Why does this proof work?
  • Thread starter GabrielN00
  • Tags
    Proof Work
In summary, the conversation discusses the proof that the multiplicity of the eigenvalue 0 of the Laplacian matrix is equal to the number of convex components in a non-directed graph with non-negative weights. The subspace associated with the eigenvalue 0 is generated by the vectors D^(1/2)1_Ai. However, there are some unclear points in the proof, such as the use of different symbols and undefined variables. To understand the proof, it is helpful to start with a simple case of a graph with only one eigenvalue equal to 0, and then consider the case of multiple eigenvalues equal to 0, which suggests the presence of multiple non-communicating recurrent classes or convex components.
GabrielN00
Let ##G## be a non-directed graph with non negative weights. Prove that the multiplicity of the eigenvalue ##0## of ##L_s## is the same as the number of convex components ##A_1,\dots, A_k## of the graph. And the subspace associated to the eigenvalue ##0## is generated by the vectors ##D^{1/2}1_{A_i}##.
Note ##L_s## denotes the Laplacian matrix
2. Proof
Let ##f, g## be two functions ##$V \to \mathbb R## satisfying ##g = D^{1/2} f##. Then ##\langle g, L_sg\rangle = \langle f, L f\rangle = \sum_{uv \in E} (f(u) - f(v))^2.##
This identity is first used as a proof that all the eigenvalues of ##L## (or ##L_s##) are nonnegative: the right-hand side of the identity is nonnegative by inspection, so the left must be, also.
Moreover, if ##g## is an eigenvector of the eigenvalue ##0##, then ##\langle g, L_sg\rangle = 0##, and this identity characterizes the vectors ##f## for which this can occur.
3. Problems with the proof
There are several things here I don't understand.
(1) Where are the graphs? I see no reference to them
(2) How does the proof show that the multiplicity of ##0## is the same as the number of CONVEX components of the graph?
(3) Why is the subspace of ##0## generated by the vectors in the problem?
The graphs are in the Laplacian.
As for the rest, you have left quite a few things out of this problem, starting with defining the adjacency matrix as ##A##. It's also not clear what ##A_1##, ..., ##A_k## represent -- are these principal submatrices? Further at times you use ##L## and others ##L_s## it isn't clear what the difference is -- if there is one, then it should be stated explicitly, and if there isn't one, then only use one of the two symbols.
You also haven't defined ##D##. In basic combinatorial form, ##D## is a diagonal matrix that has the out degree associated with a given node in ##D_{k,k}##. If that is how it is being used here, your Laplacian can be defined as ##L=D-A##. But I do not think that is how ##D## is being used here. If it is, and all weights are one, then ##D^{1/2}1_{A_i}## would be wrong. (After reading my post and page 15 of the link at the end, you should agree.) I'm aware of other ways to represent the graph Lapacian but we shouldn't have to guess what your book is referring to, nor is guessing really feasible.
Given that the problem is underspecified I'll instead give an overview of how to think about this for that basic case of an Adjacency matrix with only 0s and 1s, and ##D## has the out degree (which equals in degree) and ##L = D- A##. This is sometimes referred to as a combinatorial or un-normalized form of the graph Laplacian.
I'll leave the conversion of this structure to whatever your problem actually wants, up to you.
The graph is undirected hence ##A## is symmetric and so is ##L##. Your eigenvectors hence may be chosen to form an orthogonal basis. Direct application of Gerschgorin discs will also give you the result that ##L## is positive semi-definite.
By construction ##\mathbf 1^T \mathbf L \mathbf 1 = 0## because ##\mathbf L \mathbf 1 = \mathbf 0##. So a graph Laplacian is always singular.
As for the rest-- I like to start simple and build. I.e. start by considering the implications where there is only one eigenvalue equal to zero. This maps directly to a connected graph via the fact that any ##n-1 ## x ##n-1## principal submatrix of ##L## has a positive determinant (and indeed said determinant counts the number of spanning trees in the graph which is greater than zero iff the graph is connected). From here you can use eigenvalue interlacing or quadratic form arguments to carry this home.
Now assume there is more than one eigenvalue equal to zero. This means the graph is not connected. (Note: I tend to use terms like connected regions and distinct recurrent classes interchangeably.)
This suggests that there are multiple non-communicating recurrent classes (which tie directly in with convex components). In general if you have multiple non-communicating connected regions then it is smart to represent your adjacency in blocked form. To answer my own question earlier, I think ## A_1, ... , A_k## would be principal submatrices iff you use an appropriate blocked structures.
With this in mind and a careful look through of
https://www.cs.cmu.edu/~aarti/Class/10701/slides/Lecture21_2.pdf
you should be done.
regarding convex components in particular, the idea is that you can represent a connected region by a graph of convex components. I don't know why they phrased it this way or what the purpose is. Terms like connected region or recurrent class seem a lot more natural to me here.
1. Why is proof important in science?
Proof is important in science because it allows us to establish the validity of a claim or theory. It provides evidence to support our understanding of the natural world and helps us to make accurate predictions and draw reliable conclusions.
2. How does a proof work?
A proof works by using a logical and systematic approach to demonstrate the validity of a statement or concept. It involves starting with a set of assumptions or axioms and using logical reasoning and mathematical principles to reach a conclusion.
3. Why do we need to provide proof for our scientific theories?
We need to provide proof for our scientific theories to ensure that they are reliable and based on evidence. This helps to prevent false or misleading information from being accepted and allows us to continuously improve our understanding of the natural world.
4. What makes a proof valid?
A proof is considered valid if it follows the rules of logic and uses sound reasoning to support its conclusions. It should also be based on reliable data and observations, and be able to withstand scrutiny and testing by other scientists.
5. How does proof contribute to the advancement of science?
Proof contributes to the advancement of science by providing a solid foundation for new discoveries and theories. It allows us to build upon existing knowledge and expand our understanding of the natural world. Additionally, proof can help to identify gaps in our understanding and guide future research efforts.
