Special relativity and diffracting beams
  • Context: Undergrad
  • Thread starter Thread starter calacone
The discussion addresses the relativistic Doppler shift of a 1 µm wavelength Gaussian light beam observed by a particle moving at near-light speed (v/c ~ 1 - O(10^-16)), resulting in an apparent wavelength in the MHz range (hundreds of meters). Despite the beam's transverse localization at millimeter or centimeter scales, relativistic effects such as the inverse headlight effect (aberration) cause the beam to appear broader in the particle's rest frame. The Abbe diffraction limit applies isotropically, but longitudinal relativistic motion does not alter transverse wavelength, leading to increased beam divergence as observed by the moving particle. The phenomenon is explained using Huygens' Principle, where superimposed wavelets from a wide wavefront create a broader effective beam at longer wavelengths in the particle's frame.
  • Special relativity Doppler shift and Lorentz transformations
  • Gaussian beam optics and beam divergence
  • Abbe diffraction limit and isotropic wavelength assumptions
  • Huygens' Principle and wave superposition
  • Analyze relativistic aberration effects on beam profiles in moving frames
  • Study diffraction-free beam configurations and their relativistic transformations
  • Model Gaussian beam divergence under extreme Doppler shifts
  • Explore experimental setups with periodic focusing mirrors to manipulate beam localization
Physicists and optical engineers studying relativistic effects on electromagnetic wave propagation, researchers working on high-speed particle interactions with laser beams, and theorists modeling beam behavior under extreme Doppler shifts and relativistic aberration.
calacone
Say there is a beam of light at 1 um (f=300 THz), and there is a particle traveling at constant speed along the axis of the beam, which is, say, a few mm or cm in diameter. Say the particle is going fast enough so that the shift brings the light down to the MHz level (v/c ~ 1- O(10^-16)). Then the wavelength as measured by the particle will be something like a few hundred meters. But how can this happen, if the beam is localized in the transverse direction at the mm or cm level?
If it is a gaussian beam, then I think the beam divergence would make the beam appear consistent with the wavelength observed by the particle, even if the beam divergence is small in our rest frame (I haven't checked this). What about diffraction free beams? Or other odd arrangements that allow the particle to see a highly localized spot at MHz frequencies (say, focusing mirrors spaced periodically along the axis of the beam path but offset to either side, so that the beam periodically intercepts the path of the particle, or something like this).
(sorry in advance for not checking the math, nor checking previous forum posts for similar questions)
Long wavelength and small bundle beam are compatible.
The Abbe diffraction limit assumes an isotropic wavelength. The relativistic movement of a reference frame in longitudinal direction does not change the wavelength in transverse direction.
If the beam is not perfectly collinear, the beam has a wider angle in the rest-frame of the moving particle, due to the (inverse) relativistic headlight effect (aberration).
I think this phenomenon will occur with any wave, such as sound. The small diameter wavefront seen at optical frequencies may be considered as arising from the superimposition of wavelets from an infinitely wide wavefront. This is Huygens' Principle at work. If you now travel along the beam, the waves as observed are longer; in other words, you need to travel further for a given phase shift. The waves from the outer Huygens' Sources are also longer, so there is less phase difference as we move off axis. So I think you will observe a broader beam. The beam will diverge at a greater angle than the original optical beam. In essence, I am suggesting that the entire space is filled with the optical energy, even though you see a narrow cone, and when you travel along the beam there will be created a broader beam by the process of superimposition.
  • · Replies 33 ·
  • · Replies 40 ·
  • · Replies 73 ·
10K
