What shapes do d orbital represent?
In summary, the conversation discusses the shapes and orientations of d orbitals, particularly d_z^2, and their relationship to other quadratic expressions such as x^2 and y^2. The conversation also touches on the role of these orbitals in hybridization and their relevance to different molecular geometries. There is a mention of Linus Pauling's book, "The Nature of the Chemical Bond," which explains the rationale behind the choice of hybrid orbitals. Overall, the conversation highlights the complexity and theoretical nature of orbitals and their relationship to molecular structure.
Raghav Gupta
1,011
76
In d orbital there are 5 degenerates.
How ## d_z^2 ## represents something like a donut shape.
Shouldn't it be a parabola with respect to z axis, like when plotting graph of ## x^2 ##.
Also have confusion about shapes of other 4 degenerates.
For s it is spherical and simple.
For p there are 3 degenerates directed along x,y,z axes.
Have confusion about shapes of these orbitals. Can somebody help?
The "2" is an index, not an exponent.
The orbitals are solutions to the Schrödinger equation. They just happen to look like that. What images usually show are the regions with a high probability to find the electron.
So what is 2 representing here as an index?
Also in square planar geometry having hybridisation dsp2 , there are certain orbital degenerates involved, totally 4. What are these and what is their reason?
No, it is an exponent, not an index. However, it is an abreviation for ##z^2-(x^2+y^2+z^2)/3##. Specifically, you can form 6 quadratic expressions: xy, xz, yz, ##x^2##, ##y^2##, ##z^2##, but the combination ##x^2+y^2+z^2## transforms like an s-orbital, hence you subtract it.
Likes mfb
Isn't then x2 +1 a quadratic expression and so on? How total six then?
How then ##x^2+y^2+z^2## transforms like an s-orbital?
What is the answer for this?
How then ##x^2+y^2+z^2## transforms like an s-orbital?What is the answer for this?
To 1: "1" isn't a quadratic expression in x, y or z.
##x^2+y^2+z^2=r^2## i.e. the square of the radial distance. It is rotational isotropic, i.e. transforms as an s orbital and doesn't carry angular momentum.
2. Formally, you can always form hybrids of d, s and p orbitals, irrespective of whether they are degenerate or not, but they will be relevant for bonding only if the s, p and d orbitals are nearly energetically degenerate.
But why in dsp2 hybridisation orbitals like if look at their orientation,
dx2 -y2, px,py and s are only involved?
Why not other d orbital orientations and what about pz?
Because these are the only functions which give your orbitals lying in the xy plane. If you would like to construct dsp2 orbitals lying in some other plane, you would have to use another set of orbitals.
DrDu said:
Because these are the only functions which give your orbitals lying in the xy.
But why one needs orbitals lying in xy ?
You were talking about square planar geometry, weren't you?
Yes. I see for tetrahedral some other 4 orbitals. But is there any specific reason that how to know which orientations for which geometry by any trick or something?
As the molecular coordinate system is arbitrary, to chose the xy plane for planar compounds is convention. Which hybrids correspond to which geometries is not so easy to see.
So we analyze that by experiments?
Is there not any mathematical proof?
Do we have to rote memorize it for different geometries?
No, orbitals are theoretical constructs, and not directly amenable to experiments.
The rationale behind the choice of the hybrid orbitals is due to Linus Pauling's boo: The nature of the chemical bond.
Have a look at it, it is a very good book. However, by now, quite some concepts are outdated or disproven.
I would try to see the book later. Thanks for providing so much help.
What are d orbitals?
D orbitals are atomic orbitals that are shaped like cloverleafs and have five possible orientations in space.
What do d orbitals represent?
D orbitals represent the different ways that electrons can be distributed around the nucleus of an atom in the d subshell.
How many d orbitals are there?
There are five d orbitals, labeled as dxy, dxz, dyz, dz2, and dx2-y2, each with a unique orientation in space.
What is the shape of d orbitals?
The shape of d orbitals can be described as a cloverleaf or a double dumbbell, with varying orientations in space.
What is the significance of d orbitals?
D orbitals are significant because they play a crucial role in determining the chemical and physical properties of elements and their compounds.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
