I The normalizing constant in a gamma distribution
  • I
  • Thread starter Thread starter Trollfaz
    Constant
The gamma distribution is defined with a normalizing constant, ##\Gamma(\alpha)##, ensuring the probability density function integrates to one over the interval from 0 to infinity. For integral values of ##\alpha##, it is derived that ##\Gamma(\alpha) = \frac{1}{(\alpha-1)!}##. The discussion raises questions about the gamma function's application for non-integral values of ##\alpha##, noting that it is an extension of the factorial function. The integral definition of the gamma function, ##\Gamma(z) = \int_0^\infty t^{z-1} e^{-t} dt##, applies for non-integral values as well. Resources such as tables and computer functions are available to obtain gamma values for various inputs.
Trollfaz
Wikipedia and some of my simpler statistics courses present the gamma distribution with shape ##\alpha## and rate ##\lambda## as
$$P(X=x)=x^{\alpha-1}\lambda^\alpha e^{-\lambda x} \Gamma(\alpha)$$
Where ##\Gamma(\alpha)## is a value in terms of alpha to normalize the PDF from the space of x from 0 to ##\infty## (i.e make it's integral in the space 1).
I have derived that for integral values of ##\alpha##,
$$\Gamma(\alpha)=\frac{1}{(\alpha-1)!}$$
But how about non integral values of alpha? How do I get the ##\Gamma## constant?
https://en.m.wikipedia.org/wiki/Gamma_distribution
Someone please help with the LaTex it's not working thanks
I think you derived that equation for Gamma wrong. It is a well known extension of the factorial: ##\Gamma(n)=(n-1)!## for positive integers ##n##, and in general, ##\Gamma(z)=\int_0^\infty t^{z-1}e^{-t} dt## for ##z## in the right half of the complex plane. (see https://en.wikipedia.org/wiki/Gamma_function )
There are tables and computer functions to get values.
Both your formula and mine results in the same final expression
$$P(X=x)=e^{-\lambda x}\lambda^n x^{n-1}/(n-1)!$$
But what if n is non integral or is it not possible for n to be non integral
By the integral definition @FactChecker gave you i post #3 or by the Wikipedia page about the Gamma function.
Here is a nice paper about the Gamma distribution:
https://ocw.mit.edu/courses/18-443-...924817d33e1ccb6f3a6b944c985d0cdb_lecture6.pdf
It directly starts with that definition.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
