Two masses, two pulleys and an inclined plane
The discussion revolves around a physics problem involving two masses, pulleys, and an inclined plane, focusing on the dynamics of a block sliding up the incline and the corresponding forces at play. Participants analyze the forces acting on both blocks, derive equations of motion, and address potential errors in their calculations, particularly concerning the signs of acceleration and tension. The relationship between the accelerations of the two blocks is established, with one block moving half the distance of the other due to the constraints of the string. Additionally, participants explore the conditions for the blocks to just barely slide up or down the incline, leading to further calculations for minimum and maximum mass values. The conversation emphasizes the importance of clearly defining coordinate systems and understanding the implications of constant acceleration in such problems.
Valerion
A block of mass m1 is at rest on an inclined plane that makes an angle (theta) with the horizontal. The coefficient of static friction between the block and the inclined planed is µs. A massless, inextensible string is attached to one end of the block, passes over a fixed pulley, pulley 1, around a second freely suspended pulley, pulley 2, and is finally attached to a fixed support. The pulleys are massless, but a second block of mass m2 is hung from the suspended pulley. Gravity acts downwards.
Now assume that the block on the incline plane is sliding up the plane. The coefficient of kinetic friction is µk. Find the magnitude of the acceleration of the block on the inclined plane a_x1 Express your answer in terms of some or all of the variables m1, m2, theta, µk and g
[/B]
F = ma
[/B]
I choose coordinate systems. For block 1 I chose the positive X axis downward along the surface of the inclined plane and the positive Y axis up, perpendicular to the surface of the inclined plane with the x origin at the top of the incline. For block 2 I chose the positive Y-direction downwards with the origin at the ceiling.
I made free-body diagrams of both block 1, 2 and the suspended pulley which gave me the following equations:
I can treat the suspended pulley and block 2 as one system because the length between them is constant so they move with the same acceleration a_2
-T + µ_k m_1 gcos(theta) + m_1 gsin(theta) = m_1 a_x1
N = m_1 gcos(theta)
-2T + m_2 g = m_2 a_2
The length of the cord connecting block 1 with the ceiling is constant. So after taking two derivatives of the length. I get the relation between a_x1 and a_2 which is a_1 = -2a_2
T = ((m_2*g- m_2*a_2)/2 )
T = µ_k*m_1*g*cos(theta) + m_1*g*sin(theta) - m_1*a_1
((m_2*g-m_2*a_2 /2 ) = µ_k*m_1*g*cos(theta) + m_1*g*sin(theta) - m_1*a_1
2*(µ_k*m_1*g*cos(theta) + m_1*gsin(theta) - m_1*a_1 = (m_2*g-m_2*a_2)
2*(µ_k*m_1*g*cos(theta) + m_1*g*sin(theta)) - m_2*g = -m_2*a_2 + 2*m_1*a_1
substitute a_1 / -2 for a_2 and factor a_1 out
2*(µ_k*m_1*g*cos(theta) + m_1*g*sin(theta)) -m_2*g = (m_2/2 + 2*m_1) * a_1
a_1 = (2*(µ_k*m_1*g*cos(theta) + m_1*g*sin(theta))-m_2*g ) / (m_2/2 + 2*m_1)
For some reason this answer is not correct and I have been looking for that reason for several hours but I can't seem to find it. I think its a math error rather than a physics error. Can someone help me out?
Looks like you have signage errors. You have one block moving down the plane and the other hanging block moving downward. If the hanging block moves down the other moves up the plane, as stated. Acceleration of each block is in the direction of the net force.
So the acceleration of block 1 has a negative sign and the acceleration of block 2 has a positive sign. Then,
-T + µ_k m_1 gcos(theta) + m_1 gsin(theta) = m_1 a_x1 should be -T + µ_k m_1 gcos(theta) + m_1 gsin(theta) = - m_1*a_x1 ?
Ok, I think I got it. a_1 = (2*(µ_k*m_1*g*cos(theta) + m_1*g*sin(theta))-m_2*g ) / (-m_2/2 - 2*m_1)
Yes that looks correct. I find it easier to assume the positive direction in the direction of the acceleration, positive up incline for m1 and positive down for m2. Helps a bit with signage errors
Thank you for your help!
You're welcome.
Hi. Has anyone made parts (a) and (b)?
(a) What is m2,min, the minimum value of m2 for which block 1 just barely slides up
the incline? Express your answers in terms of some or all of the variables m1, θ,
µs and g.
(b) What is m2,max, the maximum value of m2 for which block 1 just barely slides
down the incline? Express your answers in terms of some or all of the variables
m1, θ, µs and g.
I got m_2_max/min = 2*m_1*(sin(θ) +- µ_s*cos(θ)).
µs and g.
m1, θ, µs and g.
Good.
PhanthomJay said:
Yes , and a2 is one half of a1.
Is ##a_2= \dfrac {a_1} {2}## because mass ##m_2## moves half the distance that mass ##m_1## moves in the same interval?
@vcsharp2003 that can be explained using "constrained motion", making use of the fact that the string is inextensible, so its length is constant. Writing the string's length in terms of motion functions of the objects and other constants, we get the identity. Would you like me to post the actual proof so you can understand better?
Likes vcsharp2003
Yes, please.
I think I got it as shown below.
In analysis below, ##l_1##, ##l_2##, ##l_3## are instantaneous lengths of respective sections of the string, while
##a_1##, ##a_2## are the instantaneous accelerations of masses ##m_1## and
##m_2##.
I am not very clear why I wrote ##\dfrac {d^2l_1} {dt^2} = -a_1##. I know that ##l_1## is decreasing with time and so ##\dfrac {dl_1} {dt}## is negative.
Because you are measuring a1 as positive up the slope but the distance of that mass from the pulley, l1, as positive down the slope.
Likes vcsharp2003
You mean the origin of the axis for the ##l_1## axis is at top pulley and I have assumed ##l_1## to be positive so the positive direction of axis is pointing down along the plane?
vcsharp2003 said:
You mean the origin of the axis for the ##l_1## axis is at top pulley and I have assumed ##l_1## to be positive so the positive direction of axis is pointing down along the plane?https://www.physicsforums.com/attachments/288104
I mean because an increasing value of l1 would mean the mass is sliding down, so implicitly you are measuring the displacement of the mass from the pulley as positive down the plane.
Likes vcsharp2003
I see.
I think it's very important to define the axis with origin and direction when analysing kinematic situations else signs can get messed up.
From the differential analysis we get the relationship between instantaneous accelerations ##a_1## and ##a_2##, but why would we assume that these instantaneous accelerations are constant with time i.e. uniform?
In which equation are you making that assumption?
When applying Newton's second law to each of the masses.
We are treating acceleration of each mass as constant else we would end with acceleration as a function of time.
Or maybe we apply Newton's second law to instantaneous values of forces and acceleration and after we solve the simultaneous equations it turns out that tensions and accelerations are pure numbers and not a function of time.
##m_2##.
You are on the right track, to some extent. When tackling constrained motion problems, it is very important to clearly define coordinate axis for each object, as things can easily overcomplicate. Take a look, for example, at the system of pulleys I have attached, and think of how you would solve it.
In my approach I have chosen for object 1 an axis with origin at distance d away from pulley 1, and for object 2 an axis that is at height h below the ceiling. I denoted the small string between pulley 2 and object 2 with s. When considering the length of the string I have not neglected the part wrapped around the pulleys, which is also constant.
These steps are not necessary here, however in the future treating everything carefully will bring you benefits.
Good luck.
Likes vcsharp2003
No, that law does not assume constant acceleration. It relates the net force at some instant to the resulting acceleration at that instant.
It will turn out that the accelerations are constant here because all the masses are constant and the forces will be proportional to the weight of the suspended mass.
Likes vcsharp2003
When we write F=ma, we do not "assume" constant acceleration, but why we answer the question "what is the acceleration?". Here, because the forces are not time dependent, the acceleration also turns out to be constant. However there are applications where the forces are for example velocity dependent (drag forces) or x dependent (mass spring system) and will require solving a differential equation.
Likes vcsharp2003
We can say that gravity forces are time independent but how can we say that tesion T is time independent?
Since pulley mass problems always end up with constant accelerations, can we safely assume before diving into solving it that accelerations are constant?
The question that you are asking is a bit complicated.
First of all, in this problem the strings are considered massless and firctionless when wrapping around a pulley. Assume a piece of the string, denote its ends with A (left) and B (right). The forces acting on it are Ta (tension in point A oriented to the left) and Tb (tension in point B oriented to the right). Applying F=ma : Tb - Ta = ma. But m ~ 0 so Tb - Ta = 0, yielding Tb = Ta, for any piece of the string. The conclusion is that the tension is uniform in the string.
For a massive spring, the tension can be computed distance dependent, using differential analysis.
Now we only have to worry for the tension at the extreme points / where the string links to another object. Tension can be "extracted" from writing F=ma for the motion of each moving object: mass 1, mass 2 and pulley 2. You will end up with a system with 4 equations and 4 unknowns: T (tension in main string), T' (tension in little string), a1, a2. Solving for T will prove that it is constant, and it is a good exercise to try out.
Is the pulleys masses diagram a part of some question? It looks like a challenging problem and worth trying/learning from it.
We assume the positive direction of vertical axis to point downwards and origin to be at center of pulley P when looking at the masses 2 and 3.
If the mass 1 on left side moves down by x units then the pulley P will also move up by x units. Therefore, mass 1 and pulley P have same accelerations.
Regarding masses 2 and 3, it gets challenging. Let's say the mass 3 moves up by z units relative to pulley P, then mass 2 will move down by z units relative to pulley P. So relative to ground, mass 3 will move up by x + z units and mass 2 will move down or up by z- x or x- z units. So masses 2 and masses 3 will also not same accelerations as distances traveled by them are different in a certain time interval. We would therefore end up with 3 different accelerations as unknowns in this situation.
The solution is as shown below. Once we have ##a_1##, then by substitution in other equations we can determine ##a_2## and ##a_3##.
Yes, the system is from an MIT problem. If you are interested, I have a very good resource of problems and explanations from an MIT OCW.
The first 4 equations are OK, but the 5th one is RIP. We cannot consider the acceleration of a system of objects, only if we consider that to be a non-inertial frame and consider the fictitious force, which messes up the problem in this case.
I have attached a PDF with the full solution.
Likes vcsharp2003
I think that the equation (5) is ok because we have the system of pulley and the hanging masses in black box move up with acceleration ##a_1## relative to ground. Is that correct? The acceleration of internal parts of this system is not needed but just the acceleration of whole system.
  • #31
Yes, I am interested.
  • #32
I understand your intuitive logic, but here's the thing.
Whenever you have objects that are considered massless (pulleys / strings), avoid grouping them into systems of objects, because you risk getting such contradictions. In this case it's the fault of pulley P which you have to treat separately, because it's massless. When you group it with other objects, you jump over using this fact. You can compare it to dividing by x in an inequality, but you don't know if x is positive or not, and you dilute that information and you get to something wrong.
As you can see, according to equation (8.6.69) (which I also arrived to when solving the problem), the final answer is not conclusive with yours.
This is mainly the problem with "ideal physics" where you have to make some assumptions, because otherwise it will be insanely hard to treat everything (ignore mass and friction for rope/pulley, ignore drag force in air falling, consider uniform density, sin x = x for the pendulum, also known as fundamental theorem of engineering). And when you make such assumptions sometimes they turn against you. Hope you understand it.
  • #35
I was comparing it to a plane that is moving on the runway. Passengers inside could be walking relative to the plane, but Newton's second law could be applied to the plane using the total mass of passengers and plane as the m term in F=ma equation.
  • #36
I know perfectly what you're talking about, but here it simply doesn't work and I kinda told you why.
The problem wouldn't be called challenging if it were that easy.
  • #37
I think if we take a system of multiple parts then the a in F = ma needs to be the acceleration of the center of mass. In the application I did, I took the acceleration of the pulley P when it should have been the acceleration of the center of mass of P and moving masses 2 and 3. That's why my application of Newton's second law to the system was incorrect. Right?
  • #38
Yes I think you are right here, I didn't think of the center of mass thing. Personally I avoid grouping objects because I think it's safer to take care of each object in particular.
Likes vcsharp2003
  • #39
If the parts of a system are at rest relative to each other then the acceleration of any part is also the acceleration of the center of mass of this system and then it's valid to apply F= ma with "m" being total mass of system and "a" being acceleration of any part of the system.
  • #40
Another way of solving this challenging problem could be to convert the non-inertial frame of reference to an inertial frame of reference.
In this case the pulley P is a non-inertial frame of reference and we can apply a pseudo force on masses ##m_2## and ##m_3## in a downward direction if pulley P is assumed to accelerate upwards. By doing this the accelerations of masses ##m_2## and ##m_3## will be as if the pulley P was fixed (not moving up or down) i.e. the masses will have same accelerations in magnitude but in opposite directions like in a typical Atwood machine.
  • #41
In post #10, @haruspex confirms the answers to parts A and B and that is also what I got, however, when it comes to part C (the OP's original question), I get something completely different and I'm unsure why.
I used T=(g*m_2)/2 for parts A and B and got them right, I also used them on Part C but according to OP, I can't use that on part C and rather should use T = ((m_2*g- m_2*a_2)/2 )... Why?
Edit: Here's Part C for clarification:
Now assume that the block on the incline plane is sliding upward. The coefficient of kinetic friction between the block and the incline surface is µk. Find the magnitude of the acceleration of the block on the inclined plane, a1. Express your answers in terms of some or all of the variables m1, m2, θ, µk and the acceleration of gravity g.
  • #42
Draw a FBD for m2. What are the forces on it? What equation does that give for its acceleration?
  • #43
I get that if I were to go the F=ma route and set the Forces to find the T I'd get F=ma such that m_2*g-2T=ma_2 so that T=((ma_2-m_2*g)/2).
I guess better worded my question would be: why am I setting 2T equal to m_2*g in parts A and B whereas I'm tying in the component of acceleration to the equation in Part C?
  • #44
Look at the FBDs below for part (c) where ##m_1## is moving up the incline and ##m_2## is descending.
  1. What is Newton's second law in the direction along the incline for ##m_1##?
  2. What is Newton's second law in the vertical direction for ##m_2##?
  • #45
Because in parts A and B the acceleration was zero, maybe?
  • #46
I've attached the full question to this reply! There is no mention of acceleration being 0 from what I can tell!
  • #47
"barely slides", i.e. negligible acceleration.
  • #48
Got it, so technically what we did with parts A and B is a F=ma analysis where 2T-m_2*g=m_2*a_2=0 and thus 2T=m_2*g?
  • #49
Yes.
  • #50
haruspex said:
Yes.
So just to confirm: Conceptually, we ALWAYS have to do a F=ma analysis.
I've attached the new solution that I've come to. Does it look correct?
