Support of Stochastic Variables: Math_Ninja
In summary, stochastic variables are mathematical quantities used to model random events and their outcomes. The support of a stochastic variable refers to the range of values it can take on and is important for proper modeling. Probability distributions are used to describe the likelihood of different values occurring and help quantify the randomness of the variable's outcomes. The support can be determined by examining the variable's definition, constraints, and context. It can also change over time depending on external factors.
Math_Ninja25
Hi
I have been working on understanding concept fra Measure Theory known as support or supp
I know that according to the definition
if [tex](\mathcal{X},\mathcal{T})[/tex] is a topological space and [tex](\mathcal{X},\mathcal{T}, \mu)[/tex] such that the sigma Algebra A contain all open sets [tex]U \in \mathcal{T}[/tex]. Then the support on a measure [tex]\mu[/tex] is defined as the set of all points [tex]x \in \mathcal{X} [/tex] for which every open neighbourhood of x has a positve measure
[tex]\mathrm{supp}(\mu) = \{x \in X| \forall z \in Z \in N_{x} \in \mathcal{T}, \mu(N_{x}) > 0 \} [/tex]
Can this definition be used on a discrete stohastic vector [tex](Y,Z)[/tex] with the distributionfunction [tex]p_{Y,Z}[/tex]
[tex]P(Y = y, Z = z) = p_{Y,Z}(Y,Z) = \left\{ \begin{array}{ll}\frac{1}{2} \cdot e^{-\lambda} \frac{\lambda^z}{z!} & \mbox{where \ \mathrm{y $\in \{-1,0,1\}$} \mathrm{and} \mathrm{z $\in \{0,1,\ldots\}$}} \\ 0 & \mbox{\mathrm{other.}}\end{array} }\right[/tex]
where [tex]\lambda > 0[/tex]
I need to determine supp [tex] P_{Y,Z}[/tex]
Then by the definition of supp then the non-negative mesure on a meassurable space (Y,Z), is the function
[tex]P: \rightarrow ]-1,1[ \ \mathrm{x} \ ]0,\infty [[/tex]
The supp is is it then the set of all subsets which the measure operates on?
Therefore the support [tex]supp \ p_{(Y,Z)} = supp(P) = \{y \in Y| \forall z \in Z , P(Y,Z) > 0\}[/tex]
Sincerely Yours
Math_Ninja
Dear Math_Ninja,
Thank you for your post. It seems like you are trying to understand the concept of support in measure theory and how it applies to a discrete stochastic vector with a given distribution function. Let me try to provide some clarification and help you with your question.
Firstly, the definition of support in measure theory is slightly different from the one you have provided. The correct definition is as follows:
Given a measurable space (X, Σ) and a measure μ on it, the support of μ is defined as the smallest closed set E such that μ(E^c) = 0, where E^c denotes the complement of E. In other words, the support of a measure is the set of all points where the measure is non-zero.
Now, to answer your question about whether this definition can be used on a discrete stochastic vector (Y, Z) with the given distribution function, the answer is yes. In this case, the measurable space would be the Cartesian product of the spaces of Y and Z, i.e. (Y x Z, Σ), where Σ is the sigma-algebra generated by the product of the sigma-algebras of Y and Z. The measure μ would be the distribution function p_{Y,Z}.
To determine the support of this measure, you would need to find the smallest closed set E such that p_{Y,Z}(E^c) = 0. In this case, the support would be the set of all (y,z) such that p_{Y,Z}(y,z) > 0. In other words, the support would be the set of all possible outcomes of the discrete stochastic vector (Y,Z) with non-zero probability.
I hope this helps. Let me know if you have any further questions or need any additional clarification.
Related to Support of Stochastic Variables: Math_Ninja
1. What are stochastic variables?
Stochastic variables are mathematical quantities that can take on different values with a certain probability. They are used to model random events and their outcomes.
2. How does the concept of support apply to stochastic variables?
The support of a stochastic variable refers to the range of values that the variable can take on. It is important to define the support in order to properly model and analyze the behavior of the variable.
3. What is the role of probability distributions in supporting stochastic variables?
Probability distributions are used to describe the likelihood of different values occurring for a stochastic variable. They provide a way to understand and quantify the randomness of the variable's outcomes.
4. How can we determine the support of a stochastic variable?
The support of a stochastic variable can be determined by examining the range of values that are possible for the variable based on its definition and any constraints or limitations. It is also important to consider the context in which the variable is being used.
5. Can the support of a stochastic variable change over time?
Yes, the support of a stochastic variable can change depending on the specific conditions and factors involved in the situation. For example, if the variable is affected by external factors such as weather or market conditions, its support may shift over time.
  • Classical Physics
  • Classical Physics
