Temperture And Kinetic Theory
In summary, the problem is to determine the common temperature at which a brass plug and an iron ring will have the same diameter, allowing the plug to fit inside the ring. This can be solved by equating the linear expansion equations for the two materials and solving for the change in temperature.
davidkis
A brass plug is to be placed in a ring made of iron. At room temperature (20°C), the diameter of the plug is 8.764 cm and that of the inside of the ring is 8.754 cm. They must both be brought to what common temperature in order to fit?
Change in V=B*V0*Change in T
B for brass = 56x10^-6
B for Iron = 35 x 10^-6
I had no idea how to start i notice that the change in the coefficent of expansion is going to change the items dimensions but i honestly don't know where to begin, do i combine the 2 separate formulas? how would i solve for the temperture?
Here you need not consider the volume expansion. Brass plug will pass through iron ring if their radii are the same.
Rb = Rb0( 1 + αb*Δt)
Ri = Ri0( 1 + αi*Δt)
where α is the coefficient of linear expansion which is equal to B/3.
Equate Rb and Ri and solve for Δt
I would approach this problem by considering the principles of temperature and kinetic theory. According to the kinetic theory of matter, the temperature of an object is related to the average kinetic energy of its particles. This means that as the temperature increases, the particles within the object will vibrate faster and take up more space.
In this problem, we are dealing with two materials, brass and iron, which have different coefficients of thermal expansion (B). This means that they will expand or contract at different rates when subjected to a change in temperature. In order for the brass plug and iron ring to fit together, they must have the same dimensions, which means they must be at the same temperature.
To solve for the common temperature at which they will fit, we can use the formula for change in volume (ΔV) as follows:
ΔV = B * V0 * ΔT
Where B is the coefficient of thermal expansion, V0 is the original volume, and ΔT is the change in temperature.
Since we want the final volume of the brass plug and iron ring to be the same, we can set their change in volumes equal to each other:
Bbrass * V0brass * ΔT = Biron * V0iron * ΔT
We can then rearrange the equation to solve for ΔT:
ΔT = (Biron * V0iron) / (Bbrass * V0brass)
Now, we know the values for B and V0 for both brass and iron, so we can plug them into the equation to solve for ΔT:
ΔT = (35 x 10^-6 * 8.754 cm) / (56 x 10^-6 * 8.764 cm)
ΔT = 5.39°C
Therefore, the brass plug and iron ring must both be brought to a temperature of 5.39°C in order to fit together. This is the common temperature that will result in the same change in volume for both materials.
1. What is temperature?
Temperature is a measure of the average kinetic energy of particles in a substance. It is usually measured in units of degrees Celsius (°C) or Kelvin (K).
2. How is temperature related to kinetic energy?
Temperature and kinetic energy are directly proportional - as temperature increases, so does the average kinetic energy of particles in a substance. This is because at higher temperatures, particles have more energy and move faster.
3. How does the kinetic theory explain the behavior of gases?
The kinetic theory of gases states that gases are made up of particles that are constantly moving and colliding with each other and the walls of their container. The theory also explains how changes in temperature and pressure affect the behavior of gases.
4. Can temperature affect the state of matter?
Yes, temperature can affect the state of matter. As a substance's temperature increases, the average kinetic energy of its particles increases, causing them to move more and become less tightly packed. This can cause a solid to melt into a liquid or a liquid to evaporate into a gas.
5. How is temperature measured?
Temperature is commonly measured using a thermometer, which contains a substance that expands or contracts in response to changes in temperature. The temperature is then read from a scale on the thermometer, such as Celsius or Fahrenheit.
