What Does X1-xMx Notation Indicate in Material Science?
In summary, this conversation is about notation for mixtures that contain two elements in a particular ratio. The notation shown uses subscripts to denote the proportion of each element in the molecular formula.
dipole
555
151
I see this often and am not sure what it means. Suppose X and M are any two elements:
X1-xMx
Thanks.
Chemistry news on Phys.org
dipole;3985425e5DI see this often and am not sure what it means. Suppose X and M are any two elements: X[SUB said:
1-x[/SUB]Mx
Thanks.
Do you mean like [itex]C_nH_{2n+2}[/itex]? That is a notation for a class of compounds that contain two elements (carbon and hydrogen) in a particular ratio - in this case, the class is the alkanes. n can take on any integer value starting from 1. There will be n carbon atoms and (2n+2) H atoms. So you can have [itex]CH_4, C_2H_6, C_3H_8,...[/itex] for methane, ethane and propane, respectively.
I'm guessing your notation is similar, and the subscripts denote the proportion in which X and M make up the molecular formula of each of the compounds in the class you're considering.
Yes that makes sense, but the notation I posted doesn't because it would produce negative indices. For example, Bi2Sb3 is one compound which has that formula, but the indices should then be BixSbx+1, so I'm wondering it it doesn't have to do with the stochiometric ratio and perhaps something to do with electron configuration or something.
Do you know what molar fraction is? Molar fractions sum to 1, my guess is that notation you show means a mixture that contains x moles of M and (1-x) moles of X in each mole of the mixture. Whether it is still a mixture, or a compound, or some combination of both is another question.
Take an alloy of gold and caesium. When they are in exactly equimolar ratio they create caesium auride, when the mixture is not equimolar, it contains some auride and some pure metal (it is obvious when your observe specific resistance of the mixture - when it is equimolar, resistance goes up by orders of magnitude, as auride replaces pure metals). Using your notation pure caesium auride would be Cs0.5Au0.5.
I believe Borek has it as these are the ways that superconductors and ceramics are often often described in "notation". Ceramics will be describing oxides with the noted molar composition of the XM, and superconductors will often use this , but have to describe the anionic components separately.
X is a metalloid, and M is a metal.
Related to What Does X1-xMx Notation Indicate in Material Science?
1. What does the "x" notation mean in mathematics?
In mathematics, the "x" notation is typically used to represent an unknown quantity or variable in an equation or expression. It is often used in algebraic equations to represent a number that can take on different values.
2. What does the "Σ" notation mean in statistics?
In statistics, the "Σ" notation is used to represent a sum or total of a set of numbers. It is often used in formulas to calculate the sum of a series of data points.
3. What does the "∫" notation mean in calculus?
In calculus, the "∫" notation is used to represent the integral of a function. It is used to find the area under a curve or to calculate the total change in a quantity over a given interval.
4. What does the "μ" notation mean in chemistry?
In chemistry, the "μ" notation is used to represent the mean or average of a set of values. It is often used in formulas to calculate the average atomic mass or the average weight of a compound.
5. What does the "λ" notation mean in physics?
In physics, the "λ" notation is used to represent wavelength, which is a measure of the distance between two consecutive peaks or troughs in a wave. It is often used in equations to calculate the frequency or energy of a wave.
  • Linear and Abstract Algebra
  • General Math
