Trouble understanding g-forces
  • Thread starter flumbie
  • Tags
    G-forces
In summary: So, if you're slowing at 32 ft/sec^2 for 5 seconds, you've experienced a "5 negative gee" forceIn summary, g-forces are a unit of measurement for acceleration, with 1 g being equal to 9.8 meters per second squared. This includes forces like force normal and applies to all directions of acceleration. In aviation, g-forces are often described in relation to the human body, with "positive g's" being acceleration towards the feet and "negative g's" being deceleration. In summary, understanding g-forces involves understanding how they are measured and how they affect the human body in different situations.
flumbie
Im having a bit of trouble understanding g-forces. I get that you divide the forces acting upon an object by 9.8 to obtain the number of g's but does that include forces like force normal? I am also having trouble applying them in situations when acceleration is in different directions such as diagonals. can anyone help explain them for me?
thanks
Edit: I need help with the g-forces experienced from decelerating too
g-force is just a term to describe the force required to generate 1 g of acceleration on an object. 1 g of acceleration is defined to be 32.174 feet / sec^2, or 9.80665 meters / sec^2. Note that this takes into account that the Earth is rotating, isn't perfectly spherical, and assumes the object is at sea level (average tide height) and at 45.5 degrees latitude.
The direction of the force doesn't matter, it's just a way of stating an accelerating force compared to the defined acceleration of gravity. In a Formula 1 race car, the cars generate downforce equal to their weight around 115mph, this could be considered "1 g" of downforce. At around 160mph, the cars can pull "4 g" turns. There's also about "1 g" of drag force at 160mph, so just lifting the throttle produces "1 g" of braking force, and with full application of the brakes, "5 g's" of iniital braking deceleration (while still close to 160mph).
Take away the Earth's rotation and assume it to be spherical, and g force increases to about 32.224 feet / sec^2 or 9.822 meters / sec^2. This definition of g-force is the base value used for space craft, (reduced by R/(A+R)^2, where R is the average radius of the earth, and A is altitude) since they move indepedently of Earth's rotation, and are not significantly affected by the non-spherical shape.
A simpler, but less detailed, way to answer this:
"G's" are just a unit of measurement of acceleration. Just like meters per second squared, or MPH per second, or any other acceleration unit. 1 g = 9.8 m/s/s = 22 MPH/s.
"G-force" is not a special quantity. It just means "acceleration in units of g's". That's all.
flumbie said:
Im also having trouble applying them in situations when acceleration is in different directions such as diagonals. can anyone help explain them for me?
I'm not sure if this will help, but pilots usually refer to g-force in relation to their bodies. 2 g's 'eyeballs-in', for instance, would mean a straight line acceleration (in seated position) of 2 gravities. 4 g's 'eyeballs-down' would mean entering a hard climb. It's based upon the idea that the eyeballs are somewhat free-floating in the skull and lag behind the rest of the body. (Sort of like how Wile E. Coyote's ears always hang around for a second after he falls off of a cliff.)
Those are simply referred to as 'negative-gees'. One negative means that you're slowing at a rate of 32ft/sec^2.
Related to Trouble understanding g-forces
1. What are g-forces and how do they affect the body?
G-forces, or gravitational forces, are a measurement of the amount of force an object experiences due to gravity. When an object is accelerating or decelerating, it experiences a change in g-forces, which can cause physiological effects on the body such as loss of consciousness, blurred vision, and difficulty breathing.
2. How do g-forces differ in different situations, such as on Earth and in space?
G-forces are dependent on the strength of gravity, so they will differ based on the gravitational pull of the object or environment. On Earth, the average g-force experienced is 1g, while in space, g-forces can vary depending on the acceleration of the spacecraft. For example, astronauts may experience higher g-forces during takeoff and reentry.
3. Can g-forces be harmful to the body?
Yes, high g-forces can have a negative impact on the body. In extreme cases, high g-forces can lead to injuries such as broken bones and internal organ damage. The body's response to g-forces can also cause temporary or permanent physical changes, such as vision impairment or vertigo.
4. How do pilots and astronauts train to withstand high g-forces?
Pilots and astronauts undergo specialized training to learn how to withstand and mitigate the effects of high g-forces. This includes practicing breathing techniques, wearing specialized equipment such as G-suits, and building up their endurance through physical training.
5. Are there any safety measures in place to protect against high g-forces during travel?
Yes, there are safety measures in place to protect against high g-forces during travel. For example, aircraft and spacecraft are designed with safety features such as reinforced structures and seats to help cushion and protect passengers from the effects of g-forces. Pilots and astronauts also undergo thorough medical screening to ensure they are physically capable of withstanding high g-forces.
  • Other Physics Topics
12K
  • Aerospace Engineering
