How Do You Determine the Equation of a Parabola Given its Vertex and a Point?
  • Thread starter Evan1025
In summary: After verifying that "a" is indeed the correct answer, I plugged it into the equation to find the x-coordinate of the vertex. The x-coordinate is 3.
Evan1025
Two children were bouncing a ball. During one particular bounce, the ball traveled a horizontal distance of 6 feet and its maximum height above the ground was 4 feet. The path was in the shape of a parabola. Find the standard equation of the parabola described by this information. Let x represent the horizontal distance in feet from the point the bounce started and y represent the height above the ground in feet.
Here's the possible answers:
http://img145.imageshack.us/img145/3118/possanswerszr3.jpg
Standard form of a parabola: F(x)=a(x-h)^2 + k
Finding a is my problem, but ultimately you need to find the other variables before you can find a so essentially i am having problems with it all.
In the standard equation k would be be y intercept. In your case I believe that is +4. That narrows it down to A, C, and E. The brute force method is to solve the standard equation when y = 0. You know that when y = 0, that x must equal [tex]\pm[/tex] 6. Therefore you can check equations A, C, and E. to see if when y=0 x=[tex]\pm[/tex]6.
If its a perfect parabola, then what's the x coordinate of the maximum height?
I think that the x value for the max height is 3 because it would half way between the 2 x intercepts.
I had plugged all of the information into the equation, and tried solving for a.
But i can't come out with any of the a values in any of the possible answers. I get a = 0.
Starting from standard position, y=a(x-c)^2+b, this has been translated to
y=a(x-3)^2+4.
One of the points is (3, 4). Another point on this graph will be (6, 0), one of the intercepts. "a" should be a negative number. Do some algebra and obtain a formula,
(y-4)=a(x-3)^2
a = ((y-4)^(0.5))/((x-3)^2)),
Now plug in the values for coordinate of (6, 0) for x and y and find a. You will obtain the value of a = ? You can figure this out now.
THANK YOU symbol!
I figured it out i think, or atleast i got the a value in one of the possible answers.
Here's how i did it, to help anyone else who might have had a similar problem.
y=a(x-h)^2 + k (standard equation)
0=a(6-3)^2 + 4 (In the original problem it says that y represents the height above the ground but the trick is, the height above the ground at a horizontal distance of 6, which means the height is 0 because at a horizontal distance of 6 it has hit the ground already. So i plugged in 3,4 for h,k and i plugged in 6,0 for x,y)
0=a(3)^2 + 4
0=9a +4
-4=9a
a=-4/9
Standard equation: y=-4/9(x-3)^2 + 4
Actually you don't need to find a at all- the problem does not require you to. You know that the "base" of the parabola goes from 0 to 6 and, because of the symmetry, the vertex will be at the horizontal mid-point, x= 3. The top is at 4 so the vertex is at (3, 4). Now you know that the graph is of the form y= a(x- 3)2+ 40- and only one of the answers, C, is like that.
Oh yes that is true. But the reason i wanted to make sure and find a was because on the test that's coming up it might not be multiple choice. So i would need to know how to find a in that situation. Thank you so much everyone.
Absolutely a good approach. I rechecked carefully for "a" to be sure that a correct choice was given among the set of answer choices.
Related to How Do You Determine the Equation of a Parabola Given its Vertex and a Point?
What is a parabola?
A parabola is a type of mathematical curve that is commonly seen in algebra and geometry. It is a symmetrical curve that can be described by a quadratic equation.
How are parabolas used in story problems?
Parabolas are often used in story problems to represent real-life situations, such as the path of a thrown object or the shape of a satellite dish. They allow us to model and solve problems that involve quadratic equations.
What is the formula for a parabola?
The standard form of a parabola is y = ax^2 + bx + c, where a, b, and c are constants. The value of a determines whether the parabola opens upwards or downwards, while the values of b and c affect the position and shape of the curve.
How do we find the vertex of a parabola?
The vertex of a parabola is the point at which the curve changes direction. It can be found by using the formula x = -b/2a, where a and b are the coefficients of the quadratic equation. The y-coordinate of the vertex can then be found by substituting the value of x into the equation.
Can parabolas have more than one x-intercept?
Yes, parabolas can have multiple x-intercepts if the curve crosses the x-axis at more than one point. This occurs when the quadratic equation has two distinct real roots. However, there are also cases where the parabola does not intersect the x-axis at all.
  • General Math
