Ali Raza
- 3
i want to know the behavior of voltage in 11 KV underground and OH distribution line at different load conditions i.e. no load-full load ...
I meant the change in voltage and other parameters i.e. inductance, capacitance etc in case of different loading like no load , partial loading or full load, and what measures can be taken to prevent any such change .davenn said:hi there
welcome to PF
your question is quite vague ... what type of behavior are you referring to/wanting to know about ?
Thank u i am trying ...anorlunda said:You want to regulate voltage on cables and OH lines. You need to consult with a power engineer, or to study power system analysis enough to do your own engineering.
Answer to questions such as the OP are unlikely to be complete enough to make good choices.
UG cables, also known as underground cables, are cables that are buried underground for the purpose of transmitting electricity. OH 11 KV distribution lines, on the other hand, are overhead lines that are placed above ground and supported by poles or towers. The main difference between the two is their location and method of installation.
Voltage behavior in UG cables and OH 11 KV distribution lines is affected by several factors such as the type of insulation used, the length of the cable or line, and the load on the system. In general, the voltage in UG cables tends to be more stable compared to OH 11 KV distribution lines due to the added protection from the surrounding soil.
Some common issues with voltage behavior in UG cables and OH 11 KV distribution lines include voltage drop, overvoltage, and insulation breakdown. These issues can be caused by factors such as cable/line length, load fluctuations, and environmental conditions. Regular maintenance and proper installation can help prevent these issues.
In UG cables, voltage is controlled through the use of transformers and voltage regulators. Transformers are used to step-up or step-down the voltage as needed, while voltage regulators are used to maintain a steady voltage level. In OH 11 KV distribution lines, voltage is controlled through the use of voltage regulators and capacitor banks.
When working with voltage in UG cables and OH 11 KV distribution lines, it is important to follow all safety precautions and protocols. This includes using proper personal protective equipment, de-energizing the cables/lines before maintenance or repairs, and following proper grounding procedures. It is also important to regularly inspect and maintain the cables/lines to ensure safe operation.
