Can Trigonometric Functions Nested Within Other Functions Be Integrated?
In summary: You are confusing summation with addition. The second summation should be inside of the first, not simply multiplying the...The second summation should be inside of the first, not simply multiplying the...\int_a^b \sin(\cos x) dx = \left(\sum_{n=0}^\infty \frac{(-1)^n}{(2n+1)!} \right) \left( \sum_{n=0}^\infty \frac{(-1)^n}{(2n)!} x^{2n} \right)^{2n + 1}The second summation should be inside of the first, not simply multiplying the...
Orion1
973
Is it possible to integrate a trigonometry function within a function, or is this a formula that cannot be integrated in terms of elementary functions?
[tex]\int \sin(\cos x) dx[/tex]
It cannot be integrated in terms of elementary functions.
just to clear up
If sin(x)=y and arcsin(y)=x , why can sin(arcsiny) not be integrated with elementary function? It is equivalent to integrating sin(x) which is -cosx + C, correct? So why is sin(cosx) any different, does this not apply to inverse trig functions?
Actually sin(arcsin(y)) = y in the interval from -pi/2 to pi/2, and so in that interval it would be equivalent to integrating y which would be y2/2 + C. sin(cos(x)) is a very different stroy however, and as has already been stated in this thread cannot be integrated in terms of elementary functions.
integral of sin(cos(x)) well i have a fancy calculator that says...
Error. Sorry, Wcalc is unable to complete your requested computation. Please verify your data.
I take that as a no-no.
Is it possible to solve the area under the curve using the Riemann sum?
[tex]\int_a^b f(x) dx = \lim_{n \rightarrow \infty} \sum_{k=1}^n f(x_k) \Delta x_k[/tex]
[tex]\int_a^b \sin(\cos x) dx = \lim_{n \rightarrow \infty} \sum_{k=1}^n \sin(\cos x_k) \Delta x_k[/tex]
If by solve you mean 'numerically approximate' then obviously the answer is yes. The function is continuous and Riemann integrable. If you mean is it possible to find the exact answer in some explicit form (where explicit is to be determined by your own opinion) between any two limits then the answer is 'no, not for all a and b under most definitions of explicit.'
Here is the theorem that I developed for any trig function within a function:
[tex]\int u[v(x)] dx = u [ \int v(x) dx ] + C[/tex]
[tex]\int \sin (\cos x) dx = \sin [ \int \cos x \; dx ] = \sin (\sin x) + C[/tex]
[tex]\int_a^b u[v(x)] dx = u [ \int v(x) dx ]_b - u [ \int v(x) dx ]_a[/tex]
[tex]\int_a^b \sin (\cos x) dx = \sin (\sin b) - \sin (\sin a)[/tex]
It doesn't bother you the least that what you've written is totally wrong?
It might be better if you don't call this a theorem. Try a few examples where u and v are polynomials and you should see how very, very wrong this is.
I retract my term 'theorem', perhaps I should have used the term pseudo-developmental philosophy...
Please post a graph of what F(x) appears like versus f(x)?
[tex]f(x) = \sin(\cos x)[/tex]
[tex]\int \sin(\cos x) dx = F(x) + C[/tex]
I would post my graphs for f(x) = Sin (Cos x) and F(x) = Sin (Sin x), however these functions have been refuted here.
The graph for F(x) can be drawn or graphed manually, can it not?
In blue, f(x); in green, a possible F(x) with c taken 0.
http://img132.imageshack.us/img132/1402/intle6.jpg"
What do you mean by "refuted"? Did you read Matt Grimes post? Perhaps if you did not understand it you should make an effort to. What is means is that your function is fine, and an integral exists. But as others have said the integral cannot be expressed in terms of elementary functions.
Consider this for small x; Sin(x) = x. Now look at the first terms of Taylor series expansion of cos(x):
Cos(x) ~ x + (x^2)/2 + ...
You can see that your function will differ from Sin(x) only in when Cos(x) is large. These functions can easily be plotted and it indeed tracks sin(x) very nicely except that the maximum values.
Now again Where do you see that anyone has "refuted" these functions?
If by Cos(x) ~ x you mean Cos(x) ~ 1, then sure.
Orion, this is wrong:
[tex]\sin (\cos x) = \left(\sum_{n=0}^\infty \frac{(-1)^n}{(2n+1)!} \right) \left( \sum_{n=0}^\infty \frac{(-1)^n}{(2n)!} x^{2n} \right)^{2n + 1}[/tex]
The second summation should be inside of the first, not simply multiplying the first.
[tex]\sin x = \sum_{n=0}^\infty \frac{(-1)^n}{(2n+1)!} x^{2n + 1}[/tex]
[tex]\cos x = \sum_{n=0}^\infty \frac{(-1)^n}{(2n)!} x^{2n}[/tex]
[tex]\sin (\cos x) = \sum_{n=0}^\infty \frac{(-1)^n}{(2n+1)!} \left( \sum_{n=0}^\infty \frac{(-1)^n}{(2n)!} x^{2n} \right)^{2n + 1}[/tex]
[tex]\int \sin ( \cos x) dx = \int \sum_{n=0}^\infty \frac{(-1)^n}{(2n+1)!} \left( \sum_{n=0}^\infty \frac{(-1)^n}{(2n)!} x^{2n} \right)^{2n + 1} dx[/tex]
[Color = Blue]
Would it require a full page of proof in order to prove this equation?
[/Color]
Reference:
http://en.wikipedia.org/wiki/Taylor_series
To prove what? You've just replaced the trig functions with their Taylor's series. What is there to prove? Of course, you still haven't done the integral which was the whole point. Now, if you had moved the integral inside the sums, that would have been something to prove- but you wouldn't need a whole sum- just note that power series converge uniformly inside their radius of convergence and that the power series for sine and cosine have infinite radius of convergence.
Stop using the same letter for all summation indices.
integration
hi, I am new here, can i ask how 2 integrate "tan x"
Welcome to PF
[tex]\int {\tan x\,dx} = \int {\frac{{\sin x}}
{{\cos x}}\,dx} = - \int {\frac{{d\left( {\cos x} \right)}}
{{\cos x}}} = - \log \left| {\cos x} \right| + C = \log \left| {\sec x} \right| + C[/tex]
Generally, such questions belong in this subforum :)
thx alot.haha..i took me a while, i juz nid to check...
Perhaps "something I just made up" would have been a better term!
Related to Can Trigonometric Functions Nested Within Other Functions Be Integrated?
1. What is trigonometric integration?
Trigonometric integration is the process of finding the integral of a function that contains trigonometric functions, such as sine, cosine, or tangent.
2. Why is trigonometric integration important?
Trigonometric integration is important in many areas of mathematics, physics, and engineering. It allows us to solve complex problems involving periodic functions and is essential in calculating areas, volumes, and other physical quantities.
3. How do you integrate trigonometric functions?
The integration of trigonometric functions follows specific rules and techniques, such as using trigonometric identities, substitution, and integration by parts. It also requires a good understanding of basic calculus concepts like derivatives and antiderivatives.
4. What are some common applications of trigonometric integration?
Trigonometric integration has various applications in fields such as engineering, physics, and mathematics. Some common examples include calculating the period and frequency of oscillating systems, determining the displacement and velocity of a particle undergoing circular motion, and finding the center of mass of a rotating object.
5. Are there any tips for solving trigonometric integration problems?
Some useful tips for solving trigonometric integration problems include identifying the appropriate trigonometric identities to simplify the integrand, using trigonometric substitution to transform the integral into a more manageable form, and practicing regularly to improve problem-solving skills.
  • Calculus
  • Calculus
