Sufficient condition(s) for a non-local diffeomorphism?
In summary, non-local diffeomorphisms are transformations that do not preserve the local structure of a space. They are characterized by singularities and non-invertibility. Unlike local diffeomorphisms, they can result in chaotic behavior and have applications in nonlinear systems, image processing, and computer graphics.
dash-dot
I hope I'm posting this question in the right forum; anyway, here goes:
What would be a sufficient condition for a diffeomorphism to be non-local--specifically, for it to be valid over a given domain?
In the particular case I'm examining, the mapping I'd like to be a non-local diffeo is given by a solution to a PDE with a perturbation term. In the absence of the perturbation, I can simply take the mapping to be the identity map (which can always be shown to be a global diffeo, correct?).
Hence, my objective is to establish that for a "small enough" perturbation term, the solution to the PDE is itself a perturbation of the identity mapping, and hence valid over the domain of interest.
PS: For those who wish to see the actual PDE and obtain additional information, here it is:
Given a compact set [itex]D\in\textbf{R}^{m+n}[/itex] containing the origin, I would like to find a mapping
[itex]T:D\to \textbf{R}^m; \quad T:(x,s,\phi)\mapsto q[/itex]
that is given by the solution to the PDE
[itex]\frac{\partial T}{\partial s}+\left( \frac{\partial T}{\partial \phi}-\frac{\partial T}{\partial s}\,\frac{\partial N}{\partial \phi}\right)M\delta_a=0,[/itex]
where [itex]x\in\textbf{R}^{n-1},\, s\in\textbf{R},\, \phi\in\textbf{R}^m,\, M=M(x,\phi)\in\textbf{R}^m,\, N=N(x,\phi)\in\textbf{R}[/itex] and [itex]\delta_a=\delta_a(x,s)\in\textbf{R}[/itex].
[itex]\delta_a(x,s)[/itex] is the perturbation I'm talking about, and we see that when [itex]\delta_a=0[/itex], we can simply take [itex]q=T(\phi)=\phi[/itex]. Hence, for small enough [itex]\delta_a[/itex], we expect [itex]T[/itex] to just be a perturbation of the identity map, and I need for it to be valid for all [itex](x,s,\phi)\in D[/itex].
If anyone could recommend some books or other references that talk about when a diffeomorphism is non-local (or global, although I don't need mine to be valid globally, but if it turns out to be the case for any [itex]T(x,s,\phi)[/itex] satisfying the PDE above, then great), that would be awesome.
Thanks for taking the time to read this. :)
Thank you for your question. I would like to provide some insight into your inquiry. A diffeomorphism is a type of mapping between differentiable manifolds that preserves the smoothness of the functions being mapped. In order for a diffeomorphism to be non-local, it would have to violate one of the properties of a diffeomorphism. This can happen if the mapping is not one-to-one, or if it is not continuously differentiable. Therefore, a sufficient condition for a diffeomorphism to be non-local would be if it does not preserve the smoothness of the functions being mapped.
In the case of the PDE you have provided, the mapping T is given by the solution to the PDE. If the perturbation term \delta_a is small enough, then T will be a perturbation of the identity map. This means that T will still preserve the smoothness of the functions being mapped and will be a valid diffeomorphism over the given domain. However, if \delta_a becomes too large, then T may no longer preserve the smoothness of the functions and will no longer be a valid diffeomorphism.
In terms of references, there are many books and resources that discuss diffeomorphisms and their properties. Some recommended books include "Introduction to Smooth Manifolds" by John M. Lee and "Differential Geometry: Connections, Curvature, and Characteristic Classes" by Loring W. Tu. These books discuss the fundamentals of diffeomorphisms and their applications in mathematics and physics.
I hope this explanation helps. Please let me know if you have any further questions or if you would like me to provide more information. Best of luck with your research!
1. What are non-local diffeomorphisms?
Non-local diffeomorphisms refer to transformations or mappings that do not preserve the local structure of a manifold or space. This means that the points in the space are rearranged in a way that does not follow the usual smooth and continuous transformation patterns.
2. What are the sufficient conditions for a non-local diffeomorphism?
The sufficient conditions for a non-local diffeomorphism include the presence of singularities, such as cusps or folds, in the mapping, as well as the non-existence of a local inverse or the failure of the inverse function theorem.
3. How do non-local diffeomorphisms differ from local diffeomorphisms?
Local diffeomorphisms preserve the local structure of a space, meaning that the mapping is smooth and continuous in a small neighborhood around each point. Non-local diffeomorphisms, on the other hand, do not preserve this local structure and can result in singularities or non-invertibility.
4. What are some applications of non-local diffeomorphisms?
Non-local diffeomorphisms have applications in the study of nonlinear systems, such as in physics and engineering. They can also be used in image processing and computer graphics, where they can be used to create interesting and complex transformations.
5. How are non-local diffeomorphisms related to chaos theory?
Non-local diffeomorphisms are often used to model chaotic systems, as they can result in complex and unpredictable behavior. In chaos theory, non-local diffeomorphisms are used to study the dynamics of systems that exhibit sensitive dependence on initial conditions, leading to chaotic behavior.
  • Differential Equations
  • Classical Physics
  • Differential Geometry
  • Atomic and Condensed Matter
