VHDL Register File Test Bench
  • Thread starter hinkypunk
  • Tags
    File Test
In summary, the conversation is about implementing a register file and test bench in VHDL. The speaker has finished the register file and is now working on the test bench. They are unsure about how to write the stimulus process and are seeking guidance. The code for the register file and test bench is also provided.
hinkypunk
I am trying to implement a register file and a test bench in VHDL. I think I have the register file itself done ok so I just have to test it with the test bench now. I'm a little unsure as to how write the stimulus process however and was hoping that someone could point me the right way. This is what I have so far:
Register File
Code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity register_file is
    Port ( src_s0 : in  STD_LOGIC;
           src_s1 : in  STD_LOGIC;
           des_A0 : in  STD_LOGIC;
           des_A1 : in  STD_LOGIC;
           Clk : in  STD_LOGIC;
           data_src : in  STD_LOGIC;
           data : in  STD_LOGIC_VECTOR (15 downto 0);
           reg0 : out  STD_LOGIC_VECTOR (15 downto 0);
           reg1 : out  STD_LOGIC_VECTOR (15 downto 0);
           reg2 : out  STD_LOGIC_VECTOR (15 downto 0);
           reg3 : out  STD_LOGIC_VECTOR (15 downto 0));
end register_file;
architecture Behavioral of register_file is
-- components
	-- 16 bit Register for register file
	COMPONENT reg4
	PORT(
			D : IN std_logic_vector(15 downto 0);
			load : IN std_logic;
			Clk : IN std_logic;
			Q : OUT std_logic_vector(15 downto 0)
	END COMPONENT;
	-- 2 to 4 Decoder
	COMPONENT decoder_2to4
	PORT(
			A0 : IN std_logic;
			A1 : IN std_logic;
			Q0 : OUT std_logic;
			Q1 : OUT std_logic;
			Q2 : OUT std_logic;
			Q3 : OUT std_logic
	END COMPONENT;
	-- 2 to 1 line multiplexer
	COMPONENT mux2_4bit
	PORT(
			In0 : IN std_logic_vector(15 downto 0);
			In1 : IN std_logic_vector(15 downto 0);
			s : IN std_logic;
			Z : OUT std_logic_vector(15 downto 0)
	END COMPONENT;
	-- 4 to 1 line multiplexer
	COMPONENT mux4_4bit
	PORT(
			In2 : IN std_logic_vector(15 downto 0);
			In3 : IN std_logic_vector(15 downto 0);
			S0 : IN std_logic;
			S1 : IN std_logic;
	END COMPONENT;-- signals
signal load_reg0, load_reg1, load_reg2, load_reg3 : std_logic;
signal reg0_q, reg1_q, reg2_q, reg3_q,
			data_src_mux_out, src_reg : std_logic_vector(15 downto 0);begin
-- port maps
	--register 0
	reg00: reg4 PORT MAP(
				D => data_src_mux_out,
				load => load_reg0,
				Clk => Clk,
				Q => reg0_q
	--register 1
	reg01: reg4 PORT MAP(
				load => load_reg1,
				Clk => Clk,
				Q => reg1_q
	--register 2
	reg02: reg4 PORT MAP(
				load => load_reg2,
				Clk => Clk,
				Q => reg2_q
	--register 3
	reg03: reg4 PORT MAP(
				load => load_reg3,
				Clk => Clk,
				Q => reg3_q
	-- Destination register decoder
	des_decoder_2to4: decoder_2to4 PORT MAP(
				A0 => des_A0,
				A1 => des_A1,
				Q0 => load_reg0,
				Q1 => load_reg1,
				Q2 => load_reg2,
				Q3 => load_reg3
	-- 2 to 1 Data source multiplexer
	data_src_mux2_4bit: mux2_4bit PORT MAP(
				In0 => data,
				In1 => src_reg,
				s => data_src,
				Z => data_src_mux_out
	-- 4to 1 source register multiplexer
	Inst_mux4_4bit: mux4_4bit PORT MAP(
				In0 => reg0_q,
				In1 => reg1_q,
				In2 => reg2_q,
				In3 => reg3_q,
				S0 => src_s0,
				S1 => src_s1,
				Z => src_reg
	reg0 <= reg0_q;
	reg1 <= reg1_q;
	reg2 <= reg2_q;
	reg3 <= reg3_q;
end Behavioral;
Register File test bench
Code:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY register_file_tb IS
END register_file_tb;
ARCHITECTURE behavior OF register_file_tb IS
    -- Component Declaration for the Unit Under Test (UUT)
    COMPONENT register_file
    PORT(
         src_s0 : IN  std_logic;
         src_s1 : IN  std_logic;
         des_A0 : IN  std_logic;
         des_A1 : IN  std_logic;
         Clk : IN  std_logic;
         data_src : IN  std_logic;
         data : IN  std_logic_vector(15 downto 0);
         reg0 : OUT  std_logic_vector(15 downto 0);
         reg1 : OUT  std_logic_vector(15 downto 0);
         reg2 : OUT  std_logic_vector(15 downto 0);
         reg3 : OUT  std_logic_vector(15 downto 0)
    END COMPONENT;
   --Inputs
   signal src_s0 : std_logic := '0';
   signal src_s1 : std_logic := '0';
   signal des_A0 : std_logic := '0';
   signal des_A1 : std_logic := '0';
   signal Clk : std_logic := '0';
   signal data_src : std_logic := '0';
   signal data : std_logic_vector(15 downto 0) := (others => '0');
 	--Outputs
   signal reg0 : std_logic_vector(15 downto 0);
   signal reg1 : std_logic_vector(15 downto 0);
   signal reg2 : std_logic_vector(15 downto 0);
   signal reg3 : std_logic_vector(15 downto 0);
   -- Clock period definitions
   constant Clk_period : time := 10 ns;
BEGIN
	-- Instantiate the Unit Under Test (UUT)
   uut: register_file PORT MAP (
          src_s0 => src_s0,
          src_s1 => src_s1,
          des_A0 => des_A0,
          des_A1 => des_A1,
          Clk => Clk,
          data_src => data_src,
          data => data,
          reg0 => reg0,
          reg1 => reg1,
          reg2 => reg2,
          reg3 => reg3
   -- Clock process definitions
   Clk_process :process
   begin
		Clk <= '0';
		wait for Clk_period/2;
		Clk <= '1';
   end process;
   -- Stimulus process
   stim_proc: process
   begin
		data <= "0101010101010101";
			src_s0 <= '0'; src_s1 <= '0';
			des_A0 <= '0'; des_A1 <= '0';
			wait for 10 ns;
				des_A0 <= '1'; des_A1 <= '0';
			wait for 10 ns;
				des_A0 <= '0'; des_A1 <= '1';
			wait for 10 ns;
				des_A0 <= '1'; des_A1 <= '1';
		wait for 10 ns;
			data <= "0000111100001111";
			wait for 10 ns;
			wait for 10 ns;
			wait for 10 ns;
		wait for 10 ns;
			src_s0 <= '1'; src_s1 <= '0';
			wait for 10 ns;
			wait for 10 ns;
			wait for 10 ns;
		wait for 10 ns;
			wait for 10 ns;
			wait for 10 ns;
			wait for 10 ns;
		wait for 10 ns;
			src_s0 <= '0'; src_s1 <= '1';
			wait for 10 ns;
			wait for 10 ns;
			wait for 10 ns;
		wait for 10 ns;
			wait for 10 ns;
			wait for 10 ns;
			wait for 10 ns;
		wait for 10 ns;
			src_s0 <= '1'; src_s1 <= '1';
			wait for 10 ns;
			wait for 10 ns;
			wait for 10 ns;
		wait for 10 ns;
			wait for 10 ns;
			wait for 10 ns;
			wait for 10 ns;
     -- wait;
   end process;
END;
Am I going in the right way at all with it?
please help me these is my first time on these forum.I didn't know where to post these question.A car and a truck start from rest at the same time, with the car initally some distance behind the the truck. The acceleration of the truck is 2.10m/s^2 and the acceleration of the car is 3.40 m/s^2. The car overtakes the truck after the truck has moved 40.0 m.how long does it takes the car to overtake the truck?
I tried to equate the distance traveled by both, abd it turns to be is if the car has traveled 40.m
1. What is a VHDL register file test bench?
A VHDL register file test bench is a simulation environment used to test the functionality of a VHDL register file design. It is a collection of test cases and stimuli that are used to verify the correct operation of the register file.
2. Why is a register file test bench necessary?
A register file test bench is necessary to ensure that the register file design meets the desired specifications and functions correctly. It also helps to identify and debug any errors or issues in the design before it is implemented in hardware.
3. How do you write a VHDL register file test bench?
To write a VHDL register file test bench, you need to first define the test cases and stimuli that will be used to verify the design. Then, you need to instantiate the register file in the test bench and apply the stimuli to the inputs. The outputs of the register file can then be compared to the expected results to check for correct functionality.
4. What are the important factors to consider when designing a register file test bench?
Some important factors to consider when designing a register file test bench include choosing appropriate test cases and stimuli to cover all possible scenarios, ensuring proper initialization and clocking of the register file, and verifying correct data and control signal propagation within the design.
5. Can a register file test bench be used for other VHDL designs?
Yes, a register file test bench can be modified and used for other VHDL designs. However, the stimuli and test cases will need to be updated to match the inputs and outputs of the new design. It is important to thoroughly test and verify the modified test bench to ensure accurate results.
11K
11K
  • Electrical Engineering
