A Toy Model of Atmospheric Geophysics
  • Level: Undergrad
  • Thread starter Thread starter wrobel
3 replies · 1K views
Insights Author
In this thread, I propose a very naive, homemade model of particle behavior in an atmosphere.
Assume that the Earth and its atmosphere rotate as a unified rigid body about a fixed axis with constant angular velocity ##\boldsymbol\omega##. Assume that a particle of mass ##m## moves in a plane perpendicular to the vector ##\boldsymbol\omega## and containing the center of the Earth.
The particle is subjected to a gravitational force and a drag force
$$\boldsymbol F=-\gamma \boldsymbol v_{rel},\quad \boldsymbol v_{rel}=\boldsymbol v-\boldsymbol \omega\times\boldsymbol r,\quad \gamma>0.$$
Here, ##\boldsymbol v## is the particle's velocity, and ##\boldsymbol v_{rel}## is its velocity relative to the atmosphere.
##\boldsymbol r## stands for the position vector of the particle relative to the Earth's center (the origin).
Introduce fixed polar (inertial) coordinates ##(r,\varphi)## such that ##\boldsymbol r=r\boldsymbol e_r##
and
$$\boldsymbol v=\dot r\boldsymbol e_r+r\dot\varphi\boldsymbol e_\varphi.$$
Thus, in these fixed polar coordinates, the Lagrangian of the system (excluding the non-conservative drag force) is
$$L=\frac{m}{2}\left(\dot r^2+r^2\dot\varphi^2\right)+\frac{G}{r},\quad G>0.$$
The Lagrange equations of the second kind are written as
$$\frac{d}{dt}\frac{\partial L}{\partial \dot r}-\frac{\partial L}{\partial r}=Q_r,\quad
\frac{d}{dt}\frac{\partial L}{\partial \dot \varphi}-\frac{\partial L}{\partial \varphi}=Q_\varphi,$$
where ##Q_r## and ##Q_\varphi## are the non-conservative generalized forces defined by
$$Q_r=\left(\frac{\partial\boldsymbol v}{\partial \dot r},\boldsymbol F\right)=-\gamma\dot r,\quad
Q_\varphi=\left(\frac{\partial\boldsymbol v}{\partial \dot \varphi},\boldsymbol F\right)=-\gamma r^2(\dot\varphi-\omega).$$
I think it would be interesting if someone could plot a few trajectories numerically and share the images here
So you are neglecting the effects of the solar radiation (including that it is distributed non-uniformly over the sunlit half of the earth) in determining the transient temperature and density profiles in the atmosphere, and are also neglecting atmospheric chemistry. Also, you are neglecting the thermal inertia of the atmosphere coupled with the rotation. This says nothing about about atmospheric turbulence, and its effects in producing local variations on a small scale.
wrobel said:
Yes, I neglect these effects and many others that you didn't mention.
Neglect will be more or less?
