What Are the Effective and Total Deviator Stresses in Saturated Silty Clay?
In summary, to solve this problem, you need to understand the given information and what is being asked. Then, use the equations and concepts related to effective and total stresses, deviator stress, and porewater pressure to calculate the effective and total deviator stresses at failure, as well as the load needed to cause failure. Make sure to double check your units and answers. Following a systematic and logical approach will help you solve this problem successfully. Good luck on your exam!
db725
35
Urgent Question Soil Mechanics -- Please Help
A saturated over-consolidated silty clay is estimated to have the effective strength parameters
c'=5 kPa
∅'=25 kPa
A specimen of the silty is mounted into a triaxial cell and full consolidated to 400 kPa with a cell pressure of 500 kPa and a back pressure of 100 kPa. With the drainage then turned off, the specimen is slowly loaded axially failure. At failure, the porewater pressure was measured to be 160 kPa and the diameter of the specimen was calculated to be 103.47 mm.
Estimate
1. the effective deviator stress at failure (σ1'-σ3')
2. the total deviator stress at failure (σ1-σ3), and
3. the load which would be needed to be applied to the loading piston to cause failure.
σ1=σ'1+u
deviator stress =deviator load/area
cell pressure =500 kPa, back pressure=100 kPa, σ3= 500-100=400 kPa
u(failure)=160 kPa
Area at failure = (∏ x diameter^2)/4=(∏x103.47^2)/4=8408.50 mm^2
1. Deviator stress= deviator load/area= (400 x 10^3)/8408.50=47.57 kPa
σ'3 at failure = 400-160=240 kPa
σ'1 at failure= σ'3 +deviator stress = 240 +47.57=287.57 kPa
2. σ1=σ1'+u=287.57+160=447.57 kPa σ3=σ3'+u =240+160=400 kPa
3. Not sure how to do this. Was thinking of drawing the mohr circles using the previous calculations. However I feel like there is something wrong with the above as when I sketched the mohr circles I got a strange circle.
I would greatly appreciate any help on this question as I am getting prepared for a final exam in my engineering degree. My exam is in 2 days and I would really like to know if I am on the right track or not. Thanks in advance.
it is important to approach problems in a systematic and logical manner. Here are some steps you can take to solve this problem:
1. First, make sure you understand the given information and what is being asked. The problem gives you the effective strength parameters of the soil, the conditions under which the specimen was tested, and the measurements taken during the test. You are asked to estimate the effective and total deviator stresses at failure, as well as the load needed to cause failure.
2. Next, review the equations and concepts related to effective and total stresses, deviator stress, and porewater pressure. Make sure you understand how these values are calculated and what they represent.
3. Then, start by calculating the effective deviator stress at failure. This can be done by using the given information on the cell pressure, back pressure, and porewater pressure, as well as the formula for deviator stress. Make sure your units are consistent.
4. Next, use the effective deviator stress to calculate the effective principal stresses at failure. This can be done using the Mohr-Coulomb failure criterion, which states that the failure occurs when the deviator stress equals the effective cohesion plus the effective stress multiplied by the effective friction angle. Make sure your units are consistent.
5. Once you have the effective principal stresses, you can use them to calculate the total principal stresses at failure. This can be done by adding the porewater pressure to the effective principal stresses.
6. Finally, to calculate the load needed to cause failure, you can use the formula for deviator stress and rearrange it to solve for the deviator load. This load should be applied to the loading piston, so make sure you use the correct area in your calculation.
7. Once you have completed all the calculations, make sure to double check your units and final answers to ensure they are correct.
I hope this helps you in solving the problem. Remember to approach it step by step and use the equations and concepts you have learned in your studies. Good luck on your exam!
What is soil mechanics?
Soil mechanics is a branch of geotechnical engineering that studies the behavior of soil under different conditions, such as loading or moisture content. It involves the application of principles from mechanics, physics, and mathematics to understand the properties and behavior of soil.
Why is soil mechanics important?
Soil mechanics is important because soil is the foundation of all civil engineering projects. Understanding the properties and behavior of soil is crucial in designing safe and stable structures such as buildings, roads, and bridges. It also plays a significant role in environmental and geotechnical engineering projects.
What are the main factors that affect soil behavior?
The main factors that affect soil behavior are its composition, moisture content, density, and loading conditions. The type of soil, its particle size distribution, and its mineralogy can greatly influence its properties. The amount of water in the soil also affects its strength and compressibility. The density of the soil is also important, as it determines its ability to support loads. Lastly, the type and magnitude of external loads, such as building or vehicle loads, can significantly impact soil behavior.
What are the different types of soil tests used in soil mechanics?
There are several types of soil tests used in soil mechanics, including classification tests, compaction tests, and strength tests. Classification tests determine the type and properties of soil, such as its particle size distribution and plasticity. Compaction tests measure the maximum density and water content of soil to determine its suitability for construction. Strength tests, such as triaxial and compression tests, assess the strength and stiffness of soil under different conditions.
How can soil mechanics be applied in real-world projects?
Soil mechanics can be applied in real-world projects by conducting site investigations and soil testing to understand the properties and behavior of the soil at a construction site. This information is then used to design foundations, slopes, and retaining structures that can withstand the loads and environmental conditions at the site. Soil mechanics is also used to evaluate and mitigate potential hazards, such as landslides or liquefaction, and to monitor the performance of structures over time.
