Question about 2nd order linear ODEs series solutions
Tosh5457
I got some questions about this topic...
y'' + p(z)y' + q(z)y=0
where y (and its derivatives) is a function of z, z ∈ ℂ.
1) My books says this: In points where both p(z) and q(z) are analytic, y(z) is also analytic. But in points where p(z) or q(z) (or both) aren't analytic, y(z) may not be analytic.
Since y(z) is a differentiable complex function in an open set (it must be for the ODE to make sense, right?), it's holomorphic in that set, and so it's analytic. So I don't understand why y(z) may not be analytic when p or q aren't analytic. Why does y(z) being analytic or not even depends on the behavior of these functions?
2) This is a question about an example.
The problem is:
Find the series solutions, about z = 0, of
y''(z) + y(z) = 0
y can be written as a power series (it's analytic), so:
y(z)=\sum_{n=0}^{\infty}a_{n}z^{n}
Substituting the series in the EDO, we obtain the two-term recurrence relation:
a_{n+2}=-\frac{a_{n}}{(n+2)(n+1)}, n \geq 0
So,
y(z)=1+z-\frac{z^{2}}{2!}+\frac{z^{3}}{3!}-...
Which is equal to:
y(z) = cos(z) + sin(z)
The solution to the EDO is:
y(z) = c_{1}cos(z) + c_{2}sin(z)
Why isn't the solution this though?:
We stated that y(z) was a power series, and the power series turned out to be cos(z) + sin(z), so why do we take the linear combination of these 2 functions as the solution? Was the initial assumption that y(z) equals a power series wrong?
Thanks :smile:
To your first question: suppose p(z) = 1/z and q(z) = -1/z^2. These aren't analytic at z = 0 even though they are analytic everywhere else. Multiplying the ODE by z^2 then gives z^2y'' + zy' - y = 0, which has solution y(z) = Az + B/z for arbitrary constants A and B. We see that at z = 0, 1/z is not analytic. On the other hand, z is analytic at z = 0.
Points at which p(z) or q(z) have (essential) singularities are called singular points of the ODE, and typically at least one of the two linearly independent solutions will have a(n essential) singularity at such a point. Another example is Bessel's equation: p(z) = 1/z, q(z) = 1 - a^2/z^2 where a is a constant; the J solutions are bounded at z = 0, but the Y solutions have a singularity.
The problem is:
y''(z) + y(z) = 0
You already know (I hope) that the solution of that is ##y(0)\cos(z) + y'(0)\sin(z)##, so if you don't end up with that then you've made an error in your calculations.
So far so good.
Tosh5457 said:
So,
Here's your error: Why should a0 = a1 = 1? a0 and a1 are determined by the initial conditions, but you haven't been given any. So you leave a0 and a1 as arbitrary constants.
You're asked for series solutions, so now you need to solve this recurrence relation to find ##a_n## in terms of ##a_0## and ##a_1##.
You should satisfy yourself (ideally by a formal proof by induction) that if n = 2m (##m \geq 0##) then
a_{2m} = a_0 {{(-1)^m} \over (2m)!}
and if n = 2m+1 (##m \geq 0##) then
a_{2m+1} = a_1 {{(-1)^m} \over (2m+1)!}
so that
y(z) = <br /> \sum_{n=0}^{\infty} a_n z^n =<br /> a_0\sum_{m=0}^{\infty} {{(-1)^m z^{2m}} \over (2m)!}<br /> + a_1\sum_{m=0}^{\infty} {{(-1)^m z^{2m+1}} \over (2m+1)!}
which gives us the series solutions you were asked to find. You should recognize this as the power series about ##z = 0## of ##y(z) = a_0 \cos(z) + a_1 \sin(z)##.
So far so good.
so that
"excellent job and your analysis point on, pasmith. You are correct on all notes,
a_0 and a_1 are arbitary, unless given specifications. "
yus310
So far so good.
so that
On the 2nd part, I didn't do the exercise, that was the resolution from the book. Thanks for the reply, I understand now :smile:
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
