wirebiter
- 1
I know I knew this many years ago and I am sure the answer is simple but I would really appreciate the help.
Event That Brought Up The Question:
Working on a complany vehicle, there was a heater fan that would keep failing. As we troubleshot, we saw that system voltage was low (bad alternator) causing the fan to draw more current (possibly, at least this is what I was told and I seem to remember that this is in fact true).
If this is correct, my question is how?
In my head, I am thinking that the fans resistance (at least before being damaged) would have stayed the same...therfore with:
I = E/R
Resistance staying the same and system voltage droping, current would then drop and not overheat/damage the fan. But then, that doesn't fit the example.
If I look at it as having to maintain the same power, then:
P = I x E
To maintain the same power, and voltage decreases, then current must increase which does fit the above example.
But, then if current increases, resistance had to decrease (Im pretty sure that wouldn't have happened to the fan, again..at least not at first) OR, voltage had to increase, which does not fit the above example. (Using I = E / R again)
I know I am just missing a simple part or concept, or I am over nuking things, but if someone could clear this up for me I would appreciate it. (Hopefully I explained it well)
I = E/R
P = I x E
