Converting PSD into equivalent sound pressure for an underwater hydrophone
  • Thread starter Thread starter nauman
To convert the measured PSD of -80 dBvrms/sqrtHz from the hydrophone output to equivalent underwater sound pressure level in dB re 1 µPa, the known sensitivity of -190 dB re 1 V/µPa and the preamplifier gain of 40 dB must be considered. The conversion involves adjusting the PSD value for the preamplifier gain and then applying the sensitivity reference. This process will yield the sound pressure level in the desired unit. Assistance is sought for the specific calculations involved in this conversion. Accurate conversion is crucial for underwater acoustics analysis.
nauman
Hi all
I have a underwater hydrophone with known receive sensitivity e.g. -190dB ref 1v/upa with a preamplifier having gain of 40dB at frequency e.g. 200Hz. I measure preamplifier output using spectrum analyzer and it gives PSD of around -80dBvrms/sqrtHz. I need to convert this PSD value into equivalent underwater sound pressure level with unit of dB ref 1upa.
Any help is much appreciated.
The measurement is of a single frequency, so that Power Spectral Density is not the appropriate measurement. All you need to measure is voltage. PSD is used for measuring noise like signals.
If you are actually measuring a noise-like signal, then the electronics must respond to the full sound spectrum and you need to know what the total bandwidth is.
If you have a narrow resolution bandwidth you can use that to convert the spectral density into a voltage. You can assume the psd is flat and just multiply by the measurement BW squared sqrt(BW). Of course the BW measured may only be part of the time domain signal.
For a more complex situation, it's like doing an inverse Fourier transform. It can't really be done without the phase information the spectrum analyzer threw out, but you could do the integral to get an estimate.
https://www.ti.com/content/dam/videos/external-videos/en-us/1/3816841626001/4078827152001.mp4/subassets/opamps-noise-calculating-root-mean-squared-noise-presentation-quiz.pdf#:~:text=To convert voltage spectral density to RMS,,to convert back to voltage or current.
edit: Oops! it's ##\sqrt{BW}## not ##BW^2##. Duh!, sorry
Hello! I want to generate an RF magnetic field at variable frequencies (from 1 to 20 MHz) using this amplifier: https://www.minicircuits.com/WebStore/dashboard.html?model=LZY-22%2B, by passing current through a loop of current (assume the inductive resistance is negligible). How should I proceed in practice? Can i directly connect the loop to the RF amplifier? Should I add a 50 Ohm in series? Thank you!
