Open circuit resonator not acting according to theory
  • Thread starter Thread starter yefj
The discussion addresses the implementation challenges of an open circuit microstrip resonator designed to resonate at 5 GHz, focusing on poor S-parameter performance due to improper excitation and loading. It is established that measuring S11 directly with a 50Ω load suppresses resonance, and proper excitation requires lightly coupled input and output probes arranged as three spaced microstrip lines: input, resonator, and output. The resonator length should be λ/2, often bent into a U-shape, while input and output lines act as λ/4 quarter-wave transformers. References to distributed-element filters and hairpin resonators clarify the correct design approach for frequency-selective resonance and accurate S-parameter characterization in a 50Ω matched system.
  • Microstrip resonator design at microwave frequencies (5 GHz)
  • S-parameter measurement techniques in 50Ω matched systems
  • Quarter-wave transformer theory (λ/4 transmission lines)
  • Distributed-element filter concepts and hairpin resonator structures
  • Study hairpin resonator design and implementation for microstrip circuits
  • Learn advanced S-parameter measurement and interpretation for resonant structures
  • Explore techniques for lightly coupled input/output probes in microstrip resonators
  • Review distributed-element filter theory from authoritative sources such as Wikipedia and RF engineering texts
RF engineers, microwave circuit designers, and antenna developers working on microstrip resonators and frequency-selective components who require accurate resonance characterization and improved impedance matching techniques.
yefj
Hello, I have tried to implement an open circuit microstrip resonator .
I got the microstrip resonating at 5Ghz as shown below.
However the S-parameters is very bad.
Is there a way to improve the matching so It will have a better dip in 5GHz.
If you measure S11 at one end of the resonator you will be loading it with 50Ω. That will kill any resonance.
You need to excite the resonator with a lightly coupled input signal, then view the output from a lightly coupled load. That requires three spaced strips on the PCB, one input, one resonator, and one output probe. The resonance will appear as a dip of the input, and a peak in the load on the output.
The input and output will be λ/4 long, which makes them quarter wave transformers.
The resonator will be λ/2, and so is usually bent into a 'U'.
https://en.wikipedia.org/wiki/Distributed-element_filter
Google: 'hairpin resonator'
  • Agree
That could be achieved with a very high impedance source feeding in parallel with (across) the transmission line ('injecting from a Current Source'.)
@yefj
Re S parameters: The way the (Complex) S parameters are measured is by measuring the forward and reflected waves in a 'good' 50Ohm matched system. If you want to design a circuit with a resonator in it with an S Parameter tester then I think you should be looking at the S Parameters of the whole circuit or a part of the planned circuit. The point of the resonator will be frequency selective (obvs). The S parameter could reveal the presence of a resonator by an amplitude blip or a rapid phase change with frequency, depending.
Units police here. 50Ohm has problems.
Ohm was a person, so ohm is the unit.
50 ohm is spaced, 50Ω is not.
47 kilohm is contracted, 47 kilo ohm is not. 47kΩ is also correct.
Low hanging fruit, officer. :smile:
Have a lovely day.
10K
