Can Time Be Considered a Constant in Extra Dimensional Universes?
  • Thread starter SimonA
  • Tags
    Units
In summary: A photon is a particle, and an electron is a particle. They have different properties, but fundamentally they are just different ways of representing the same thing. Photons have a wavelength, and electrons have a charge. Photons have momentum and electrons have kinetic energy. They both have mass and they both have momentum. Electrons also have a magnetic moment.
SimonA
176
What is time ? My maths is so rusty its almost non existant. I'm looking at the energy to mass equivalence formula and trying to work out an equivalent 'unit of time'. With my poor maths I get;
e=mc^2e^(1/2)=m^(1/2)* c
[In terms of units]
e^(1/2)=m^(1/2)* (d/t)e^(1/2)*t=m^(1/2)* dt= d * m^(1/2) / e^(1/2)So in terms of units, time is related to distance ( einsteins spacetime ) multiplied by a 'small part' of mass over energy. Is doing this valid at all ?
Energy is not a base unit. if you consider the kinetic energy formula E=1/2m*v^2 then the units of energy are as follows:
E=([M]*[L]^2)/[T]^2
If you replace energy in your expression with its units you'll find that time is equal to time as it should be.
Hi Kurdt
I'm trying to understand time, so its not much use saying that its time.
Does this seem ok ?
Comparing units is fine but if you do not use fundamental units then you just have an elaborate way of saying time is equal to time. As one of the fundamental units that's all you will ever get with time. Understanding it is more to do with philosophical arguments i guess although it is defined by the speed of light.
Hi Kurt
Thats my starting point, but what do you mean by "speed". If time is defined by the speed of light, that seems so important. Perhaps we should say veolcity rather than speed ? Phased EM, laser like, finds its target like a particle. Individual photons spread out like a wave.
So what is the difference between a phased photon and a photon in youngs slit experiment ?
There is no consideration of dimensionaity in these concepts. No one seems to want to move on from Einstein.
Saying time is defined by the speed of light was confusing because you need time to define speed. What you define one second by is how long it takes light to travel a particular distance. I never really felt comfortable with this because you need a definition of time to have a speed in the first place. I prefer the definition that says one second is the time taken for a caesium atom to oscillate so many times (I'm a theoretical physicist thus i have no idea how many times it actually is). Anyway I'm still not clear what it is about time that you're trying to understand. Are you attemting to derive the time dilation formula?
You CAN indeed rederive the unit system by choosing a new set of base units. Take care, though, you need to also rederive all the equations and reinterpret them. Here-in lies the problem. If you choose, say, J, kgm/s, and kg as base units (a system based on conserved quantities), just what does J/kg imply? What is a J/(kgm/s) and what does it mean?
I have messed with this a bit and have yet to find another system that makes any sort of internal logical sense. That doesn't mean there isn't a way to do it, but it is HIGHLY non-trivial.
-Dan
"Base" units are man-made not natural. I remember reading, some years back, a way of choosing "natural" units in which it was necessary to change what you consider "base" units. Since the speed of light, c, is a natural constant, take speed as "base" and c as the unit (that's commonly done in texts on relativity). Since Plank's constant, h, which measures "action" is a natural constant, take that as a base unit. Similarly, take G, the "universal gravitational constant (NOT "g"), as base unit. If I remember correctly, the unit length in that system turns out to be the "diameter" of an electron and the unit time is the time it takes light to cross that distance.
Great answers thanks guys. I will stick to this "Introductory Physics" board as the replies are far more down to Earth than on other boards here like QM and cosmology.
What I'm trying to do is use time as a 'constant' in an extra dimensional universe. Einstein's relativity is clearly fundamental. But mass and EM energy seem to occupy fundamentally different realms. When a photon is emitted as light - or when an electron travels down a telephone cable - there is a change in properties of the domain of that energy that is more fundamental than 3D spatial vectors. This is the heart of einsteins theories, but kind of taken for granted. I suspect time is, despite what seems intuitive, the actual connection between these domains. For EM raditation there is no time, and yet it has a very real connection to spacetime in 'relativity'. This is why I'm curious what the difference is between a 'normal' light photon that travels through both slits in youngs experiment, and a 'phased' photon that is part of a laser beam. By polarising the light, the connection between the matter and EM domains seems to have been changed. Or is this an incorrect assumption I have made - would a photon in a laser also pass through both slits?
Thanks
Simon
Related to Can Time Be Considered a Constant in Extra Dimensional Universes?
1. What is the importance of comparing units in scientific research?
The comparison of units is important in scientific research because it allows for the evaluation and understanding of relationships between variables. It also helps to determine the validity and reliability of the results obtained.
2. How do researchers ensure the validity of comparing units?
Researchers ensure the validity of comparing units by using standardized units of measurement and controlling for confounding variables. They also conduct replication studies to confirm the consistency of their findings.
3. What are the limitations of comparing units in scientific research?
One limitation is that not all variables can be easily quantified and compared using standardized units. Additionally, there may be cultural or contextual differences that make it difficult to compare units across different populations or settings.
4. How does the validity of comparing units impact the interpretation of research findings?
The validity of comparing units directly affects the accuracy and generalizability of research findings. If the units are not valid, the conclusions drawn from the study may not be applicable to other situations or populations.
5. Can the validity of comparing units be improved?
Yes, the validity of comparing units can be improved through careful study design, use of appropriate statistical methods, and consideration of potential confounding factors. Collaborative efforts between researchers and experts in the field can also help to improve the validity of comparing units.
