How Does Temperature Affect Pendulum Clock Accuracy?
In summary: I'm still not sure what you're saying. Let me try to be really clear; here is the breakdown of the problem for the time period of the pendulum:1. First we are told that the pendulum's period is ##T = \Delta t_{true}##. This means that if you put a stopwatch next to the pendulum, the stopwatch will count off ##\Delta t_{true}## time while one cycle of the pendulum goes by.2. Next we are told that, for some reason, the pendulum's period is changed to ##T' = \Delta t_{measured}##. This means that if you put a stopwatch next to the pendulum, the stopwatch will count
Vibhor
971
40
Q. What is the time lost in time 't' by a pendulum clock whose actual time period is T and the changed time period at some higher temperature is T' ? (T' is Time period at some higher temperature , l' is the increased length , Δθ is the difference in temperature, α is coefficient of linear expansion)
T = ##2\pi \sqrt{\frac{l}{g}}##
Time period of a simple pendulum is given by T = ##2\pi \sqrt{\frac{l}{g}}## . As the tempertaure is increased , length of the pendulum and hence time period gets increased . the pendulum clock becomes slow and hence loses time .
If T' is Time period at some higher temperature , l' is the increased length , Δθ is the difference in temperature, α is coefficient of linear expansion .
##\frac{T'}{T} = \sqrt{\frac{l'}{l}}## = ## \sqrt{\frac{l+Δl}{l}}## = ## \sqrt{\frac{l+lαΔθ}{l}}## = ##(1+αΔθ)^{\frac{1}{2}}##
##T' ≈ T(1+\frac{1}{2} αΔθ)##
##ΔT = T'-T = \frac{1}{2} αΔθ##
Time lost/sec = ##\frac{ΔT}{T}##
Time lost in time 't' = ##\frac{ΔT}{T}t##
But the answer given is ##\frac{ΔT}{T'}t## . This is what I do not understand . When we calculate Time lost/sec , we should divide ΔT by T or ##T'## ( new/increased time period ) . I think it should be T , but according to the book it should be ##T'##
Please help me with the concept .
Many Thanks
I'm not sure why you considered the lengths, or the coefficients of expansion, or the change in temperature; none of those are known, so it's no use in considering them.
In fact, your relevant equation is not important either; even if it swung through large enough angles so that the small angle approximation failed, the answer would be the same. (It doesn't even matter if they are pendulums or another device.)
All that matters is, we have two clocks, both of which are calibrated such that T seconds pass on the clock per cycle of the pendulum. One clock's period really is T (hence it keeps time correctly) and the other clock's pendulum has a period of T'. Suppose a (true) time t goes by; the number of oscillations of the pendulums will then be t/T and t/T'. Thus one clock will say (t/T)*T = t has passed, and the other will say (t/T')*T has passed. The difference between the clocks is then t-t(T/T') = t(T'-T)/T'.
Likes Vibhor
Sorry . They are part of the problem . I will edit the question . It is a standard problem in thermal expansion chapter.
Oh. Well all of that information is a red herring (unless there are other parts to the question).
The problem is part of the theory as well as similar to a worked example given in the book . Could you have a relook at the OP ?
Ok, but as I said, all of that information is a red herring (none of it matters; it's a distraction to get you thinking about other things).
Have you understood the (second paragraph of) post #2? If you are still confused, can you better explain why you think it should be over T instead of over T' ?
Because it is the actual time period over which the pendulum has gained time . Whenever we are looking for fractional change in a quantity , the division is made by the true/original quantity . Isn't it ??
I don't understand what you're saying here.
Yeah, if we want the fractional change in something, then we do it that way. If the problem had said, "find the fractional change in the period" then the answer would be (T'-T)/T. That's not what it asked though. It is asking this: "after time t, how far off from the true time is the T'-clock?" You see, it's a more subtle question than just finding a fractional change.
(Paragraph 2 of post #2 has the precise explanation.)
Likes Vibhor
You (and the link) determined the relative error of time with the linear approximation. Then ##\frac {\Delta T}{T'}= \frac{0.5 \alpha \Delta \theta}{1+0.5 \alpha \Delta \theta}## which is the same as ##0.5 \alpha \Delta \theta## in the linear approximtion. It does not matter if you divide by T or by T'.
In principle, you see the beats of the clock, and assign the time to the number of beats. During t time, there are N=t/T' beats of the wrong clock, what you think is NT time. The time difference is( t/T')*T-t=T(T/T' - 1), as Nathanael has shown.
Likes Vibhor
Vibhor said:
Please have a look at the second response http://physics.stackexchange.com/qu...ffect-the-accuracy-of-grandmas-pendulum-clock . I guess the poster is doing the same thing . i.e dividing by ##T## .
To be clear, most of the work in that post is to find T' which we are given at once.
Towards the end, they did not explain their calculation of "##t_{day}##," but it does appear that they (effectively) used t(T'-T)/T instead of t(T'-T)/T'. I say they are wrong in doing that (although to the accuracy involved in that thread it changes nothing).
Vibhor said:
I still do not understand what is the mistake with my reasoning :rolleyes: .
Well I don't understand your reasoning in the first place so I'm not sure how to help. If you have another way of explaining your reasoning, please do.
You calculated the relative increase of time elapsed during one period of the pendulum to the time of one period of a punctual pendulum.
But the time shown by the clock was the question. It is less then the real time.
Likes Vibhor and Nathanael
This is the key issue . I was not paying enough attention to how the clock works . The number of oscillations in the incorrect clock is multiplied by the correct time period T to get how much time has elapsed as per the incorrect clock . Please correct me if I am wrong.
Thank you very much :smile: .
Spot on :smile:
Thanks !
@ehild ,@Nathanael Please see the attached image . It has a worked out example from the textbook dealing with the same concept . I think it is quite misleading in light of the discussion we had in this thread . The author is using the same approach as in the OP i.e fractional loss of time .
But interestingly ,the answer comes out to be same using both the approaches , the flawed as in the OP and the correct approach as in post#2 .
Exactly. :smile:
Vibhor said:
Even here https://www.physicsforums.com/threads/thermal-expansion-pendulum-of-a-grandfather-clock.334006/ the experts are approaching on similar lines as in OP .
You are absolutely right, they are all doing it wrong! I guess it's quite a prevalent misconception! Note though, that although they are theoretically wrong, the answers involved are virtually the same either way. This is because T and T' are so close to each other (which in turn is because thermal expansion is so minuscule).
You can see, algebraically, to get from their answer to ours, you must multiply by T/T'. In your textbook's example, this factor is 0.99988, which is very nearly 1 (hence why it seems to give the same answer).
If T and T' were not so nearly the same, though, then their answers would be off by more than that.
Thanks for bringing those examples up, as I did not realize how common that misunderstanding is...
No one seems to pay attention to the finer details!
Likes Vibhor
I join to Nathanael's opinion.
Likes Vibhor
1. Why does a pendulum lose time over time?
The primary reason for a pendulum losing time over time is due to the effects of friction and air resistance. These external forces cause the pendulum to slow down gradually, leading to a decrease in its amplitude and period.
2. Does the length of a pendulum affect its timekeeping?
Yes, the length of a pendulum has a direct impact on its timekeeping. According to the laws of physics, the longer the pendulum's length, the longer its period will be. This means that a longer pendulum will take more time to complete one swing, resulting in slower timekeeping.
3. Can temperature affect a pendulum's timekeeping?
Yes, temperature can affect a pendulum's timekeeping. Changes in temperature can cause the length of the pendulum's string to expand or contract, altering its period. This is why pendulum clocks need to be adjusted for changes in temperature to maintain accurate timekeeping.
4. Why do pendulums have different timekeeping depending on their location on Earth?
The Earth's gravitational pull varies slightly in different locations, which can affect the timekeeping of a pendulum. In areas with a higher gravitational pull, the pendulum will swing slightly faster, while in areas with a lower gravitational pull, it will swing slightly slower.
5. Can the mass of a pendulum affect its timekeeping?
Yes, the mass of a pendulum can affect its timekeeping. According to the law of inertia, objects with a greater mass require more force to move and change direction. This means that a heavier pendulum will take more time to complete one swing, resulting in slower timekeeping.
