Would the two stroke spark ignition PV digram be same as for a 4 stroke?
  • Engineering
  • Thread starter lee123456789
  • Tags
    Ignition Spark
In summary, the 2-stroke engine would have a compression stroke and an ignition stroke, while the 4-stroke engine would have a power stroke and heat rejection.
lee123456789
93
Poster has been reminded to show more effort in their schoolwork posts
write about engines
none
Would two stroke spark ignition PV digram be same as 4 stroke spark ignition. both have otto pv diagrams.
What research have you done on this so far?
ive write about everything just getting confused on the PV diagrams pics to put into the document. i think its otto pv diagram.
How many strokes can you identify on the diagram in the OP?
I was thinking on the diagram
stages 1 -2 - 3 compression and 3 -4 - 1 was expansion
A stroke is a displacement ##V_s##. From 2 to 3 and 4 to 5, there are no displacements (constant volume), so let's forget about those for the moment. But you are correct with 1-2 for compression and 3-4 for expansion. But what about 0-1 and 5-0?
would 2 -3 be ignition phase and 4 - 5 would heat rejection?
0 - 1 Intake Stroke?
5 - 0 Exhaust Stroke?
2-3 would be combustion and 4-5 would be heat rejection (or cooling), but that doesn't have anything to do with our strokes.
So now you have identified a total of 4 strokes. I guess this is good for a 4-stroke engine PV diagram.
How would a 2-stroke engine PV diagram differ?
There would just be a compression stroke and expansion stroke and the exhaust would be in included in the compression stroke and intake would be included in compression stroke?
I think this would be the sequence of 2 stroke
0 to 1 intake phase
1 to 2 compression stroke
2 to 3 ignition phase
3 to 4 expansion stroke
4 to 5 heat rejection phase
5 to 0 exhaust phase
Post #9 is good, post #10 is wrong, or at least confusing. The intake phase (0-1) and exhaust phase (5-0) will not appear on the PV diagram as they will be included in the compression and expansion strokes. They are only 2 strokes.
I think this is it
0 to 1 to 2 to 3 compression stroke - included intake phase, compression stroke and ignition phase.
3 to 4 to 5 to 0 power stroke - includes power stroke, heat rejection, and exhaust phase
There are no 0 to 1 nor 5 to 0 lines drawn on the PV diagram. That is the difference between the 2-stroke and the 4-stroke PV diagrams. The 2-stroke has only 4 points:
Both the intake & exhaust phases will begin somewhere between 3 and 4 and end somewhere between 1 and 2.
Versus a 4-stroke engine PV diagram:
Sorry could u layout the strokes eg 1 to 2 to 3.
Sorry for being thick.1 to 2 to 3 I take, compression stroke and ignition.
3 to 4 to 1. Power stroke, heat rejection and exhaust.
If you look at the 4-stroke engine PV diagram in my last post, a downward stroke is from TDC (top dead center) to BDC (bottom dead center) and an upward stroke is from BDC to TDC. The same limits applied to a 2-stroke engine.
Likes jack action
Related to Would the two stroke spark ignition PV digram be same as for a 4 stroke?
1. What is the difference between a two stroke and a four stroke engine?
The main difference between a two stroke and a four stroke engine is the number of strokes required for one complete cycle. In a two stroke engine, the piston moves up and down twice in one revolution, while in a four stroke engine, the piston moves up and down four times in one revolution.
2. How does the spark ignition process differ in two stroke and four stroke engines?
In a two stroke engine, the spark plug fires once every revolution, while in a four stroke engine, the spark plug fires once every two revolutions. This is because the spark plug ignites the fuel-air mixture on every stroke in a two stroke engine, while in a four stroke engine, the spark plug only ignites the mixture on the power stroke.
3. Are the pressure-volume diagrams different for a two stroke and four stroke engine?
Yes, the pressure-volume (PV) diagrams are different for a two stroke and four stroke engine. In a two stroke engine, the PV diagram shows a single loop, while in a four stroke engine, the PV diagram shows two loops. This is due to the difference in the number of strokes required for one complete cycle.
4. Is the efficiency of a two stroke engine the same as a four stroke engine?
No, the efficiency of a two stroke engine is typically lower than a four stroke engine. This is because in a two stroke engine, some of the fuel-air mixture can escape through the exhaust port before it is fully burned, resulting in lower efficiency compared to a four stroke engine.
5. Can the same PV diagram be used for both two stroke and four stroke spark ignition engines?
No, the PV diagram for a two stroke spark ignition engine will be different from that of a four stroke spark ignition engine. This is because the combustion process and the number of strokes required for one complete cycle are different between the two types of engines.
  • Mechanical Engineering
  • Electrical Engineering
  • High Energy, Nuclear, Particle Physics
