Trigonometric substitution integrals
In summary, the appropriate trigonometric substitution for the first integral is 7(x^2 - tan^2(\theta))^{3/2}, and for the second integral is \frac{\sqrt(8)tan(t)}{\sqrt(7)}. The first integral can be simplified to 7x^3 - 7tan^3(\theta), and the second integral can be simplified to \frac{\sqrt(8)tan(t)}{\sqrt(7)}.
CellCoree
1,490
what would be the appropriate trigonometic substition for the following:
1.) [tex]\int(7x^2-7)^{3/2}) dx [/tex]
2.) [tex] \int \frac{x^2}{\sqrt{(7x^2 + 8)}} [/tex]
ok i have a book with a list of trigonometric functions in front of me, but i don't get it. i don't see anything that i can sub in for.
ok i kinda get the first one...
[tex]7(x^2-1)^{3/2}[/tex]
[tex]sin^2(\theta) + cos^2(\theta) = 1/[/tex] so...
divided by [tex]cos^2(\theta)[/tex] and get [tex]tan^2(\theta)[/tex]
[tex]7(x^2 - tan^2(\theta))^{3/2}[/tex]
[tex]7(x^3 - tan^3(\theta))[/tex]
[tex]7x^3 - 7tan^3(\theta)[/tex]
[tex]7x^3=7tan^3(\theta)[/tex]
divide by 7... (lol, don't think i can do this)
[tex]x^3 = tan^3(\theta)[/tex]
cube root...
[tex]x= tan(\theta)[/tex] is that right?
lol, thanks. i just made a dumb mistake
ok this one is a bit hard...i been thinking about this one for awhile.
can i do [tex] \int \frac{x^2}{\sqrt{(7x^2 + 7 + 1)}} [/tex]
[tex]sin^2(\theta) + cos^2(\theta) = 1[/tex] so...
well i know it's [tex]sec^2(\theta)[/tex] from solving the previous problem
[tex] \int \frac{x^2}{\sqrt{(7x^2 + 7 + sec^2(\theta))}} [/tex]
[tex] \int \frac{x^2}{\sqrt{7(x^2 + 1 + sec^2(\theta))}} [/tex]
agian, there's another 1! so i use [tex]sec^2(\theta)[/tex]
(just working with the bottom part now)
[tex] \sqrt{7(x^2 + sec^2(\theta) + sec^2(\theta)[/tex]
if i squared 7, it would be a mess, can someone help?
You might want to review trigonometric substitution in your textbook.
Check what are you doing again, it seems a bit... mixed up...
Here's a hint
[tex] \sqrt{7}x = \sqrt{8}tan\theta [/tex]
so you should have
[tex] \sqrt{7x^2 + 8} = \sqrt{8}sec\theta [/tex]
i get it now! thanks.
the trig. sub. should be:
[tex]\frac{\sqrt(8)tan(t)}{\sqrt(7)}[/tex]
Related to Trigonometric substitution integrals
What is trigonometric substitution?
Trigonometric substitution is a method used to solve integrals involving expressions with trigonometric functions. It involves replacing the variable in the integral with a trigonometric function, making the integral more manageable to solve.
When should trigonometric substitution be used?
Trigonometric substitution should be used when the integral involves a radical expression, especially if it also contains a quadratic expression. This method is also useful for integrating rational functions containing sine and cosine terms.
What are the common trigonometric substitutions?
The three most common trigonometric substitutions are:
  • For integrals involving √(a2-x2), use the substitution x = a sinθ
  • For integrals involving √(a2+x2), use the substitution x = a tanθ
  • For integrals involving √(x2-a2), use the substitution x = a secθ
What are the steps for using trigonometric substitution?
The general steps for using trigonometric substitution are:
  1. Identify the appropriate substitution to use based on the integral's expression.
  2. Carry out the substitution, replacing the variable in the integral with the trigonometric function.
  3. Use trigonometric identities to rewrite the integral in terms of the new variable.
  4. Solve the new integral using standard integration techniques.
  5. Substitute the original variable back into the solution.
What are some common mistakes to avoid when using trigonometric substitution?
Some common mistakes to avoid when using trigonometric substitution include:
  • Forgetting to substitute the original variable back into the solution.
  • Incorrectly applying trigonometric identities when rewriting the integral.
  • Using the wrong substitution for the given integral.
  • Not checking for extraneous solutions when solving the new integral.
  • Forgetting to include the appropriate constants when substituting back into the solution.
