10^6
If you assume a constant force, hence constant acceleration, then the work done is ##Fd## and this must equal the initial KE of the bullet. So:
##F = \frac{mv^2}{2d}##
This agrees with the formula derived from the kinematics of constant acceleration.
Assuming SI units (units are important but missing from your work and your answers), then this should be ##F = 27kN##.
Likes Delta2
... average force exerted by post on bullet, will be same as the bullet on post?
@Delta2 - thankyou for the assistance
@PeroK - sorry will endevour to be more precise
Likes Delta2
That's Newton's third law.
Likes Delta2
so still no viable answer according to the exam sheet... well this discourse has been helpful anyway, thanks
As @PeroK notes, the question embodies a blunder: you have to assume the force is constant.
Average force (a vector) is defined as change in momentum (a vector) divided by elapsed time (a scalar). Dividing work done by distance produces a scalar, and this does not in general match the magnitude of the average force. It is an interesting exercise to calculate the difference in the case of a spring.
physics question section on an MCAT practice paper
1. What is a speeding bullet?
A speeding bullet is a projectile that travels at a velocity that is faster than the speed of sound.
2. How is the average force of a bullet calculated?
The average force of a bullet is calculated by dividing the change in momentum of the bullet by the time it takes to change that momentum. This can be represented by the equation F = Δp/Δt, where F is average force, Δp is change in momentum, and Δt is change in time.
3. Why is it important to understand the average force of a bullet?
Understanding the average force of a bullet is important for a variety of reasons. It can help us understand the impact and potential damage caused by a bullet, and also aid in the design and development of bulletproof materials and structures.
4. How does the average force of a bullet affect its trajectory?
The average force of a bullet plays a significant role in determining its trajectory. A higher average force will result in a faster and more powerful bullet, which may have a flatter and more accurate trajectory. On the other hand, a lower average force may result in a slower and weaker bullet with a more curved trajectory.
5. Can the average force of a bullet be altered?
Yes, the average force of a bullet can be altered by changing its mass or velocity. A heavier bullet will have a higher average force, while a faster bullet will have a higher average force as well. Other factors such as air resistance and gravity can also affect the average force of a bullet.
