How to quantify gyroscopic precession torque?
  • Context: Undergrad
  • Thread starter Thread starter rcgldr
    Precession Torque
The discussion centers on quantifying gyroscopic precession torque, particularly in the context of motorcycles and gyroscopes. Participants explore the relationship between various torques, angular momentum, and the effects of weight and speed on precession and steering dynamics.
  • Some participants reference a Wikipedia article that discusses the roll moment induced by precession and question how it is quantified, particularly regarding the influence of angular inertia and weight of the motorcycle.
  • There is a suggestion that to stop precession, a torque must be applied that cancels the horizontal torque from gravity, rather than a pure vertical torque.
  • One participant notes that the steering mechanism does not account for the weight of the motorcycle, which may affect the necessary torque to change lean angle.
  • Concerns are raised about the clarity of the forces exerted by a screwdriver in a referenced video, questioning how these forces relate to the quantification of torque needed to stop precession.
  • Participants discuss the relationship between the roll moment and the rate of change about the yaw axis, suggesting that multiple torques may interact in complex ways during motorcycle steering.
  • There is mention of the effects of lateral forces and angular momentum from the rear tire on the steering dynamics of the motorcycle.
  • Some participants express uncertainty about how to quantify the torque required to stop precession, indicating a need for further exploration of the topic.
Participants do not reach consensus on the quantification of gyroscopic precession torque or the specific conditions under which precession can be stopped. Multiple competing views and uncertainties remain regarding the interactions of various torques and forces.
Limitations include unclear definitions of torque components, dependencies on specific scenarios (e.g., weight and speed of motorcycles), and unresolved mathematical relationships between the discussed forces and torques.
  • #31
rcgldr said:
...an internal roll torque reaction to yaw "cancels" an external roll torque...
"Internal torque canceling an external torque" is exactly the kind of confused talk that leads nowhere.
rcgldr said:
This doesn't change the fact that there is only one external torque that results in precession.
External torques and forces are all we care about.
rcgldr said:
The gyro initially "drops a bit", and only after the drop has started does the gyro begin accelerating in the direction of precession.
Because of angular momentum and energy conservation the gyro cannot just start precessing, while maintaining exactly the same spin rate and spin axis inclination. The precession motion itself has its own small angular momentum component around the vertical axis, which must be reflected by an equal but opposite change in the vertical angular momentum from the spin.
And it is that small angular momentum component around the vertical axis that you need to remove to stop the yaw-precession.
  • #32
rcgldr said:
The torque from the straw is smaller than the torque from gravity, yet the gyro "drops" at a faster rate than it precesses due to gravity alone.
Here a linear momentum analogy that might help to understand why it drops so fast:
Linear momentum:
The force of gravity acting on a body in circular orbit continuously changes direction as the body moves along the orbit, so the linear momentum transferred by gravity doesn't accumulate, it just goes into continuously changing the direction of the bodies linear momentum. When you prevent it from moving tangentially the force of gravity has a fixed direction, so the linear momentum transferred by gravity quickly accumulates, and the body drops to the center fast.
Angular momentum:
The torque from gravity acting on a horizontally precessing gyro continuously changes direction as the gyro precesses, so the angular momentum transferred by gravity doesn't accumulate, it just goes into continuously changing the direction of the gyros angular momentum. When you prevent it from precessing horizontally the torque from gravity has a fixed direction, so the angular momentum transferred by gravity quickly accumulates, and the spin axis drops down fast.
  • #33
A.T. said:
angular momentum ... gravity
Doing the math from the Wikipedia article, if there was no gravity, and instead the axis support allowed yaw rotation, but not roll rotation, then if a yaw torque was applied to the gyro until the same rate of yaw as gravity induced precession, then the induced roll torque exerted onto the support would have the same magnitude but opposite direction from the torque that gravity would exert if present. Once that same rate of yaw was reached, the yaw torque would go to zero, and there would be a Newton third law like pair of roll torques: the gyro exerting an "upwards' roll torque onto the support that is preventing roll rotation, coexistent with that support exerting a "downwards" roll torque onto the gyro.
The support would need a reactive external torque to prevent the roll rotation, such as being attached to some massive object. Once the yaw torque was removed, then the gyro's change in angular momentum would be balanced by an opposing change in angular momentum of the massive object, and the angular momentum of gyro and object would be conserved. In this closed system, there are no external torques, since the total angular momentum is not changing. This what I meant by the "internal torque" that opposes gravity in the original case.
  • #34
Calling the roll torque "downwards" is a bad idea, even if you put it in quotes. That torque vector is horizontal, and continuously changes direction in the horizontal plane during yaw-precression. This continuous change of torque direction is key to why angular momentum doesn't accumulate during yaw-precression, but does accumulate when yaw-precression is prevented (see post #32). Calling that torque "downwards" doesn't allow to distinguish these two cases, which makes it a particularly bad naming choice here.
rcgldr said:
... This what I meant by the "internal torque" that opposes gravity in the original case.
Whatever complicated rationale, based on comparing different scenarios, you had for this terminology, it just sounds dead wrong, to say that an internal torque balances an external one for a specific scenario. Just like with your "downward torque" above, your terminology choices make it really hard to follow you.
  • #35
OK, but the key point was the torques involved with a gyro precessing at some specific rate about a vertical axis is the same for the gravity case or the support that only allows rotation about a vertical axis case, and in the support case, the yaw rate which is the same as the precession rate in the gravity case coexists with a roll torque that opposes the roll torque from the support, and the roll torque from the support is the same as the roll torque from gravity in the gravity case.
  • #36
A.T. said:
This ambiguity of natural language makes those informal descriptions rather useless, when your goal is to quantify something.
The formula for torque equals rate of change in angular momentum still applies, but when precession is prevented, the rate of change in angular momentum due to a torque perpendicular to what would otherwise be precession acts as if the gyro is not spinning and is just a function of angular inertia. As mentioned in that MIT video, "the gyro just falls". The torque for whatever is preventing precession would account for most if not all the change in angular momentum. The torque that the gyro exerts on whatever prevents precession coexists with a Newton third law torque that whatever prevents precession exerts onto the frame of the gyro.
Right hand rule has to compensate for the fact that there is a torque that exactly opposes precession.
  • #37
A.T. said:
This ambiguity of natural language makes those informal descriptions rather useless, ...
This is exactly the ambiguous language that is not very useful or even misleading. What does "the gyro just falls" mean exactly here?
The term "just falls" implies (or at least strongly suggests) that as soon it touches the precession-obstacle, the gyro axis moves in exactly the same way, as it would if the gyro was not spinning at all, and was just released, so it "just falls". Is this really true? Was the exact motion of the gyro axis at the precession-obstacle measured, and compared to a non-spinning gyro that was just released?
The term "falls" is a bad choice, even for the non-spinning gyro case, because it's not free falling.
  • #38
From Caltech Feyman Lecture Hall - "You'll also notice that if I stop its precession, it simply falls"". A slightly out of balance gyro in this example so the rate of fall is slow.
youtube - Caltech - stop precession
In this 1974 Laithwaite lecture, he gets some stuff wrong, but in this video clip you can see that when precession stops, the gyro just falls:
youtube - 1974 Laithewaite gyro
The part about precession having no angular momentum doesn't take into account that the force on the peg still has to generate the torque the correlates with the rate of change in angular momentum as the gyro falls.
On a motorcycle ridden in a straight line, friction prevents precession, and the bike will tip over as if neither wheel was spinning (the bike simply falls over). Not mentioned is that the lateral forces on the tires would have to generate the torque related to the rate of change in angular momentum of the front and rear wheels.
Wiki - precession prevented
Steering the front wheel outwards (counter-steering) does create an inwards roll torque, but it is a small compared to the inwards torque related to the tires out-tracking from under the motorcycle.
Wiki - roll torque from steering front wheel
  • Skeptical
  • #39
No. I cannot see that the gyro "just falls", because the exact definition of "just falls" is not provided.
If we adopt the definition in post #37, then you cannot properly determine that from fractions of a second in a video of a demo, where nothing is properly measured, as already explained:
In the Caltech video it's rather obvious that it doesn't "just fall" according to the definition in post #37. If you don't like that definition of "just falls", then provide your own. But posting examples of other people using this or similar undefined terms is just as pointless, as your use of them. And I don't quite understand what the point in reviving this old thread is, if you have nothing new to add.
  • #40
New to this thread: The law of torque versus rate of change of angular momentum still applies: the torque required to prevent precession is equal to the rate of change of angular momentum. Restated, the torque that prevents precession along one axis causes a gyro to instead to precess in the direction of and at the rate of change in angular momentum. In the case where gravity exerts a torque onto the gyro, the torque that prevents gravity related precession causes the gyro to accelerate downwards so that there is zero net torque related to gravity, and the gyro appears to "just fall". Right hand rule also applies in this situation, there has to be zero net toque due to gravity otherwise the gyro would have a component of precession that was not vertical.
Another example is at the start of this clip:
MIT large gimbal mounted gyro
How much torque was needed to hold the yellow frame in place while the gyro was being rotated from a vertical orientation to a horizontal orientation. Note that the person grips the yellow frame with his entire left hand, while rotating the gyro from vertical to horizontal with just his right thumb and finger. The rest of that clip shows normal precession.
  • #41
What is new about that? It was stated in this thread several times already.
To compute a force acting on a body, you need to know all the other forces acting on it, and the rate of change of its linear momentum.
To compute a torque acting on a body, you need to know all the other torques acting on it, and the rate of change of its angular momentum.
  • #42
The new part is that the torque opposing precession coexists with zero net torque in the direction of change of angular momentum (the direction of the original torque). The zero net torque in the direction of change of angular momentum is what I was missing before. In the case of gravity induced torque, the torque that prevents precession changes the precession to one that accelerates the gyro downwards so that there is zero net torque from gravity, which is why the gyro "just falls".
  • #43
Can you provide a clear diagram with all the vectors labeled properly, so we know what you are talking about?
"Zero net torque in the direction of change of angular momentum" is an oxymoron. The net torque vector has the same direction as the change of angular momentum.
rcgldr said:
... accelerates the gyro downwards so that there is zero net torque from gravity...
Why? Does gravity suddenly disappear, when the gyro accelerates downwards? Or did you rather mean that the upwards support force at the pivot is reduced when gyro's center of mass accelerates downwards?
Then you should analyse the torques around the center of mass, rather than around the pivot. Here the torque from gravity is always zero, and the torque from the upwards pivot force depends on the vertical linear acceleration of the center of mass.
rcgldr said:
... which is why the gyro "just falls".
Since you still haven't defined what "gyro just falls" means, it not clear what you were even attempting to explain.
  • #44
"Gyro just falls" is a quote from the Caltech video. Since there is no horizontal component of precession, the torque related to gravity must be zero. This requires the precession in response to the torque about the vertical axis to accelerate the gyro downwards, as if it were "just falling".
  • #45
But you are using it here, so you should provide an exact definition.
You started a thread with a title about quantifying something. But you refuse to provide a quantitative definition of what you are talking about.
  • #46
In the case of a gyro and gravity, the torque required to prevent precession about the vertical axis, so that there is only precession about a horizontal axis.
This requires that the precession about a horizontal axis results in zero net toque due to gravity, otherwise there would still be a component of precession about the vertical axis. The end result is the gyro appears to "just fall".
  • #47
Asking for:
- the torque required to change angular momentum direction
is like asking for:
- the force required to change linear momentum direction
Neither can be answered, without knowing how exactly the momentum vector is supposed to change over time. And please note that "so it just falls" is not exact enough here.
  • #48
A.T. said:
Asking for:
is like asking for:
The vertical axis torque exerted onto the gyro prevents any precession about the vertical axis. Two sources state that in this case, the gyro just falls as if it were not spinning. In addition to vertical forces related to gravity, there's also horizontal forces due to the support causing the gyro to follow a circular arc as it falls downwards, which could increase or decrease the effects of the gravity related vertical forces, which would affect the torque required to prevent precession about the vertical axis. Quantifying that torque versus time and state of the gyro may require an experiment.
A rotating cylinder with a hinge with a horizontal axis that supports the gyro is shown in this
video clip of precessing gyro
Consider the case where the support cylinder is prevented from rotating and that a torque sensor is involved so that the cylinder torque can be measured versus time, and an angle sensor in the hinge so that gyro position can be determined versus time. A near vertical gyro would be released and torque and gyro position would be sampled over time as the gyro falls. This would provide the information on how the momentum vector changes over time.
  • #49
Do they state the "as if it were not spinning" part explicitly, or are you merely interpreting some more vague statement here? Do they provide any measurements or analysis?
In the Calltech demo the gyro is obviously not falling as if it were not spinning. And Eric Laithwaite is not a reliable source on gyroscopes:
https://en.wikipedia.org/wiki/Eric_Laithwaite said:
In his 1974 lectures, Laithwaite suggested that Newton's laws of motion could not account for the behaviour of gyroscopes and that they could be used as a means of reactionless propulsion.
  • #50
A.T. said:
Do they state the "as if it were not spinning" part explicitly ...
"The rear wheel is prevented from precessing by friction of the tires on the ground, and so continues to lean as though it were not spinning at all. Hence gyroscopic forces do not provide any resistance to tipping"
Wiki - lateral gyroscopic effects
What I consider to be a missing bit about this is that a torque is still required to cause a rate of change in angular momentum. For the motorcycle case, there is a torque about a vertical axis due to the opposing lateral forces exerted by the pavement onto the front and rear contact patches.
Agreed. There are several false claims in his videos. I only included that one video to show a faster rate of drop of gyro. The statements he makes about that clip are wrong.
  • · Replies 0 ·
  • · Replies 30 ·
