Uniform charge across a rod, Professor couldn't answer
Hydroshock
Alright, well I wanted to see what help I could get here, my professor had assigned this problem and when someone in class asked a question, he started doing it on the board and after using ~15min of class time decided there was an issue with the problem. The problem got progressively harder (which leads me to believe he must have made a mistake) and he ended up deciding we don't have to do it, but I'm interested in getting it done anyway.
"A rod of length L has a total charge Q uniformly distributed alone its length. The rod lies along the x-axis with its center at the origin. (a) What is the electric potential as a function of position along the x-axis for x > L/2? (b) Show that for x >> L/2, your result reduces to that due to a point charge Q.
V = int|kdq/r
dq = λdx
λ = Q/L
r = x0 - x
Well what the problem was when we got to (b). Which after setting up the equation we ended up with
k\lambda\int_{-L/2}^{L/2}\frac {dx} {x_0-x})
where after substitution we get
k\lambda\int_{-L/2}^{L/2}ln(x_0-x)
but since there's units (meters) for x, it can't be run through a transcendental function, then I got lost here, but with more substitution we ended up with
V = k\lambdaln\frac {x_0-1/2} {x_0+1/2}
then when the problem got going, it expanded and expanded and didn't get any simplification going, which is odd for a textbook question. I guess it's more of needing a check with the math work done in the problem?
Hi!
What you've done looks pretty good, but after subbing in the limits from the integral on this line:
\frac { \lambda } { 4 \pi \epsilon_o} ( ln (x_o + L/2) - ln (x_o - L/2) )
instead of combining the logs (using ln(A) - ln (B) = ln (A/B)) like you've done on the next line, why not factorise out an x_o in each log? Then you can pull the x_o out of the log by using the log rule ln (AB) = ln A + ln B. Something like this:
\frac { \lambda } { 4 \pi \epsilon_o} ( ln (x_o) - ln (1 + \frac{L}{2x_o}) - ln(x_o) - ln (x_o - \frac{L}{2x_o}) )
Notice how the ln(x_o) cancels.
Here's the trick now though. Try expanding each of the logs to O^2 in terms of a taylor series. If you've done it right, you'll hopefully get some canceling and be left with a an equation which you can replace the charge density and length by the total charge. You're final equation should look like this:
\frac { Q } { 4 \pi \epsilon_o x_o}
Hope this helps :-)
For starters I'd use x' to represent the position of the source charge, and x to represent the field point along the x-axis. Then Coulomb's Law giives:
V(x)=k \lambda \int_{-L/2}^{L/2} \frac{dx'}{|x-x'|} = -k \lambda ln \left( |x-x'| \right) |_{-L/2}^{L/2} = -k \lambda ln \left( \frac{|x-L/2|}{|x+L/2|} \right) = k \lambda ln \left( \frac{|x+L/2|}{|x-L/2|} \right)
For x> L/2, \quad |x-L/2|=x-L/2, \quad |x+L/2|=x+L/2
So, your solution for (a) is:
V(x)=k \lambda ln \left( \frac{x+L/2}{x-L/2} \right)
Now for (b), expand the log in a http://en.wikipedia.org/wiki/Mercator_series" :
V(x)=k \lambda ln \left( \frac{x+L/2}{x-L/2} \right) =k \lambda ln \left( \frac{1+\frac{L}{2x}}{1-\frac{L}{2x}} \right) = k \lambda ln \left( 1+\frac{L}{2x} \right) - k \lambda ln \left( 1-\frac{L}{2x} \right) \approx k \lambda \left( \frac{L}{2x} - \frac{L^2}{8x^2} \right) - k \lambda \left( - \frac{L}{2x} - \frac{L^2}{8x^2} \right)=k \frac{ \lambda L}{x} = k \frac{Q}{x}
That works gabbagabbahey :) Thanks for the help to you two.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
