How can I fix my glitchy mouse pad while using my laptop on a metal table?
  • Thread starter Thread starter Ivan Seeking
The discussion centers around a user experiencing touchpad issues with their Dell Precision laptop when placed on a stainless steel table. The mouse pad becomes unresponsive, but functions correctly when the laptop is lifted off the table. Various potential causes were explored, including electrical noise and surface pressure affecting the laptop's case. Suggestions included testing different surfaces and checking for torque or pressure on the laptop's body, which did not resolve the issue. The user noted that the problem did not occur on standard office surfaces and mentioned a previous experience where altitude affected computer performance in a confined space. Other contributors highlighted the possibility of local power inducing currents in the table or issues with the laptop's grounding, especially when plugged in. Recommendations included using a mouse or avoiding use while charging, as well as checking for loose connections or calibration issues with the touchpad that could arise from physical handling of the laptop.
Ivan Seeking
Staff Emeritus
Yesterday I was onsite doing computer work with a customer while sitting at a metal [stainless] table. Whenever the computer [my laptop] was on the table, my mouse pad was so glitchy that it was useless - the cursor didn't respond to most finger movements. We eliminated all potential sources of electrical noise but with no effect. If I lifted my computer off the table, the mouse operated properly. I tried sitting the computer on a piece of thick cardboard but even that didn't fix the problem.
I'm guessing this was somehow due to the damping of magnetic fields, but that is hard to believe.
Computer science news on Phys.org
I don't know what laptop you use, but what *could* be the case is that the surface you place your laptop on causes a slight 'bump' in the case, which messes with your touchpad. On the other hand, I find this almost as hard to believe as a damping of magnetic fields, but it's easy enough to rule out: try holding and applying some pressure to the bottom of your laptop, and then see if it's glitchy again.
Other than that, I really have no idea. Have you tried different surfaces other than the table and the cardboard?
Checking for torque on the body was a good thought, but nope. I can apply pressure to both side of the computer [including front to back] and still operate the mouse with no problem.
In my office I am normally working on a standard table surface and haven't had any problems. This was my first visit onsite [anywhere] with my new computer, so I may see more problems in the future. We did finally move the computer to another surface a few feet away and everything was fine again.
It is a Dell Precision... 4600... I think.
Sidebar: There was one job where my computer would fail every time I was onsite. As it turned out, the problem appeared to be altitude [I guess the ventilation was the real cultprit]. This was for a very small control room, about fifteen feet in diameter, located at least 25 feet [or more] underground... not sure now how far down it was any more. I had to climb down a vertical ladder from ground level. Someone back then mentioned that hard drives can be affected temporarily by pressure changes. So after that I went down and set up and then left for coffee. When I got back, my computer would boot properly again.
You know, I'm wondering if this is a problem I've seen before. Perhaps local power is inducing currents in the table top. It is a long surface sitting against a wall.
I was remindeed of a problem I had many years ago where we had overhead power lines causing no end of problems on a mobile CAT scanner. I finally checked and could measure something like 130 to 140 volts AC to ground, on the body of the bus. When we looked up, there they were - big lines feeding the hospital.
It could also be a short in your laptop and the table is Earthing it. Use a multimeter.
Have you checked it with Charger/AC power cord plugged into the socket ?
Sounds like some kind of loose connection to me. Mice are cheap. I've had the same kind of luck with keyboards and have gone through 3 in the last year or so. The last one got really weird on shift characters. New keyboard, problem solved [at least for now].
Happens to my laptop from time to time. I think its some sort of calibration issue. It always happens after I lift my laptop to carry from one room to the next or from one desk to the next. If I carry it with one hand, the touchpad will no longer operate correctly, even if I'm using one hand to hold it horizontally. I think that some sort of bending pressure I put on the hardware as I hold it with one hand messes up some sensors in or connected to the touchpad. This only happens when I carry the laptop when its on. And when this does occur, a simple reboot fixes the problem. It is a strange anomoly.
Yes this would also be something that I would check. Does the problem occur only when it is plugged in? If yes, then there micht be a problem with the earthing. The capacitative touchpad won't respond well in such a case. Best solution would be getting a mouse or avoiding use while charging.
