A. Neumaier said:
Neither do you find precisely the value ##\pm \hbar/2## claimed to be measured by Born's rule. For in spite of many thousands of measurements of Stern-Gerlach type,
Planck's constant ##\hbar## is still known only to an accuracy of 9 decimal digits.
Thus Born's rule is a fiction even in this standard textbook example!
vanhees71 said:
The uncertainty of ##\hbar## is not fundamental but a technical problem, which will be solved next year or so by fixing its value, using either a Watt balance or a silicon ball. Then ##\hbar## will be exact as is the value of ##c## already since 1983. All this has absolutely nothing to do with any interpretation issues about QT!
A. Neumaier said:
So Born's rule was not valid in the past, and its validity depends on the choice of units?? This would be the only instance in physics where something depends in an essential way on units...
But there are problems with the experiment even when ##\hbar## is fixed: The measurement of angular momentum in a Stern-Gerlach experiment is a more complicated thing. One doesn't get an exact value ##\pm\frac{\hbar}{2}## even when ##\hbar## is fixed.
For in spite of what is claimed to be measured, what is really measured is something different -- namely the directed distance between the point where the beam meets the screen and the spot created by the particle on the screen (by suitable magnification). This is a macroscopic measurement of significant but limited accuracy since the spot needs to have a macroscopic extension to be measurable. From this raw measurement, a computation based on the known laws of physics and the not (or not yet) exactly known value of ##\hbar## is used to infer the value of the angular momentum a classical particle would have so that it produces the same spot. This results for the angular momentum in a value of approximately ##\pm\frac{\hbar}{2}## only, with a random sign; the accuracy obtainable is limited both by the limited accuracy of the distance measurement and (at present) the limited accuracy of the value of ##\hbar## used.
Thus for a realistic Stern-Gerlach measurement, Born's rule is only approximate, even when ##\hbar## is exactly known.
Only the idealized toy version for introductory courses on quantum mechanics satisfies Born's rule exactly since the two blobs at approximately the correct position and the assumed knowledge of exact 2-valuedness obtained from the quantum mechanical calculation count for demonstration purposes as exact enough. If the quantization result is not assumed and a true measurement of angular momentum is performed, one gets no exact numbers!
vanhees71 said:
I think, it's non-sensical to discuss further. I'm out at this point, to prevent provoking more off-topic traffic.
But it is certainly on-topic here.
Note that I don't claim that Born's rule is always wrong.
Like anything in physics, Born's rule has its range of validity but leads to problems when applied outside this range of validity. After a careful study of lots of alleged cases where the Born rule applies I conclude the following:
Born's rule in its standard version, i.e.,
upon measurement one obtains some eigenvalue, with a probability given by the usual formula, is valid precisely for measuring observables
- with only discrete spectrum,
- measured over and over again (to make sense of the probabilities), where
- the difference of adjacent eigenvalues is significantly larger than the measurement resolution, and where
- the measured value is adjusted to exactly match the spectrum, which must be known exactly prior to the measurement.
In particular, Born's rule does not apply in cases such as the total energy, one of the key observables in quantum mechanics, where the spectrum is often very narrowly spaced and the energy levels are usually only inaccurately known. Therefore
Born's rule cannot be used to justify the canonical ensemble formalism of statistical mechanics; it can at best motivate it. Born's rule also doesn't apply to situations where typically only single measurements of an observable are made. Therefore
Born's rule does not apply to typical macroscopic measurements, whose essentially deterministic predictions are derived from statistical mechanics.
The measurement of angular momentum is a case where the 4th assumption is clearly needed.
Consider a hypothetical student who performs a Stern-Gerlach experiment with a polarized silver beam (deflected always upwards) but (having been absent when the matter was discussed in the course) has no idea what the value of the angular momentum should be in this case. The student follows instead the standard rules for the measurement of angular momentum will have to measure as described in my post
#160 in the other thread the distance of the single spot produced and then perform some calculations to get some value for the angular momentum. The inevitable inaccuracy of the distance will inevitably lead to an inaccuracy of his measurement result. Measuring multiple times will lead to slightly different distances (agreeing to within the measurement accuracy) and hence to
slightly different values of the deduced angular momentum, against Born's rule taken literally, which requires that each time the exact value ##\hbar/2## is measured.
However, under the additional assumption 4., the student will know (from theory that must already be assumed to be correct to apply) that only two ideal measurement values are possible, namely ##\pm\hbar/2##. The measurement accuracy suffices to exclude the minus sign. Thus
the student silently sharpens the inaccurate measurement results to make them conform to the theory and reports a constant value ##\hbar/2## with that value of ##\hbar## that is the currently accepted norm. The student's supervisor,
Hendrik van Hees, approves this, although compared to the exact Born rule (with the true value of ##\hbar##), the measured value is still slightly in error, in the 10th decimal place. He counts this (today not checkable) discrepancy as only a technical problem, not as a limitation of the (in fact highly idealized) textbook description of Born's rule.
But in a few years, when the value of ##\hbar## is fixed exactly by a norm yet to be defined, the world of quantum interpretation is in order again.
