The stream from the bottom of the bottle becomes short when the bottle is filled from above
  • Context: Undergrad
  • Thread starter Thread starter Mihal
The length of the water jet exiting the bottom of a bottle shortens when the bottle is filled from above, impacting the design of Kelvin generators where jet length is critical. The flow rate at the bottle's outlet depends on the internal water level, and the jet accelerates due to gravity as it falls. Filling methods affect jet behavior: filling directly from a tap results in a shorter acceleration distance and a shorter, more cohesive jet, while filling with a hose allows a longer fall distance, causing the jet to break into droplets. The jet breakup and noise upon impact correlate with the fall distance and flow dynamics, influencing the volumetric flow perception.
  • Fluid dynamics of free-falling liquid jets
  • Kelvin generator design principles
  • Hydrodynamics of flow rate dependence on fluid height
  • Gravity-driven acceleration effects on liquid streams
  • Analyze jet breakup mechanisms in free-falling water streams
  • Study the impact of filling methods on volumetric flow stability
  • Investigate the role of internal bottle geometry and sponges on flow regulation
  • Apply fluid visualization techniques to measure jet length and coherence
Engineers and designers working on Kelvin generators, fluid dynamics researchers, and anyone involved in precision fluid flow control and experimental hydrodynamics.
Mihal
the homogenous part of the stream becomes too short when the bottle is being filled from above. I need the longer stream when the bottle is being filled, such is shown on the photo where the bottle is not being filled.
this is needed for the kelving generator, in the design of which the lengths of the components are important. In this case, the length of the jet is the length from the nozzle to the inductor, and it must be specific and not changing during its falling. So I don't want it to shorten when I pour water into the bottle from the tap or hose!
Welcome!
Place a big sponge inside the bottle.
The flow rate at which water exits the bottom of the bottle, is dependent on the water level in the bottle.
As water falls from the bottom of the bottle it accelerates due to gravity.
When filling directly from the tap, there is little height remaining between the bottom of the bottle and the sink, over which the water can accelerate downwards, but the bottle can be closer to full.
When being filled with a hose, the filling rate may be less, but the water will have more distance and time to accelerate downwards.
The further the water falls, the more it begins to break up, and bead into droplets, so it makes more noise when it impacts the sink. You do not see the volumetric flow rate, you hear the impact.
I feel you may have misunderstood the question.
I presume images 1 and 2 show the bottle being continuously filled from a tap, while 3 and 4 show it being held at a greater height and without any input. Image 2 shows the flow breaking up before reaching the sink even though it had less distance to fall than in image 4, where it does not break up. Moreover, one would have guessed that the bottle is fuller in images 1 and 2 than in 3 and 4, making the volumetric flow greater.
@Mihal, how full is the bottle in images 1? Is it at least as full as in image 3?
The question is unconstrained, with many degrees of freedom, and so open to multiple interpretations.
I also feel you may have misunderstood the question.
So where does your interpretation differ from mine in post #4?
Until the question can be better defined, the question and possible interpretations are not worthy of further investment.
Ok, but I feel it is reasonably clear.
  • · Replies 20 ·
12K
  • · Replies 28 ·
  • · Replies 22 ·
