Synthesis using synopsys design compiler
In summary, Synthesis using Synopsys Design Compiler is a process of converting high-level hardware description languages (HDL) into lower-level gate-level netlists for physical implementation. This tool works by analyzing and optimizing the code for performance, area, and power consumption. It offers benefits such as faster design iterations, better optimization, improved reliability, and easier integration of third-party IP blocks. However, it may not be suitable for designs with low power consumption or complex timing requirements. Resources such as online tutorials and user guides are available for learning how to use this tool, but a good understanding of digital design and HDL coding is also necessary.
hoheiho
47
Hi, I am trying to complie my counter (writen in system verilog) using synopsys design compiler. It comes out this error:
The expression in the reset condition of the 'if' statement in this 'always' block can only be a simple identifier or its negation. (ELAB-303)
*** Presto compilation terminated with 1 errors. ***
What factor may care this problem? what can i try to do?
Thank for the help
Perhaps you should post the code for your "always" block so we can see your error? :wink:
1. What is Synthesis using Synopsys Design Compiler?
Synthesis using Synopsys Design Compiler is a process in which high-level hardware description languages (HDL) such as Verilog or VHDL are converted into lower-level gate-level netlists that can be used for physical implementation.
2. How does Synthesis using Synopsys Design Compiler work?
Synthesis using Synopsys Design Compiler works by taking an HDL description of a digital design and translating it into a gate-level netlist. This involves analyzing the code and optimizing it for performance, area, and power consumption. The resulting netlist can then be used for place and route, which is the physical layout of the design on a chip.
3. What are the benefits of using Synthesis using Synopsys Design Compiler?
There are several benefits of using Synthesis using Synopsys Design Compiler, including faster design iterations, better optimization for performance and area, improved reliability, and reduced time-to-market. It also allows for easier integration of third-party IP blocks into a design.
4. Are there any limitations to using Synthesis using Synopsys Design Compiler?
While Synthesis using Synopsys Design Compiler is a powerful tool, it does have some limitations. For example, it may not be suitable for designs that require very low power consumption or designs with complex timing requirements. It also requires a good understanding of HDL coding and design principles to achieve optimal results.
5. How can I learn how to use Synthesis using Synopsys Design Compiler?
There are various resources available for learning how to use Synthesis using Synopsys Design Compiler, such as online tutorials, training courses, and user guides provided by Synopsys. It is also helpful to have a good understanding of digital design concepts and HDL coding before using this tool.
9K
  • Mechanical Engineering
  • Sticky
