Steam Flow through holes in a pipe
The discussion focuses on calculating the mass flow rate of dry saturated steam through five 3mm holes in a 25mm ID pipe under a pressure of 3 kg/cm². Key considerations include whether there are restrictions downstream and the length of the pipe, which is noted to be 200mm. Participants suggest researching orifice flow and choked flow, as well as using the Moody chart to determine pressure drop effects on steam pressure at the holes. The context of the steam application involves a device that conditions fabric by exposing it to steam as it passes through rollers. Understanding these parameters is crucial for accurate flow rate calculations.
saruvanan
TL;DR Summary
What will be mass flow rate of dry saturated steam through holes on a pipe.
What will be mass flow rate of dry saturated steam through holes on a pipe. Pipe ID: 25mm, Steam Pressure 3 kg/cm^2, Holes' Dia: 3mm, Number of Holes: 5.
Is this a homework problem? Is there any restriction downstream from the holes? What is your background? What have you tried so far?
Search engine is your friend. Start with orifice flow, then search choked flow. If the 25 mm pipe is very long, search Moody chart or Moody diagram to calculate pressure drop in the pipe to find steam pressure at the holes.
We have a steam bath device in our company.
In this device, we feed a fabric in tape form by 2 set of rollers. Between the rollers we expose the fabric to steam (by a steam pipe directly beneath the fabric) in order to condition it.
The pipe is about 200mm long. When we switch on the rollers, we switch on the steam too by a ball valve. The pipe is closed at one end and other end is supplied with steam. All 5 holes are 40mm apart.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
