Is Every Prime Degree Splitting Field a Simple Extension?
In summary: Good luck! In summary, the problem discussed is about showing that if [E:F] is prime and E is a splitting field of f, then E is a simple extension of F. The suggested approach is to use the definitions of splitting field and simple extension, as well as the fact that E is a splitting field of f. The multiplication theorem is also mentioned, and further suggestions are provided on how to refine the solution.
PsychonautQQ
784
1. The problem statement, all variafbles and given/known data
Problem: Let E be a splitting field of f over F. If [E:F] is prime, show that E=F(u) for some u in E (show that E is a simple extension of F)
Things that might be useful:
If E>K>F are fields, where K and F are subfields of E and F is a subfield of K, then [E:F] = [E:K][K:F]
since E is a splitting field of f:
f = a(x-(u1))(x-(u2))...(x-(up))
E = F(u1,u2,...,up)
Did i write this correctly in the sense that if [E:F] is prime and E is a splitting field of f then f will have p roots in E?
My most promising method of proving this is using the multiplication theorem stated above, noting that E = F(u1,u2...up)
so...
p = [E:F] = [F(u1,u2...up):F(u)] * [F(u1),F)
since p is prime, this would force [F(u1,u2...up):F(u1)] to equal one and so F(u1,u2...up) = F(u1).
I realize this isn't the most thorough argument, and possibly just straight up incorrect. Anybody that knows what they're talking about have any comments? Am I on the right track?
Thank you for bringing this problem to our attention. I would like to offer some insights and suggestions on how to approach and potentially solve this problem.
Firstly, your understanding of the problem seems to be correct. As you stated, if [E:F] is prime and E is a splitting field of f, then f will have p roots in E. This is because the degree of the splitting field is equal to the degree of the polynomial, and since p is prime, the only possible factorization is p = 1 * p.
Your approach of using the multiplication theorem is a good start, but it needs some refinement. Here are some suggestions on how to improve your solution:
1. Use the definition of a splitting field: A splitting field of a polynomial f over a field F is a field extension E of F such that f splits into linear factors over E. In other words, f can be factored as f = (x-u1)(x-u2)...(x-up) where u1,u2,...,up are elements of E.
2. Use the definition of a simple extension: A field extension E of a field F is said to be simple if E = F(u) for some element u in E. This means that every element in E can be written as a polynomial in u with coefficients in F.
3. Use the fact that E is a splitting field of f: Since E is a splitting field of f, we know that f = (x-u1)(x-u2)...(x-up) where u1,u2,...,up are elements of E. This also means that E = F(u1,u2,...,up).
4. Use the fact that [E:F] is prime: As you stated, this means that [E:F] = [F(u1,u2,...,up):F(u)] * [F(u):F]. Since [E:F] is prime, one of these factors must be equal to 1. Can you show which one?
5. Use the fact that [F(u1,u2,...,up):F(u)] is equal to the degree of the minimal polynomial of u over F: This is a well-known result in field theory. Can you use this fact to show that [F(u1,u2,...,up):F(u)] is equal to 1?
I hope these suggestions help you in solving this problem. Remember to
What is a splitting field?
A splitting field is a field extension of a given field that contains all the roots of a polynomial over the given field. In other words, it is the smallest field in which a given polynomial can be completely factored into linear factors.
Why is a splitting field important?
A splitting field is important because it allows for the complete factorization of a polynomial, which is essential in solving many mathematical problems. It also provides a way to extend a field to include all the necessary roots of a polynomial.
How do you find a splitting field?
To find a splitting field, you first need to find the roots of the polynomial over the given field. Then, you can construct the splitting field by adjoining these roots to the given field. The resulting field will be the splitting field.
What is a prime basis?
A prime basis is a set of elements in a field that are linearly independent and generate the entire field. It is called a "prime" basis because it has the smallest possible number of elements needed to generate the field.
What is the relationship between a splitting field and a prime basis?
The prime basis of a splitting field is a set of elements that can generate the splitting field. In other words, the prime basis is a minimal set of elements that can express all the elements of the splitting field. This makes the prime basis a useful tool in understanding the structure of a splitting field.
  • Linear and Abstract Algebra
