spark802
- 47
- 12
Hi folks I shot about 260 frames on the March 17 Aurora event...iso 1600, f/4.5, Cano 550D, exp times are 12 sec for first half of movie then bumped them up to 30 secs. Imaged from a few miles north of Winnipeg, Canada.
A timelapse of Aurora Borealis is a series of images or videos taken over a period of time and then played back at a faster rate, creating the illusion of a sped-up passage of time. In this case, it captures the natural phenomenon of the Aurora Borealis, also known as the Northern Lights, which is caused by charged particles from the sun interacting with the Earth's atmosphere.
The best place to see a timelapse of Aurora Borealis is in the high latitudes of the Northern Hemisphere, particularly in countries such as Canada, Norway, Sweden, Finland, and Iceland. These locations are closer to the Earth's magnetic poles where the effects of the charged particles are more concentrated and visible.
The length of a timelapse of Aurora Borealis can vary depending on the duration of the images or videos used, but it typically ranges from a few seconds to a few minutes. The actual event of Aurora Borealis can last for several hours, but it may not be visible to the naked eye for the entire duration.
To capture a timelapse of Aurora Borealis, you will need a camera with manual settings, a tripod to keep the camera stable, and a wide-angle lens to capture a larger area of the sky. It is also recommended to use a remote shutter release or intervalometer to avoid camera shake and ensure consistent intervals between shots.
Yes, here are a few tips for capturing a timelapse of Aurora Borealis:
- Find a dark location away from city lights to reduce light pollution.
- Check the weather forecast for clear skies and a high chance of Aurora activity.
- Use a high ISO setting and a wide aperture (low f-stop) to capture more light.
- Experiment with different shutter speeds to capture movement and details of the Aurora.
- Be patient and enjoy the experience, as the Aurora can be unpredictable and may not always appear as expected.
