hedgehug
- 54
- 1
@Ibix Note that I only really need ##a(t)/a(t_0)=1/(z+1)##, because ##t_0=t_{rec}## and ##t=t_{emit}##.
The discussion revolves around the normalization of the scale factor in cosmology, particularly in relation to the calculation of the radius of the observable universe. Participants explore the implications of redefining the scale factor and its effect on integrals used in cosmological models, including the FLRW metric.
Participants express differing views on whether redefining the scale factor constitutes normalization and whether the integral's numerical value changes with unit rescaling. No consensus is reached on these points, indicating ongoing debate.
Participants highlight that the definitions and conventions used in cosmology can significantly affect the interpretation of results, and the discussion includes various assumptions about units and their relationships.
So by "normalized" you mean "less than or equal to 1"? Where are you getting that definition from?hedgehug said:The ratio ##a(t)/a_0## is normalized, because ##1/(z+1)\le 1##.
I still don't see how this is "normalization". See above.hedgehug said:in my opinion it's practically like normalizing the scale factor itself. This time even literally and explicitly.
What is "equal" about two results that differ numerically by a factor ##\left( 1100 + 1 \right)##?hedgehug said:Equal.
This is only true if ##t \le t_0##. What if you're trying to compute something for a time ##t## that's later than now (##t_0##)?hedgehug said:the ratio ##a(t)/a(t_0)\le 1##
If this were true, no ##t## other than ##t_0## would have any meaning and this whole discussion would be pointless.hedgehug said:There has never been and there will never be other time for anyone
Physical, proper distances are equal after substituting Ly/1101 for NLy.PeterDonis said:What is "equal" about two results that differ numerically by a factor ##\left( 1100 + 1 \right)##?
I think you just need to have a last word. When I said that there has never been and there never will be other time for anyone, I meant the time when you are alive.PeterDonis said:If this were true, no ##t## other than ##t_0## would have any meaning and this whole discussion would be pointless.
I think you have not thought through your position very carefully.
Yes, but we still expect our physical models to cover other times besides those when we are alive. And that includes times to our future as well as to our past. For example, suppose we wanted to compute the radius of the observable universe five billion years from now, when the Sun is a red giant.hedgehug said:When I said that there has never been and there never will be other time for anyone, I meant the time when you are alive.
##a(t_{emit})/a(t_{rec})=1/(z+1)\le 1## for ##t_{emit}\le t_0## and ##t_{rec}>t_0## in the expanding universe.PeterDonis said:This is only true if ##t \le t_0##. What if you're trying to compute something for a time ##t## that's later than now (##t_0##)?
Bad habit from programming. Me and everyone I worked with have been calling a variable divided by its maximum value normalized.PeterDonis said:So by "normalized" you mean "less than or equal to 1"? Where are you getting that definition from?
So now you're changing the definition of what variable you're using? Or did you really mean ##t_{rec}## before when you wrote ##t_0##?hedgehug said:##a(t_{emit})/a(t_{rec})=1/(z+1)\le 1##
You've been using ##t_0## all through this thread up until post #31, when you used ##t_{rec}##, and that was in response to @Ibix using it, and then post #39. That's a change. (And for that matter, you didn't use ##t_{emit}## until post #31 either; your OP in this thread gave an integral that starts at the Big Bang, ##t = 0##, which isn't the "time of emission" of anything.)hedgehug said:I'm changing nothing.
Even if I accept this, the variable here is not the scale factor but the ratio of scale factors, and it only has a "maximum value" of ##1## because we put the earlier time in the numerator and because we insist on moving the time in the denominator to be the latest time we're considering. If we flip the ratio around (which makes more sense since then we're basically just looking at the redshift), it has no maximum value.hedgehug said:Me and everyone I worked with have been calling a variable divided by its maximum value normalized.
Correct, for the expanding universe.PeterDonis said:Even if I accept this, the variable here is not the scale factor but the ratio of scale factors, and it only has a "maximum value" of
But the scale factor does not have to be normalized to the proper distance; that's the point. It doesn't matter how the scale factor is defined.hedgehug said:What really asserts the scale factor normalization, is the proper distance calculation
That doesn't mean it's normalized; it means it's irrelevant to the proper distance calculation because it cancels out.hedgehug said:it cancels out after the integration
That's the point. The formula for the proper distance always gives the same result as for the normalized scale factor, because it cancels out its not normalized value ##a(t_0)##.PeterDonis said:But the scale factor does not have to be normalized to the proper distance; that's the point. It doesn't matter how the scale factor is defined.
I don't agree with you calling the definition ##a(t_0) = 1## "normalized", which is what you're doing here. It's a convenient convention, that's all. It's not normalized to anything.hedgehug said:the normalized scale factor,
As I said, we agree on the physics. We just disagree on the usage of the term "normalization". I don't agree with your usage of it here, just as I don't agree with your other usages of it in this thread. If you are going to insist on such usage, I think you need to provide some references to the literature (textbooks or peer-reviewed papers) that support it.hedgehug said:I just hope you can agree that ##a(t_0)\ne 1## and ##a(t_0)/a(t_0)=1## is very much like the normalization in the proper distance calculation with the upper limit of integration equal to ##t_0##.
I agree that you need to know the scale factor as a function of time, in whatever coordinates and with whatever conventions you've adopted, in order to evaluate the proper distance integral, yes.hedgehug said:scale factor function is totally relevant to the proper distance calculation, which totally depends on it.
The value of "how many times the universe has expanded since the BB", which is basically what your integral is computing, does not depend on how you define the scale factor, because, as you have already shown, the scale factor definition drops out of the integral. It depends on the ratio of scale factors, but that ratio is independent of how you define the scale factor (what time you pick for ##a = 1##).hedgehug said:Should it really make no difference for the proper size of the universe, how many times the universe has expanded since the BB
You don't have to explicitly take such a ratio to evaluate the integral. You can take a limit as ##t \to 0##, and find that you get a finite answer for the integral. Similar remarks would apply to any other calculation that on its face involves ##t = 0##. Note that the "initial singularity" ##t = 0## is not actually part of the spacetime manifold.hedgehug said:the ratio ##a(t_0)/a(0)## is quite problematic to me.
Which of course is meaningless if you look at ##t = 0## itself. But as above, ##t = 0## is not actually part of the manifold. At any time ##t > 0##, the ratio is finite and has the physical meaning you describe.hedgehug said:This ratio (not the proper distance calculation) should tell us how many times the universe has expanded since the BB
Because it's irrelevant. You don't have to divide by zero to take the limit as I described. Or to calculate any other actual physical quantity from the FRW model.hedgehug said:For the second time you didn't quote the second part of my sentence about the division by 0.
No, because, as I've already said, that particular quantity does not have a finite limit as ##t \to 0##. But you don't need an answer to that question to evaluate any actual physical quantity. (Note that, as I've already said, ##t = 0## is not part of the spacetime manifold, so asking by what factor the universe has expanded since ##t = 0## has no physical meaning. Such a question only has physical meaning for ##t \gt 0##.) For example, you don't need it to evaluate the integral that gives you the size of the observable universe.hedgehug said:Can you answer the question How many times the universe has expanded using your limit ##t\rightarrow 0##?
