How Was the Moon Formed?
  • I
  • Thread starter HG009
  • Tags
    Moon
In summary, the conversation discusses the theory of Theia, a Mars-sized planet that is believed to have collided with Earth and formed the moon. However, there are different versions of this theory and it remains an open question. The conversation also addresses possible language barriers and confusion over the topic.
HG009
TL;DR Summary
What actually made moon according to you
:smile:
Astronomy news on Phys.org
What do you think and why? We expect an effort on the part of people asking questions.
I think Theia The Mars sized planet which crashed into our planet Only crashed On the half Side and the other side survived and with billions it turned into a sphere And Looks like this
@HG009, please be careful about how to use quoting. . .
[Malformed quote by HG009 fixed by a Mentor]
I find that statement pretty much incoherent but I THINK you have stated the standard belief about how the moon formed.
Is there perhaps a language problem? I see that you have capitalized a lot of words. Is German your native language?
sysprog said:
@HG009, please be careful about how to use quoting . . .
No , I really believe in theia But scientists say it crashed Fully into Earth like it could have even a planet between The astroid belt and Mars so when Jupiter's gravity may have deformed its orbit and could made it a elliptical orbit and So when that happened the half of the planet only crashed and remaining half has turned into sphere Becuase of gravity..I know it is a weird and fantasy theory
What is that
Again, I find your statement pretty much incoherent and I ask again, is English your native tongue?
To the extent I can understand what you are saying, I repeat ... you are stating the standard version of how the moon formed, although a rather convoluted version.
Have you READ the standard version? Do you have a question about it?
Yes...Im not German.. and English isn't my native language I'm using tablet for this so everyone I put Two spaces Its got caps
Nobody knows exactly how the moon formed, although some variant on a collision between Earth and a Mars-sized object is the leading hypothesis. I think they all have problems explaining all of the facts, though, so it remains an open question.
Note that this is essentially a historical question. It's not "how does x happen", it's "how did x happen". Like a lot of history when there was nobody around to see and only limited circumstantial evidence in the aftermath, we may never know with complete certainty.
Likes Delta2, sysprog, Vanadium 50 and 1 other person
HG009 said:
What is that
I fixed your post that @sysprog was referring to -- you managed to click "Reply" twice or something, creating a mixed-up double-nested quote.
Ok
It also doesn't fit most of the evidence.
Likes russ_watters
Not bad, You got your viewpoint on how the moon is formed, Though your point sounds fantasy theory or stuff as many say, Imagination is as important as knowledge, cause knowledge maybe limited but imagination isn't, Also how Universe was made, How Earth was formed, How is the milky way galaxy moving, How Planets in the solar system have orbits or How is the Moon formed, these all have no confirmed answer, But theories, And where do theories and hypothesis come from? Imagination, Do imagine but also believe in science as it has something called Logic.
Logic is magic.
And how the moon is formed well, I don't know as I wasn't born then just got the same theory as others to believe in.
  • Skeptical
Likes weirdoguy and Motore
The current leading theory is the Giant Impact Theory, which is the theory that a smaller object impacted the Earth, with the debris thrown up from the impact forming the Moon. Per wiki, this has the following supporting evidence:
  • Earth's spin and the Moon's orbit have similar orientations.[5]
  • The Earth–Moon system contains an anomalously high angular momentum. Meaning, the momentum contained in Earth's rotation, the Moon's rotation, and the Moon revolving around Earth is significantly higher than the other terrestrial planets. A giant impact might have supplied this excess momentum.
  • Moon samples indicate that the Moon was once molten down to a substantial, but unknown, depth. This might have required more energy than predicted to be available from the accretion of a body of the Moon's size. An extremely energetic process, such as a giant impact, could provide this energy.
  • The Moon has a relatively small iron core. This gives the Moon a lower density than Earth. Computer models of a giant impact of a Mars-sized body with Earth indicate the impactor's core would likely penetrate Earth and fuse with its own core. This would leave the Moon with less metallic iron than other planetary bodies.
  • The Moon is depleted in volatile elements compared to Earth. Vaporizing at comparably lower temperatures, they could be lost in a high-energy event, with the Moon's smaller gravity unable to recapture them while Earth did.
  • There is evidence in other star systems of similar collisions, resulting in debris discs.
  • Giant collisions are consistent with the leading theory of the formation of the Solar System.
  • The stable-isotope ratios of lunar and terrestrial rock are identical, implying a common origin.[6]
This theory is by no means perfect, as one would expect given that we are trying to understand something that happened over 4 billion years ago, but there is currently no better explanation.
Likes pinball1970, collinsmark, Ibix and 2 others
HG009 said:
Summary:: What actually made moon according to you
And with Drak's good post, this thread is now closed.
  • Sad
Likes Delta2 and Zeal Faust
1. What is the most widely accepted theory for the formation of the Moon?
The most widely accepted theory is the Giant Impact Hypothesis, which suggests that the Moon was formed from debris created by a collision between Earth and a Mars-sized object early in the history of the solar system.
2. How does the Giant Impact Hypothesis explain the similarities between the Moon and Earth?
The collision between Earth and the Mars-sized object would have ejected material from both bodies into orbit, which then coalesced to form the Moon. This explains why the Moon has a similar composition to Earth's mantle.
3. What evidence supports the Giant Impact Hypothesis?
Scientists have found that the Moon's composition, as well as the composition of lunar rocks brought back by Apollo missions, closely matches that of Earth's mantle. Additionally, computer simulations have shown that a giant impact could have produced a debris disk that eventually formed the Moon.
4. How does the age of the Moon compare to the age of Earth?
The Moon is approximately 4.5 billion years old, which is the same age as Earth. This supports the Giant Impact Hypothesis, as it suggests that the Moon formed at the same time as Earth.
5. Are there any alternative theories for the formation of the Moon?
Yes, there are alternative theories such as the Co-formation Theory, which suggests that the Moon formed alongside Earth from the same cloud of gas and dust. However, this theory does not account for the differences in composition between the two bodies and is not as widely accepted as the Giant Impact Hypothesis.
  • Astronomy and Astrophysics
